Part Number: LAUNCHXL-CC2650
I am trying to send an integer value, but I can only see the hex value. How to convert or present a char value in decimal?
thanks,
Rathna
thanks,
Rathna
Rathna said:but I can only see the hex value.
Exactly how do you see it? What makes you think it is a hex value?
Thanks and regards,
-George
Thank you for the response. I am using Ble Scanner App, I am working on SimpleBLEPeripheral Example.
This is my code in simpleProfile_ReadAttr(), and I am using Char4 to display data:
case SIMPLEPROFILE_CHAR4_UUID:
uint8_t level;
level = battMeasure();
battLevel = level;
if (level < battLevel)
// Update level
battLevel = (uint8)(level & 0x00FF);
*pLen = 1;
pValue[0] = battLevel;
And here is how I am getting Voltage value,
static uint8_t battMeasure(void)
uint32_t batt;
// Read the battery voltage (V), only the first 12 bits
batt = AONBatMonBatteryVoltageGet();
batt = (batt * 125) >> 5;
return batt;
I am getting, 0x78 as the hex value, and x as the value.
Can you please guide me through this.
Rathna
