CCS/CC2640R2F: how to add Uart log into simple_peripheral_cc2640r2lp_app project
Part Number: CC2640R2F
Other Parts Discussed in Thread: CC2640
I am trying to bring uart log into  simple_peripheral_cc2640r2lp_app project.
Board cc2640. SDk:2.4.0.00.32
the reference is below
Code of main.c,, simple_peripheral.c and appBLE.cfg as below
 @file  main.c
 @brief main entry of the BLE stack sample application.
 Group: WCS, BTS
 Target Device: cc2640r2
 Copyright (c) 2013-2019, Texas Instruments Incorporated
 All rights reserved.
 Redistribution and use in source and binary forms, with or without
 modification, are permitted provided that the following conditions
 are met:
 *  Redistributions of source code must retain the above copyright
    notice, this list of conditions and the following disclaimer.
 *  Redistributions in binary form must reproduce the above copyright
    notice, this list of conditions and the following disclaimer in the
    documentation and/or other materials provided with the distribution.
 *  Neither the name of Texas Instruments Incorporated nor the names of
    its contributors may be used to endorse or promote products derived
    from this software without specific prior written permission.
 THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * INCLUDES
#include <xdc/runtime/Error.h>
#include <ti/drivers/Power.h>
#include <ti/drivers/power/PowerCC26XX.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/display/Display.h>
#include <icall.h>
#include "hal_assert.h"
#include "bcomdef.h"
#include "peripheral.h"
#include "simple_peripheral.h"
/* Header files required to enable instruction fetch cache */
#include <inc/hw_memmap.h>
#include <driverlib/vims.h>
#ifndef USE_DEFAULT_USER_CFG
#include "ble_user_config.h"
// BLE user defined configuration
#ifdef ICALL_JT
icall_userCfg_t user0Cfg = BLE_USER_CFG;
#else  /* ! ICALL_JT */
bleUserCfg_t user0Cfg = BLE_USER_CFG;
#endif /* ICALL_JT */
#endif // USE_DEFAULT_USER_CFG
#ifdef USE_FPGA
#include <inc/hw_prcm.h>
#endif // USE_FPGA
#include <ti/drivers/UART.h>
// To initialize the uart log output (only needed here)
#include "uart_logs.h"
 * MACROS
 * CONSTANTS
#if defined( USE_FPGA )
  #define RFC_MODE_BLE                 PRCM_RFCMODESEL_CURR_MODE1
  #define RFC_MODE_ANT                 PRCM_RFCMODESEL_CURR_MODE4
  #define RFC_MODE_EVERYTHING_BUT_ANT  PRCM_RFCMODESEL_CURR_MODE5
  #define RFC_MODE_EVERYTHING          PRCM_RFCMODESEL_CURR_MODE6
  #define SET_RFC_BLE_MODE(mode) HWREG( PRCM_BASE + PRCM_O_RFCMODESEL ) = (mode)
#endif // USE_FPGA
 * TYPEDEFS
 * LOCAL VARIABLES
 * GLOBAL VARIABLES
#ifdef CC1350_LAUNCHXL
#ifdef POWER_SAVING
// Power Notify Object for wake-up callbacks
Power_NotifyObj rFSwitchPowerNotifyObj;
static uint8_t rFSwitchNotifyCb(uint8_t eventType, uint32_t *eventArg,
                                uint32_t *clientArg);
#endif //POWER_SAVING
PIN_State  radCtrlState;
PIN_Config radCtrlCfg[] =
  Board_DIO1_RFSW   | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW  | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* RF SW Switch defaults to 2.4GHz path*/
  Board_DIO30_SWPWR | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* Power to the RF Switch */
  PIN_TERMINATE
PIN_Handle radCtrlHandle;
#endif //CC1350_LAUNCHXL
 * EXTERNS
extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
extern Display_Handle dispHandle;
 * @fn          Main
 * @brief       Application Main
 * input parameters
 * @param       None.
 * output parameters
 * @param       None.
 * @return      None.
int main()
  HWREG(PRCM_BASE + PRCM_O_PDCTL0) &= ~PRCM_PDCTL0_RFC_ON;
  HWREG(PRCM_BASE + PRCM_O_PDCTL1) &= ~PRCM_PDCTL1_RFC_ON;
#endif // USE_FPGA
  /* Register Application callback to trap asserts raised in the Stack */
  RegisterAssertCback(AssertHandler);
  PIN_init(BoardGpioInitTable);
  UART_Params uartParams;
   UART_Params_init(&uartParams);
   uartParams.baudRate = 115200;
   UART_Handle hUart = UART_open(Board_UART0, &uartParams);
   // Initialize the logger output
   UartLog_init(hUart);
  // Enable 2.4GHz Radio
  radCtrlHandle = PIN_open(&radCtrlState, radCtrlCfg);
#ifdef POWER_SAVING
  Power_registerNotify(&rFSwitchPowerNotifyObj,
                       PowerCC26XX_ENTERING_STANDBY | PowerCC26XX_AWAKE_STANDBY,
                       (Power_NotifyFxn) rFSwitchNotifyCb, NULL);
  // set RFC mode to support BLE
  // Note: This must be done before the RF Core is released from reset!
  SET_RFC_BLE_MODE(RFC_MODE_BLE);
#endif // USE_FPGA
#ifdef CACHE_AS_RAM
  // retain cache during standby
  Power_setConstraint(PowerCC26XX_SB_VIMS_CACHE_RETAIN);
  Power_setConstraint(PowerCC26XX_NEED_FLASH_IN_IDLE);
#else
  // Enable iCache prefetching
  VIMSConfigure(VIMS_BASE, TRUE, TRUE);
  // Enable cache
  VIMSModeSet(VIMS_BASE, VIMS_MODE_ENABLED);
#endif //CACHE_AS_RAM
#if !defined( POWER_SAVING ) || defined( USE_FPGA )
  /* Set constraints for Standby, powerdown and idle mode */
  // PowerCC26XX_SB_DISALLOW may be redundant
  Power_setConstraint(PowerCC26XX_SB_DISALLOW);
  Power_setConstraint(PowerCC26XX_IDLE_PD_DISALLOW);
#endif // POWER_SAVING | USE_FPGA
#ifdef ICALL_JT
  /* Update User Configuration of the stack */
  user0Cfg.appServiceInfo->timerTickPeriod = Clock_tickPeriod;
  user0Cfg.appServiceInfo->timerMaxMillisecond  = ICall_getMaxMSecs();
  /* Initialize ICall module */
  ICall_init();
  /* Start tasks of external images - Priority 5 */
  ICall_createRemoteTasks();
  /* Kick off profile - Priority 3 */
  GAPRole_createTask();
  SimplePeripheral_createTask();
  /* enable interrupts and start SYS/BIOS */
  BIOS_start();
  return 0;
 * @fn          AssertHandler
 * @brief       This is the Application's callback handler for asserts raised
 *              in the stack.  When EXT_HAL_ASSERT is defined in the Stack
 *              project this function will be called when an assert is raised,
 *              and can be used to observe or trap a violation from expected
 *              behavior.
 *              As an example, for Heap allocation failures the Stack will raise
 *              HAL_ASSERT_CAUSE_OUT_OF_MEMORY as the assertCause and
 *              HAL_ASSERT_SUBCAUSE_NONE as the assertSubcause.  An application
 *              developer could trap any malloc failure on the stack by calling
 *              HAL_ASSERT_SPINLOCK under the matching case.
 *              An application developer is encouraged to extend this function
 *              for use by their own application.  To do this, add hal_assert.c
 *              to your project workspace, the path to hal_assert.h (this can
 *              be found on the stack side). Asserts are raised by including
 *              hal_assert.h and using macro HAL_ASSERT(cause) to raise an
 *              assert with argument assertCause.  the assertSubcause may be
 *              optionally set by macro HAL_ASSERT_SET_SUBCAUSE(subCause) prior
 *              to asserting the cause it describes. More information is
 *              available in hal_assert.h.
 * input parameters
 * @param       assertCause    - Assert cause as defined in hal_assert.h.
 * @param       assertSubcause - Optional assert subcause (see hal_assert.h).
 * output parameters
 * @param       None.
 * @return      None.
#if !defined(Display_DISABLE_ALL)
  // Open the display if the app has not already done so
  if ( !dispHandle )
    dispHandle = Display_open(Display_Type_LCD, NULL);
  Display_print0(dispHandle, 0, 0, ">>>STACK ASSERT");
#endif // ! Display_DISABLE_ALL
  // check the assert cause
  switch (assertCause)
    case HAL_ASSERT_CAUSE_OUT_OF_MEMORY:
      Display_print0(dispHandle, 0, 0, "***ERROR***");
      Display_print0(dispHandle, 2, 0, ">> OUT OF MEMORY!");
      break;
    case HAL_ASSERT_CAUSE_INTERNAL_ERROR:
      // check the subcause
      if (assertSubcause == HAL_ASSERT_SUBCAUSE_FW_INERNAL_ERROR)
        Display_print0(dispHandle, 2, 0, ">> INTERNAL FW ERROR!");
      else
        Display_print0(dispHandle, 2, 0, ">> INTERNAL ERROR!");
      break;
    case HAL_ASSERT_CAUSE_ICALL_ABORT:
      Display_print0(dispHandle, 2, 0, ">> ICALL ABORT!");
      HAL_ASSERT_SPINLOCK;
      break;
    case HAL_ASSERT_CAUSE_ICALL_TIMEOUT:
      Display_print0(dispHandle, 2, 0, ">> ICALL TIMEOUT!");
      break;
    case HAL_ASSERT_CAUSE_WRONG_API_CALL:
      Display_print0(dispHandle, 2, 0, ">> WRONG API CALL!");
      break;
  default:
      Display_print0(dispHandle, 2, 0, ">> DEFAULT SPINLOCK!");
  return;
 * @fn          smallErrorHook
 * @brief       Error handler to be hooked into TI-RTOS.
 * input parameters
 * @param       eb - Pointer to Error Block.
 * output parameters
 * @param       None.
 * @return      None.
void smallErrorHook(Error_Block *eb)
  for (;;);
#if defined (CC1350_LAUNCHXL) && defined (POWER_SAVING)
 * @fn          rFSwitchNotifyCb
 * @brief       Power driver callback to toggle RF switch on Power state
 *              transitions.
 * input parameters
 * @param   eventType - The state change.
 * @param   eventArg  - Not used.
 * @param   clientArg - Not used.
 * @return  Power_NOTIFYDONE to indicate success.
  if (eventType == PowerCC26XX_ENTERING_STANDBY)
    // Power down RF Switch
    PIN_setOutputValue(radCtrlHandle, Board_DIO30_SWPWR, 0);
  else if (eventType == PowerCC26XX_AWAKE_STANDBY)
    // Power up RF Switch
    PIN_setOutputValue(radCtrlHandle, Board_DIO30_SWPWR, 1);
  // Notification handled successfully
  return Power_NOTIFYDONE;
#endif //CC1350_LAUNCHXL || POWER_SAVING
 @file  simple_peripheral.c
 @brief This file contains the Simple Peripheral sample application for use
        with the CC2650 Bluetooth Low Energy Protocol Stack.
 Group: WCS, BTS
 are met:
 * INCLUDES
#include <string.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Queue.h>
#if defined( USE_FPGA ) || defined( DEBUG_SW_TRACE )
#include <driverlib/ioc.h>
#endif // USE_FPGA | DEBUG_SW_TRACE
#include <icall.h>
#include "util.h"
#include "att_rsp.h"
/* This Header file contains all BLE API and icall structure definition */
#include "icall_ble_api.h"
#include "devinfoservice.h"
#include "simple_gatt_profile.h"
#include "ll_common.h"
#ifdef USE_RCOSC
#include "rcosc_calibration.h"
#endif //USE_RCOSC
#include "board_key.h"
#include "board.h"
#include <xdc/runtime/Log.h>   // For Log_warning1("Warning number #%d", 4); things
#include <xdc/runtime/Diags.h> // For Log_print0(Diags_USER1, "hello"); things.
 * CONSTANTS
// Advertising interval when device is discoverable (units of 625us, 160=100ms)
#define DEFAULT_ADVERTISING_INTERVAL          160
// General discoverable mode: advertise indefinitely
#define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_GENERAL
// Minimum connection interval (units of 1.25ms, 80=100ms) for automatic
// parameter update request
#define DEFAULT_DESIRED_MIN_CONN_INTERVAL     80
// Maximum connection interval (units of 1.25ms, 800=1000ms) for automatic
#define DEFAULT_DESIRED_MAX_CONN_INTERVAL     800
// Slave latency to use for automatic parameter update request
#define DEFAULT_DESIRED_SLAVE_LATENCY         0
// Supervision timeout value (units of 10ms, 1000=10s) for automatic parameter
// update request
#define DEFAULT_DESIRED_CONN_TIMEOUT          1000
// After the connection is formed, the peripheral waits until the central
// device asks for its preferred connection parameters
#define DEFAULT_ENABLE_UPDATE_REQUEST         GAPROLE_LINK_PARAM_UPDATE_WAIT_REMOTE_PARAMS
// Connection Pause Peripheral time value (in seconds)
#define DEFAULT_CONN_PAUSE_PERIPHERAL         6
// How often to perform periodic event (in msec)
#define SBP_PERIODIC_EVT_PERIOD               5000
// Application specific event ID for HCI Connection Event End Events
#define SBP_HCI_CONN_EVT_END_EVT              0x0001
// Type of Display to open
  #if defined(BOARD_DISPLAY_USE_LCD) && (BOARD_DISPLAY_USE_LCD!=0)
    #define SBP_DISPLAY_TYPE Display_Type_LCD
  #elif defined (BOARD_DISPLAY_USE_UART) && (BOARD_DISPLAY_USE_UART!=0)
    #define SBP_DISPLAY_TYPE Display_Type_UART
  #else // !BOARD_DISPLAY_USE_LCD && !BOARD_DISPLAY_USE_UART
    #define SBP_DISPLAY_TYPE 0 // Option not supported
  #endif // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
#else // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
  #define SBP_DISPLAY_TYPE 0 // No Display
#endif // !Display_DISABLE_ALL
// Task configuration
#define SBP_TASK_PRIORITY                     1
#ifndef SBP_TASK_STACK_SIZE
#define SBP_TASK_STACK_SIZE                   644
#endif
// Application events
#define SBP_STATE_CHANGE_EVT                  0x0001
#define SBP_CHAR_CHANGE_EVT                   0x0002
#define SBP_PAIRING_STATE_EVT                 0x0004
#define SBP_PASSCODE_NEEDED_EVT               0x0008
#define SBP_CONN_EVT                          0x0010
// Internal Events for RTOS application
#define SBP_ICALL_EVT                         ICALL_MSG_EVENT_ID // Event_Id_31
#define SBP_QUEUE_EVT                         UTIL_QUEUE_EVENT_ID // Event_Id_30
#define SBP_PERIODIC_EVT                      Event_Id_00
// Bitwise OR of all events to pend on
#define SBP_ALL_EVENTS                        (SBP_ICALL_EVT        | \
                                               SBP_QUEUE_EVT        | \
                                               SBP_PERIODIC_EVT)
// Set the register cause to the registration bit-mask
#define CONNECTION_EVENT_REGISTER_BIT_SET(RegisterCause) (connectionEventRegisterCauseBitMap |= RegisterCause )
// Remove the register cause from the registration bit-mask
#define CONNECTION_EVENT_REGISTER_BIT_REMOVE(RegisterCause) (connectionEventRegisterCauseBitMap &= (~RegisterCause) )
// Gets whether the current App is registered to the receive connection events
#define CONNECTION_EVENT_IS_REGISTERED (connectionEventRegisterCauseBitMap > 0)
// Gets whether the RegisterCause was registered to recieve connection event
#define CONNECTION_EVENT_REGISTRATION_CAUSE(RegisterCause) (connectionEventRegisterCauseBitMap & RegisterCause )
 * TYPEDEFS
// App event passed from profiles.
typedef struct
  appEvtHdr_t hdr;  // event header.
  uint8_t *pData;  // event data
} sbpEvt_t;
 * GLOBAL VARIABLES
// Display Interface
Display_Handle dispHandle = NULL;
 * LOCAL VARIABLES
// Entity ID globally used to check for source and/or destination of messages
static ICall_EntityID selfEntity;
// Event globally used to post local events and pend on system and
// local events.
static ICall_SyncHandle syncEvent;
// Clock instances for internal periodic events.
static Clock_Struct periodicClock;
// Queue object used for app messages
static Queue_Struct appMsg;
static Queue_Handle appMsgQueue;
Task_Struct sbpTask;
Char sbpTaskStack[SBP_TASK_STACK_SIZE];
// Scan response data (max size = 31 bytes)
static uint8_t scanRspData[] =
  // complete name
  0x14,   // length of this data
  GAP_ADTYPE_LOCAL_NAME_COMPLETE,
  'S',
  'i',
  'm',
  'p',
  'l',
  'e',
  'B',
  'L',
  'E',
  'P',
  'e',
  'r',
  'i',
  'p',
  'h',
  'e',
  'r',
  'a',
  'l',
  // connection interval range
  0x05,   // length of this data
  GAP_ADTYPE_SLAVE_CONN_INTERVAL_RANGE,
  LO_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),   // 100ms
  HI_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),
  LO_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),   // 1s
  HI_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),
  // Tx power level
  0x02,   // length of this data
  GAP_ADTYPE_POWER_LEVEL,
  0       // 0dBm
// Advertisement data (max size = 31 bytes, though this is
// best kept short to conserve power while advertising)
static uint8_t advertData[] =
  // Flags: this field sets the device to use general discoverable
  // mode (advertises indefinitely) instead of general
  // discoverable mode (advertise for 30 seconds at a time)
  GAP_ADTYPE_FLAGS,
  DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
  // service UUID, to notify central devices what services are included
  // in this peripheral
  0x03,   // length of this data
  GAP_ADTYPE_16BIT_MORE,      // some of the UUID's, but not all
  LO_UINT16(SIMPLEPROFILE_SERV_UUID),
  HI_UINT16(SIMPLEPROFILE_SERV_UUID)
// GAP GATT Attributes
static uint8_t attDeviceName[GAP_DEVICE_NAME_LEN] = "Simple Peripheral";
 * LOCAL FUNCTIONS
static void SimplePeripheral_init( void );
static void SimplePeripheral_taskFxn(UArg a0, UArg a1);
static uint8_t SimplePeripheral_processStackMsg(ICall_Hdr *pMsg);
static uint8_t SimplePeripheral_processGATTMsg(gattMsgEvent_t *pMsg);
static void SimplePeripheral_processAppMsg(sbpEvt_t *pMsg);
static void SimplePeripheral_processStateChangeEvt(gaprole_States_t newState);
static void SimplePeripheral_processCharValueChangeEvt(uint8_t paramID);
static void SimplePeripheral_performPeriodicTask(void);
static void SimplePeripheral_clockHandler(UArg arg);
static void SimplePeripheral_passcodeCB(uint8_t *deviceAddr, uint16_t connHandle,
                                           uint8_t uiInputs, uint8_t uiOutputs);
static void SimplePeripheral_pairStateCB(uint16_t connHandle, uint8_t state,
                                         uint8_t status);
static void SimplePeripheral_processPairState(uint8_t state, uint8_t status);
static void SimplePeripheral_processPasscode(uint8_t uiOutputs);
static void SimplePeripheral_stateChangeCB(gaprole_States_t newState);
static void SimplePeripheral_charValueChangeCB(uint8_t paramID);
static uint8_t SimplePeripheral_enqueueMsg(uint8_t event, uint8_t state,
                                              uint8_t *pData);
static void SimplePeripheral_connEvtCB(Gap_ConnEventRpt_t *pReport);
static void SimplePeripheral_processConnEvt(Gap_ConnEventRpt_t *pReport);
 * EXTERN FUNCTIONS
 * PROFILE CALLBACKS
// Peripheral GAPRole Callbacks
static gapRolesCBs_t SimplePeripheral_gapRoleCBs =
  SimplePeripheral_stateChangeCB     // GAPRole State Change Callbacks
// GAP Bond Manager Callbacks
// These are set to NULL since they are not needed. The application
// is set up to only perform justworks pairing.
static gapBondCBs_t simplePeripheral_BondMgrCBs =
  (pfnPasscodeCB_t) SimplePeripheral_passcodeCB, // Passcode callback
  SimplePeripheral_pairStateCB                   // Pairing / Bonding state Callback
// Simple GATT Profile Callbacks
static simpleProfileCBs_t SimplePeripheral_simpleProfileCBs =
  SimplePeripheral_charValueChangeCB // Simple GATT Characteristic value change callback
 * PUBLIC FUNCTIONS
 * The following typedef and global handle the registration to connection event
typedef enum
   NOT_REGISTER       = 0,
   FOR_AOA_SCAN       = 1,
   FOR_ATT_RSP        = 2,
   FOR_AOA_SEND       = 4,
   FOR_TOF_SEND       = 8
}connectionEventRegisterCause_u;
// Handle the registration and un-registration for the connection event, since only one can be registered.
uint32_t       connectionEventRegisterCauseBitMap = NOT_REGISTER; //see connectionEventRegisterCause_u
 * @fn      SimplePeripheral_RegistertToAllConnectionEvent()
 * @brief   register to receive connection events for all the connection
 * @param connectionEventRegisterCause represents the reason for registration
 * @return @ref SUCCESS
bStatus_t SimplePeripheral_RegistertToAllConnectionEvent (connectionEventRegisterCause_u connectionEventRegisterCause)
  bStatus_t status = SUCCESS;
  // in case  there is no registration for the connection event, make the registration
  if (!CONNECTION_EVENT_IS_REGISTERED)
    status = GAP_RegisterConnEventCb(SimplePeripheral_connEvtCB, GAP_CB_REGISTER, LINKDB_CONNHANDLE_ALL);
  if(status == SUCCESS)
    //add the reason bit to the bitamap.
    CONNECTION_EVENT_REGISTER_BIT_SET(connectionEventRegisterCause);
  return(status);
 * @fn      SimplePeripheral_UnRegistertToAllConnectionEvent()
 * @brief   Unregister connection events
bStatus_t SimplePeripheral_UnRegistertToAllConnectionEvent (connectionEventRegisterCause_u connectionEventRegisterCause)
  CONNECTION_EVENT_REGISTER_BIT_REMOVE(connectionEventRegisterCause);
  // in case  there is no more registration for the connection event than unregister
    GAP_RegisterConnEventCb(SimplePeripheral_connEvtCB, GAP_CB_UNREGISTER, LINKDB_CONNHANDLE_ALL);
  return(status);
 * @fn      SimplePeripheral_createTask
 * @brief   Task creation function for the Simple Peripheral.
 * @param   None.
 * @return  None.
void SimplePeripheral_createTask(void)
  Task_Params taskParams;
  // Configure task
  Task_Params_init(&taskParams);
  taskParams.stack = sbpTaskStack;
  taskParams.stackSize = SBP_TASK_STACK_SIZE;
  taskParams.priority = SBP_TASK_PRIORITY;
  Task_construct(&sbpTask, SimplePeripheral_taskFxn, &taskParams, NULL);
 * @fn      SimplePeripheral_init
 * @brief   Called during initialization and contains application
 *          specific initialization (ie. hardware initialization/setup,
 *          table initialization, power up notification, etc), and
 *          profile initialization/setup.
 * @param   None.
 * @return  None.
static void SimplePeripheral_init(void)
  // N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
  // Register the current thread as an ICall dispatcher application
  // so that the application can send and receive messages.
  ICall_registerApp(&selfEntity, &syncEvent);
#ifdef USE_RCOSC
  RCOSC_enableCalibration();
#endif // USE_RCOSC
  // configure RF Core SMI Data Link
  IOCPortConfigureSet(IOID_12, IOC_PORT_RFC_GPO0, IOC_STD_OUTPUT);
  IOCPortConfigureSet(IOID_11, IOC_PORT_RFC_GPI0, IOC_STD_INPUT);
  // configure RF Core SMI Command Link
  IOCPortConfigureSet(IOID_10, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_OUT, IOC_STD_OUTPUT);
  IOCPortConfigureSet(IOID_9, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_IN, IOC_STD_INPUT);
  // configure RF Core tracer IO
  IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT);
#else // !USE_FPGA
  #if defined( DEBUG_SW_TRACE )
    IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT | IOC_CURRENT_4MA | IOC_SLEW_ENABLE);
  #endif // DEBUG_SW_TRACE
#endif // USE_FPGA
  // Create an RTOS queue for message from profile to be sent to app.
  appMsgQueue = Util_constructQueue(&appMsg);
  // Create one-shot clocks for internal periodic events.
  Util_constructClock(&periodicClock, SimplePeripheral_clockHandler,
                      SBP_PERIODIC_EVT_PERIOD, 0, false, SBP_PERIODIC_EVT);
  dispHandle = Display_open(SBP_DISPLAY_TYPE, NULL);
  // Set GAP Parameters: After a connection was established, delay in seconds
  // before sending when GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE,...)
  // uses GAPROLE_LINK_PARAM_UPDATE_INITIATE_BOTH_PARAMS or
  // GAPROLE_LINK_PARAM_UPDATE_INITIATE_APP_PARAMS
  // For current defaults, this has no effect.
  GAP_SetParamValue(TGAP_CONN_PAUSE_PERIPHERAL, DEFAULT_CONN_PAUSE_PERIPHERAL);
  // Start the Device:
  // Please Notice that in case of wanting to use the GAPRole_SetParameter
  // function with GAPROLE_IRK or GAPROLE_SRK parameter - Perform
  // these function calls before the GAPRole_StartDevice use.
  // (because Both cases are updating the gapRole_IRK & gapRole_SRK variables).
  VOID GAPRole_StartDevice(&SimplePeripheral_gapRoleCBs);
  // Setup the Peripheral GAPRole Profile. For more information see the User's
  // Guide:
  // software-dl.ti.com/.../
    // Device starts advertising upon initialization of GAP
    uint8_t initialAdvertEnable = TRUE;
    // By setting this to zero, the device will go into the waiting state after
    // being discoverable for 30.72 second, and will not being advertising again
    // until re-enabled by the application
    uint16_t advertOffTime = 0;
    uint8_t enableUpdateRequest = DEFAULT_ENABLE_UPDATE_REQUEST;
    uint16_t desiredMinInterval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
    uint16_t desiredMaxInterval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
    uint16_t desiredSlaveLatency = DEFAULT_DESIRED_SLAVE_LATENCY;
    uint16_t desiredConnTimeout = DEFAULT_DESIRED_CONN_TIMEOUT;
    // Set the Peripheral GAPRole Parameters
    GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t),
                         &initialAdvertEnable);
    GAPRole_SetParameter(GAPROLE_ADVERT_OFF_TIME, sizeof(uint16_t),
                         &advertOffTime);
    GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData),
                         scanRspData);
    GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
    GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE, sizeof(uint8_t),
                         &enableUpdateRequest);
    GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t),
                         &desiredMinInterval);
    GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t),
                         &desiredMaxInterval);
    GAPRole_SetParameter(GAPROLE_SLAVE_LATENCY, sizeof(uint16_t),
                         &desiredSlaveLatency);
    GAPRole_SetParameter(GAPROLE_TIMEOUT_MULTIPLIER, sizeof(uint16_t),
                         &desiredConnTimeout);
  // Set the Device Name characteristic in the GAP GATT Service
  // For more information, see the section in the User's Guide:
  // software-dl.ti.com/.../html
  GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
  // Set GAP Parameters to set the advertising interval
  // For more information, see the GAP section of the User's Guide:
    // Use the same interval for general and limited advertising.
    // Note that only general advertising will occur based on the above configuration
    uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
    GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MIN, advInt);
    GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MAX, advInt);
    GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MIN, advInt);
    GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MAX, advInt);
  // Setup the GAP Bond Manager. For more information see the section in the
  // User's Guide:
    // Don't send a pairing request after connecting; the peer device must
    // initiate pairing
    uint8_t pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
    // Use authenticated pairing: require passcode.
    uint8_t mitm = TRUE;
    // This device only has display capabilities. Therefore, it will display the
    // passcode during pairing. However, since the default passcode is being
    // used, there is no need to display anything.
    uint8_t ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
    // Request bonding (storing long-term keys for re-encryption upon subsequent
    // connections without repairing)
    uint8_t bonding = TRUE;
    // Whether to replace the least recently used entry when bond list is full,
    // and a new device is bonded.
    // Alternative is pairing succeeds but bonding fails, unless application has
    // manually erased at least one bond.
    uint8_t replaceBonds = FALSE;
    GAPBondMgr_SetParameter(GAPBOND_PAIRING_MODE, sizeof(uint8_t), &pairMode);
    GAPBondMgr_SetParameter(GAPBOND_MITM_PROTECTION, sizeof(uint8_t), &mitm);
    GAPBondMgr_SetParameter(GAPBOND_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
    GAPBondMgr_SetParameter(GAPBOND_BONDING_ENABLED, sizeof(uint8_t), &bonding);
    GAPBondMgr_SetParameter(GAPBOND_LRU_BOND_REPLACEMENT, sizeof(uint8_t), &replaceBonds);
  // Initialize GATT attributes
  GGS_AddService(GATT_ALL_SERVICES);           // GAP GATT Service
  GATTServApp_AddService(GATT_ALL_SERVICES);   // GATT Service
  DevInfo_AddService();                        // Device Information Service
  SimpleProfile_AddService(GATT_ALL_SERVICES); // Simple GATT Profile
  // Setup the SimpleProfile Characteristic Values
  // For more information, see the sections in the User's Guide:
    uint8_t charValue1 = 1;
    uint8_t charValue2 = 2;
    uint8_t charValue3 = 3;
    uint8_t charValue4 = 4;
    uint8_t charValue5[SIMPLEPROFILE_CHAR5_LEN] = { 1, 2, 3, 4, 5 };
    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1, sizeof(uint8_t),
                               &charValue1);
    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR2, sizeof(uint8_t),
                               &charValue2);
    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR3, sizeof(uint8_t),
                               &charValue3);
    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR4, sizeof(uint8_t),
                               &charValue4);
    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN,
                               charValue5);
  // Register callback with SimpleGATTprofile
  SimpleProfile_RegisterAppCBs(&SimplePeripheral_simpleProfileCBs);
  // Start Bond Manager and register callback
  VOID GAPBondMgr_Register(&simplePeripheral_BondMgrCBs);
  // Register with GAP for HCI/Host messages. This is needed to receive HCI
  // events. For more information, see the section in the User's Guide:
  GAP_RegisterForMsgs(selfEntity);
  // Register for GATT local events and ATT Responses pending for transmission
  GATT_RegisterForMsgs(selfEntity);
  //Set default values for Data Length Extension
    //Set initial values to maximum, RX is set to max. by default(251 octets, 2120us)
    #define APP_SUGGESTED_PDU_SIZE 251 //default is 27 octets(TX)
    #define APP_SUGGESTED_TX_TIME 2120 //default is 328us(TX)
    //This API is documented in hci.h
    //See the LE Data Length Extension section in the BLE-Stack User's Guide for information on using this command:
    //software-dl.ti.com/.../index.html
    //HCI_LE_WriteSuggestedDefaultDataLenCmd(APP_SUGGESTED_PDU_SIZE, APP_SUGGESTED_TX_TIME);
#if !defined (USE_LL_CONN_PARAM_UPDATE)
  // Get the currently set local supported LE features
  // The HCI will generate an HCI event that will get received in the main
  // loop
  HCI_LE_ReadLocalSupportedFeaturesCmd();
#endif // !defined (USE_LL_CONN_PARAM_UPDATE)
  Display_print0(dispHandle, 0, 0, "BLE Peripheral");
 * @fn      SimplePeripheral_taskFxn
 * @brief   Application task entry point for the Simple Peripheral.
 * @param   a0, a1 - not used.
 * @return  None.
  // Initialize application
  SimplePeripheral_init();
  // Application main loop
  for (;;)
      Log_info0("Hello world via Log_info0");
    uint32_t events;
    // Waits for an event to be posted associated with the calling thread.
    // Note that an event associated with a thread is posted when a
    // message is queued to the message receive queue of the thread
    events = Event_pend(syncEvent, Event_Id_NONE, SBP_ALL_EVENTS,
                        ICALL_TIMEOUT_FOREVER);
    if (events)
      ICall_EntityID dest;
      ICall_ServiceEnum src;
      ICall_HciExtEvt *pMsg = NULL;
      // Fetch any available messages that might have been sent from the stack
      if (ICall_fetchServiceMsg(&src, &dest,
                                (void **)&pMsg) == ICALL_ERRNO_SUCCESS)
        uint8 safeToDealloc = TRUE;
        if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
          ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
          if (pEvt->signature != 0xffff)
            // Process inter-task message
            safeToDealloc = SimplePeripheral_processStackMsg((ICall_Hdr *)pMsg);
        if (pMsg && safeToDealloc)
          ICall_freeMsg(pMsg);
      // If RTOS queue is not empty, process app message.
      if (events & SBP_QUEUE_EVT)
        while (!Queue_empty(appMsgQueue))
          sbpEvt_t *pMsg = (sbpEvt_t *)Util_dequeueMsg(appMsgQueue);
          if (pMsg)
            // Process message.
            SimplePeripheral_processAppMsg(pMsg);
            // Free the space from the message.
            ICall_free(pMsg);
      if (events & SBP_PERIODIC_EVT)
        Util_startClock(&periodicClock);
        // Perform periodic application task
        SimplePeripheral_performPeriodicTask();
 * @fn      SimplePeripheral_processStackMsg
 * @brief   Process an incoming stack message.
 * @param   pMsg - message to process
 * @return  TRUE if safe to deallocate incoming message, FALSE otherwise.
  uint8_t safeToDealloc = TRUE;
  switch (pMsg->event)
    case GATT_MSG_EVENT:
      // Process GATT message
      safeToDealloc = SimplePeripheral_processGATTMsg((gattMsgEvent_t *)pMsg);
      break;
    case HCI_GAP_EVENT_EVENT:
        // Process HCI message
        switch(pMsg->status)
          case HCI_COMMAND_COMPLETE_EVENT_CODE:
            // Process HCI Command Complete Event
              // This code will disable the use of the LL_CONNECTION_PARAM_REQ
              // control procedure (for connection parameter updates, the
              // L2CAP Connection Parameter Update procedure will be used
              // instead). To re-enable the LL_CONNECTION_PARAM_REQ control
              // procedures, define the symbol USE_LL_CONN_PARAM_UPDATE
              // The L2CAP Connection Parameter Update procedure is used to
              // support a delta between the minimum and maximum connection
              // intervals required by some iOS devices.
              // Parse Command Complete Event for opcode and status
              hciEvt_CmdComplete_t* command_complete = (hciEvt_CmdComplete_t*) pMsg;
              uint8_t   pktStatus = command_complete->pReturnParam[0];
              //find which command this command complete is for
              switch (command_complete->cmdOpcode)
                case HCI_LE_READ_LOCAL_SUPPORTED_FEATURES:
                    if (pktStatus == SUCCESS)
                      uint8_t featSet[8];
                      // Get current feature set from received event (bits 1-9
                      // of the returned data
                      memcpy( featSet, &command_complete->pReturnParam[1], 8 );
                      // Clear bit 1 of byte 0 of feature set to disable LL
                      // Connection Parameter Updates
                      CLR_FEATURE_FLAG( featSet[0], LL_FEATURE_CONN_PARAMS_REQ );
                      // Update controller with modified features
                      HCI_EXT_SetLocalSupportedFeaturesCmd( featSet );
                  break;
                default:
                  //do nothing
                  break;
            break;
          case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
            AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
            break;
          default:
            break;
      break;
      default:
        // do nothing
        break;
  return (safeToDealloc);
 * @fn      SimplePeripheral_processGATTMsg
 * @brief   Process GATT messages and events.
  // See if GATT server was unable to transmit an ATT response
  if (attRsp_isAttRsp(pMsg))
    // No HCI buffer was available. Let's try to retransmit the response
    // on the next connection event.
    if( SimplePeripheral_RegistertToAllConnectionEvent(FOR_ATT_RSP) == SUCCESS)
      // Don't free the response message yet
      return (FALSE);
  else if (pMsg->method == ATT_FLOW_CTRL_VIOLATED_EVENT)
    // ATT request-response or indication-confirmation flow control is
    // violated. All subsequent ATT requests or indications will be dropped.
    // The app is informed in case it wants to drop the connection.
    // Display the opcode of the message that caused the violation.
    Display_print1(dispHandle, 5, 0, "FC Violated: %d", pMsg->msg.flowCtrlEvt.opcode);
  else if (pMsg->method == ATT_MTU_UPDATED_EVENT)
    // MTU size updated
    Display_print1(dispHandle, 5, 0, "MTU Size: %d", pMsg->msg.mtuEvt.MTU);
  // Free message payload. Needed only for ATT Protocol messages
  GATT_bm_free(&pMsg->msg, pMsg->method);
  // It's safe to free the incoming message
  return (TRUE);
 * @fn      SimplePeripheral_processConnEvt
 * @brief   Process connection event.
 * @param pReport pointer to connection event report
  if( CONNECTION_EVENT_REGISTRATION_CAUSE(FOR_ATT_RSP))
    // The GATT server might have returned a blePending as it was trying
    // to process an ATT Response. Now that we finished with this
    // connection event, let's try sending any remaining ATT Responses
    // Try to retransmit pending ATT Response (if any)
    if (attRsp_sendAttRsp() == SUCCESS)
        // Disable connection event end notice
        SimplePeripheral_UnRegistertToAllConnectionEvent (FOR_ATT_RSP);
 * @fn      SimplePeripheral_processAppMsg
 * @brief   Process an incoming callback from a profile.
 * @return  None.
  switch (pMsg->hdr.event)
    case SBP_STATE_CHANGE_EVT:
        SimplePeripheral_processStateChangeEvt((gaprole_States_t)pMsg->
                                                hdr.state);
      break;
    case SBP_CHAR_CHANGE_EVT:
        SimplePeripheral_processCharValueChangeEvt(pMsg->hdr.state);
      break;
    // Pairing event
    case SBP_PAIRING_STATE_EVT:
        SimplePeripheral_processPairState(pMsg->hdr.state, *pMsg->pData);
        ICall_free(pMsg->pData);
        break;
    // Passcode event
    case SBP_PASSCODE_NEEDED_EVT:
        SimplePeripheral_processPasscode(*pMsg->pData);
        break;
	case SBP_CONN_EVT:
        SimplePeripheral_processConnEvt((Gap_ConnEventRpt_t *)(pMsg->pData));
        break;
    default:
      // Do nothing.
      break;
 * @fn      SimplePeripheral_stateChangeCB
 * @brief   Callback from GAP Role indicating a role state change.
 * @param   newState - new state
 * @return  None.
  SimplePeripheral_enqueueMsg(SBP_STATE_CHANGE_EVT, newState, NULL);
 * @fn      SimplePeripheral_processStateChangeEvt
 * @brief   Process a pending GAP Role state change event.
 * @return  None.
#ifdef PLUS_BROADCASTER
  static bool firstConnFlag = false;
#endif // PLUS_BROADCASTER
  switch ( newState )
    case GAPROLE_STARTED:
        uint8_t ownAddress[B_ADDR_LEN];
        uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
        GAPRole_GetParameter(GAPROLE_BD_ADDR, ownAddress);
        // use 6 bytes of device address for 8 bytes of system ID value
        systemId[0] = ownAddress[0];
        systemId[1] = ownAddress[1];
        systemId[2] = ownAddress[2];
        // set middle bytes to zero
        systemId[4] = 0x00;
        systemId[3] = 0x00;
        // shift three bytes up
        systemId[7] = ownAddress[5];
        systemId[6] = ownAddress[4];
        systemId[5] = ownAddress[3];
        DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
        // Display device address
        Display_print0(dispHandle, 1, 0, Util_convertBdAddr2Str(ownAddress));
        Display_print0(dispHandle, 2, 0, "Initialized");
      break;
    case GAPROLE_ADVERTISING:
      Display_print0(dispHandle, 2, 0, "Advertising");
      break;
    // After a connection is dropped, a device in PLUS_BROADCASTER will continue
    // sending non-connectable advertisements and shall send this change of
    // state to the application.  These are then disabled here so that sending
    // connectable advertisements can resume.
    case GAPROLE_ADVERTISING_NONCONN:
        uint8_t advertEnabled = FALSE;
        // Disable non-connectable advertising.
        GAPRole_SetParameter(GAPROLE_ADV_NONCONN_ENABLED, sizeof(uint8_t),
                           &advertEnabled);
        advertEnabled = TRUE;
        // Enabled connectable advertising.
                             &advertEnabled);
        // Reset flag for next connection.
        attRsp_freeAttRsp(bleNotConnected);
      break;
#endif //PLUS_BROADCASTER
    case GAPROLE_CONNECTED:
        linkDBInfo_t linkInfo;
        uint8_t numActive = 0;
        numActive = linkDB_NumActive();
        // Use numActive to determine the connection handle of the last
        // connection
        if ( linkDB_GetInfo( numActive - 1, &linkInfo ) == SUCCESS )
          Display_print1(dispHandle, 2, 0, "Num Conns: %d", (uint16_t)numActive);
          Display_print0(dispHandle, 3, 0, Util_convertBdAddr2Str(linkInfo.addr));
        else
          uint8_t peerAddress[B_ADDR_LEN];
          GAPRole_GetParameter(GAPROLE_CONN_BD_ADDR, peerAddress);
          Display_print0(dispHandle, 2, 0, "Connected");
          Display_print0(dispHandle, 3, 0, Util_convertBdAddr2Str(peerAddress));
          // Only turn advertising on for this state when we first connect
          // otherwise, when we go from connected_advertising back to this state
          // we will be turning advertising back on.
          if (firstConnFlag == false)
            uint8_t advertEnabled = FALSE; // Turn on Advertising
            // Disable connectable advertising.
                                 &advertEnabled);
            // Set to true for non-connectable advertising.
            // Enable non-connectable advertising.
                                 &advertEnabled);
            firstConnFlag = true;
      break;
    case GAPROLE_CONNECTED_ADV:
      Display_print0(dispHandle, 2, 0, "Connected Advertising");
      break;
    case GAPROLE_WAITING:
      Util_stopClock(&periodicClock);
      Display_print0(dispHandle, 2, 0, "Disconnected");
      // Clear remaining lines
      Display_clearLines(dispHandle, 3, 5);
      break;
    case GAPROLE_WAITING_AFTER_TIMEOUT:
      Display_print0(dispHandle, 2, 0, "Timed Out");
      break;
    case GAPROLE_ERROR:
      Display_print0(dispHandle, 2, 0, "Error");
      break;
    default:
      Display_clearLine(dispHandle, 2);
      break;
 * @fn      SimplePeripheral_charValueChangeCB
 * @brief   Callback from Simple Profile indicating a characteristic
 *          value change.
 * @param   paramID - parameter ID of the value that was changed.
 * @return  None.
  SimplePeripheral_enqueueMsg(SBP_CHAR_CHANGE_EVT, paramID, 0);
 * @fn      SimplePeripheral_processCharValueChangeEvt
 * @brief   Process a pending Simple Profile characteristic value change
 *          event.
 * @return  None.
  uint8_t newValue;
  switch(paramID)
    case SIMPLEPROFILE_CHAR1:
      SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR1, &newValue);
      Display_print1(dispHandle, 4, 0, "Char 1: %d", (uint16_t)newValue);
      break;
    case SIMPLEPROFILE_CHAR3:
      SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &newValue);
      Display_print1(dispHandle, 4, 0, "Char 3: %d", (uint16_t)newValue);
      break;
    default:
      // should not reach here!
      break;
 * @fn      SimplePeripheral_performPeriodicTask
 * @brief   Perform a periodic application task. This function gets called
 *          every five seconds (SBP_PERIODIC_EVT_PERIOD). In this example,
 *          the value of the third characteristic in the SimpleGATTProfile
 *          service is retrieved from the profile, and then copied into the
 *          value of the the fourth characteristic.
 * @param   None.
 * @return  None.
  uint8_t valueToCopy;
  // Call to retrieve the value of the third characteristic in the profile
  if (SimpleProfile_GetParameter(SIMPLEPROFILE_CHAR3, &valueToCopy) == SUCCESS)
    // Call to set that value of the fourth characteristic in the profile.
    // Note that if notifications of the fourth characteristic have been
    // enabled by a GATT client device, then a notification will be sent
    // every time this function is called.
                               &valueToCopy);
 * @fn      SimplePeripheral_pairStateCB
 * @brief   Pairing state callback.
 * @return  none
                                            uint8_t status)
  uint8_t *pData;
  // Allocate space for the event data.
  if ((pData = ICall_malloc(sizeof(uint8_t))))
    *pData = status;
    // Queue the event.
    SimplePeripheral_enqueueMsg(SBP_PAIRING_STATE_EVT, state, pData);
 * @fn      SimplePeripheral_processPairState
 * @brief   Process the new paring state.
 * @return  none
  if (state == GAPBOND_PAIRING_STATE_STARTED)
    Display_print0(dispHandle, 2, 0, "Pairing started");
  else if (state == GAPBOND_PAIRING_STATE_COMPLETE)
    if (status == SUCCESS)
      Display_print0(dispHandle, 2, 0, "Pairing success");
    else
      Display_print1(dispHandle, 2, 0, "Pairing fail: %d", status);
  else if (state == GAPBOND_PAIRING_STATE_BONDED)
      Display_print0(dispHandle, 2, 0, "Bonding success");
  else if (state == GAPBOND_PAIRING_STATE_BOND_SAVED)
      Display_print0(dispHandle, 2, 0, "Bond save success");
    else
      Display_print1(dispHandle, 2, 0, "Bond save failed: %d", status);
 * @fn      SimplePeripheral_passcodeCB
 * @brief   Passcode callback.
 * @return  none
  uint8_t *pData;
  // Allocate space for the passcode event.
    *pData = uiOutputs;
    // Enqueue the event.
    SimplePeripheral_enqueueMsg(SBP_PASSCODE_NEEDED_EVT, 0, pData);
 * @fn      SimplePeripheral_processPasscode
 * @brief   Process the Passcode request.
 * @return  none
  // This app uses a default passcode. A real-life scenario would handle all
  // pairing scenarios and likely generate this randomly.
  uint32_t passcode = B_APP_DEFAULT_PASSCODE;
  // Display passcode to user
  if (uiOutputs != 0)
    Display_print1(dispHandle, 4, 0, "Passcode: %d", passcode);
  uint16_t connectionHandle;
  GAPRole_GetParameter(GAPROLE_CONNHANDLE, &connectionHandle);
  // Send passcode response
  GAPBondMgr_PasscodeRsp(connectionHandle, SUCCESS, passcode);
 * @fn      SimplePeripheral_clockHandler
 * @brief   Handler function for clock timeouts.
 * @param   arg - event type
 * @return  None.
  // Wake up the application.
  Event_post(syncEvent, arg);
 * @fn      SimplePeripheral_connEvtCB
 * @brief   Connection event callback.
  // Enqueue the event for processing in the app context.
  if( SimplePeripheral_enqueueMsg(SBP_CONN_EVT, 0 ,(uint8_t *) pReport) == FALSE)
    ICall_free(pReport);
 * @brief   Creates a message and puts the message in RTOS queue.
 * @param   event - message event.
 * @param   state - message state.
 * @param   pData - message data pointer.
 * @return  TRUE or FALSE
                                           uint8_t *pData)
  sbpEvt_t *pMsg = ICall_malloc(sizeof(sbpEvt_t));
  // Create dynamic pointer to message.
  if (pMsg)
    pMsg->hdr.event = event;
    pMsg->hdr.state = state;
    pMsg->pData = pData;
    // Enqueue the message.
    return Util_enqueueMsg(appMsgQueue, syncEvent, (uint8_t *)pMsg);
  return FALSE;
var ROM = xdc.useModule('ti.sysbios.rom.ROM');
ROM.romName = ROM.CC2650;
var Defaults = xdc.useModule('xdc.runtime.Defaults');
var Types = xdc.useModule('xdc.runtime.Types');
var Diags = xdc.useModule('xdc.runtime.Diags');
var Error = xdc.useModule('xdc.runtime.Error');
var Main = xdc.useModule('xdc.runtime.Main');
var Memory = xdc.useModule('xdc.runtime.Memory')
var SysCallback = xdc.useModule('xdc.runtime.SysCallback');
var System = xdc.useModule('xdc.runtime.System');
var Text = xdc.useModule('xdc.runtime.Text');
var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
var Reset = xdc.useModule('xdc.runtime.Reset');
var BIOS = xdc.useModule('ti.sysbios.BIOS');
var Clock = xdc.useModule('ti.sysbios.knl.Clock');
var Task = xdc.useModule('ti.sysbios.knl.Task');
var Semaphore = xdc.useModule('ti.sysbios.knl.Semaphore');
var Hwi = xdc.useModule('ti.sysbios.hal.Hwi');
var M3Hwi = xdc.useModule('ti.sysbios.family.arm.m3.Hwi');
var Power = xdc.useModule('ti.sysbios.family.arm.cc26xx.Power');
/* Enable idle task (default). */
Task.enableIdleTask = true;
/* Idle CPU when threads blocked waiting for an interrupt */
Power.idle = true;
Power.policyFunc = Power.standbyPolicy;
/* compile out all Assert's */
Defaults.common$.diags_ASSERT = Diags.ALWAYS_OFF;
/* Don't load string names of modules on the target */
Defaults.common$.namedModule = false;
/* Allow Mod_create() and Mod_construct() but not delete() or destruct() */
Defaults.common$.memoryPolicy = Types.CREATE_POLICY;
/* Don't load diagnostic/descriptive text strings on the target */
Text.isLoaded = false;
/* Use the minimal user-supplied callback provider */
System.SupportProxy = SysCallback;
/* no exit handlers needed */
System.maxAtexitHandlers = 0;
/* main() and Hwi, Swi stack size */
Program.stack = 1024;
/* no command-line arguments main(argc, argv) needed */
Program.argSize = 0;
/* build a custom, optimized version of SYS/BIOS */
BIOS.libType = BIOS.LibType_Custom;
/* no logging - all compiled out */
BIOS.logsEnabled = false;
/* disable Asserts in SYS/BIOS code */
BIOS.assertsEnabled = false;
/* Reduce number of Task priority levels to save RAM */
Task.numPriorities = 6;
/* Set the default Task stack size - used if one is not specified */
Task.defaultStackSize = 768;
/* Don't check stacks for overflow - saves cycles (and power) and Flash */
Task.checkStackFlag = false;
/* Disable exception handling to save Flash - undo during active development */
M3Hwi.enableException = true;
M3Hwi.excHookFunc = '&myExceptionHook';
M3Hwi.excHandlerFunc = '&exceptionHandler'; /* null = default while loop function. Use e.g. "&myFxn" to use your own function. */
M3Hwi.nvicCCR.UNALIGN_TRP = 0;
M3Hwi.nvicCCR.DIV_0_TRP = 0;
/* Don't check for interrupt stack overflow during Idle loop */
Hwi.checkStackFlag = false;
/* Minimize Flash and RAM usage of Error module */
Error.raiseHook = null; /* null = default while loop function. Use e.g. "&myFxn" to your own handler function. */
Error.maxDepth = 2;
/* Set the default CPU frequency */
BIOS.cpuFreq.lo = 48000000;
/* Put reset vector at start of Flash */
M3Hwi.resetVectorAddress  = 0x0;
/* Put interrupt vector at start of RAM so interrupts can be configured at runtime */
M3Hwi.vectorTableAddress  = 0x20000000;
/* CC2650 has 50 interrupts */
M3Hwi.NUM_INTERRUPTS = 50;
/* Set heap size */
BIOS.heapSize = 1668;
var Swi = xdc.useModule('ti.sysbios.knl.Swi');
Swi.numPriorities = 6;
BIOS.swiEnabled = true;
BIOS.includeXdcRuntime = true;
/* Tasks cannot pend based on priority */
Semaphore.supportsPriority = false;
/* Change default error function -- just spin */
Error.policyFxn = Error.policySpin;
/* true:  Allow runtime creation of e.g. semaphores
 * false: Compile out reference to Memory in BIOS */
BIOS.runtimeCreatesEnabled = true;
/* Abort and exit functions -- just spin */
System.abortFxn = System.abortSpin;
System.exitFxn = System.exitSpin;
/* CC26xx Boot module */
var Boot = xdc.useModule('ti.sysbios.family.arm.cc26xx.Boot');
Boot.driverlibVersion = 2;
Boot.customerConfig = false;
//Boot.checkBackdoor = false;
/* Turn on RCOSC_HF calibration, thus enabling fast startup */
Power.calibrateRCOSC = true;
//Power.calibrateRCOSC = false;
/* 10 us tick period */
Clock.tickPeriod = 10;
// Need Text loaded for formatting of Log_info/warning/error, but not for Log_print.
Text.isLoaded = true;
// Logging
var Log = xdc.useModule('xdc.runtime.Log');
// Override error output color with ANSI codes, and use shorter (file.c:line) format.
Log.L_error =  {
    mask: Diags.STATUS,
    level: Diags.ERROR,
    msg: "\x1b[31;1mERROR:\x1b[0m (%s:%d) %$S"
Log.L_info = {
    mask: Diags.INFO,
    msg: "\x1b[32;1mINFO:\x1b[0m (%s:%d) %$S"
Log.L_warning = {
    mask: Diags.STATUS,
    level: Diags.WARNING,
    msg: "\x1b[33;1mWARNING:\x1b[0m (%s:%d) %$S"
// Pull in LoggerCallback
var LoggerCallback = xdc.useModule('xdc.runtime.LoggerCallback');
// Tell LoggerCallback to call our output function
LoggerCallback.outputFxn = "&uartLog_outputFxn";
// Tell the Idle module to add our flush() function to the idle loop (before Power)
var Idle = xdc.useModule('ti.sysbios.knl.Idle'); // Add if Idle isn't already imported.
Idle.addFunc('&uartLog_flush');
// Create a static instance of LoggerCallback and set as default Main logger
var loggerParams = new LoggerCallback.Params();
loggerParams.arg = 1;
Main.common$.logger = LoggerCallback.create(loggerParams); // Only for Main (code that's not in an rtsc module)
//Defaults.common$.logger = LoggerCallback.create(loggerParams); // Use for all log events
// Turn on USER1 logs and INFO in Main module (user code). Turn off USER2 for fun.
Main.common$.diags_USER1 = Diags.ALWAYS_ON;
Main.common$.diags_USER2 = Diags.ALWAYS_OFF;
Main.common$.diags_INFO = Diags.ALWAYS_ON;
and I get
error fatal error #1965: cannot open source file "C:/Users/Ospicon_Vietnam_1/Desktop/working_space/simple_peripheral_cc2640r2lp_app/FlashROM_StackLibrary/configPkg/package/cfg/appBLE_pem3.h. I even tried to copy appBLE_pem3.h from other project, but still stuck there
is the reference obsolete? any source I can follow?
