RTOS/CC2640R2F: How to communicate with CC2640 simultaneously with another CC2640 and my APP
Part Number: CC2640R2F
Other Parts Discussed in Thread: LAUNCHXL-CC2640R2
Tool/software: TI-RTOS
Hi everyone, I'm working with the CC2640R2F examples and everything works very well. I tested the communication between two devices with the Simple-Central and Simple-Peripheral examples and I also tested the communication of the device with my APP to turn on / off the LEDs. Now I'm thinking of something much more elaborate. Communication between APP, Simple-Peripheral (Multi Role) and Simple-Central. That is I turn on the led with my APP and I close the led with a button of my device (Simple-central). I tested the Multi-Role example, but when I connect with Simple-Central, my phone doesn't see the Multi-role. Why?
  • Because the code would toggle doWrite to FALSE after it runs first time.
  • Then? Can I to write GATT only?
  • Yes, I had told you many times.
  • I set the doWrite to TRUE and I cooment all part of code that talk of read GATT, but i sent the write only 1 times
  • I remember there’s somewhere in the code would do “doWrite=!doWrite;”. You should comment that line out.
  • Yes, it works. Sorry Yikai the last question.  I implement the SIMPLEPROFILE_CHAR1_UUID for turn on/off the led in the second device, now with SIMPLEPROFILE_CHAR3_UUID I want to turn on/off the second led in the second device. I thought so:
    else if (state == BLE_STATE_CONNECTED)
          if (keys & KEY_RIGHT)
              if (charHdl != 0 &&
                  procedureInProgress == FALSE)
                uint8_t status;
                // Do a read or write as long as no other read or write is in progress
                if (doWrite)
                  // Do a write
                  attWriteReq_t req;
                  req.pValue = GATT_bm_alloc(connHandle, ATT_WRITE_REQ, 1, NULL);
                  if ( req.pValue != NULL )
                    req.handle = charHdl;
                    req.len = 1;
                    req.pValue[0] = charVal;
                    req.sig = 0;
                    req.cmd = 0;
                    status = GATT_WriteCharValue(connHandle, &req, selfEntity);
                    if ( status != SUCCESS )
                      GATT_bm_free((gattMsg_t *)&req, ATT_WRITE_REQ);
                  else
                    status = bleMemAllocError;
               /* else
                  // Do a read
                  attReadReq_t req;
                  status = GATT_ReadCharValue(connHandle, &req, selfEntity);
                if (status == SUCCESS)
                  procedureInProgress = TRUE;
                  //doWrite = !doWrite;
          } else if(keys & KEY_LEFT) {
              if (charHdl != 0 &&
                          uint8_t status;
                          if (doWrite)
                            // Do a write
                            attWriteReq_t req;
                              req.len = 1;
                              req.pValue[0] = charVal1;
                              req.sig = 0;
                              req.cmd = 0;
                            else
                        /*  else
                            // Do a read
                            attReadReq_t req;
                           // doWrite = !doWrite;
        return;
    Then when I click on BUTTON RIGHT turn on led1 of second device and when I click on BUTTON LEFT turn on led2 of second device. Now, how can I implement the SIMPLEPROFILE_CHAR3_UUID in SimpleCentral?
  • I suppose you should use different value in req.handle (SIMPLEPROFILE_CHAR1_UUID or SIMPLEPROFILE_CHAR3_UUID) before you do GATT_WriteCharValue.
  • Then, I should to add a new charHdl? and then a new if condition for to use the button right? It's correct?
  • Yes, you can do it in this way.
  • Thanks for your answer. I write this:
              if (charHdl1 != 0 &&
                          uint8_t status;
                          if (doWrite)
                            // Do a write
                            attWriteReq_t req;
                              req.handle = charHdl1;
                              req.len = 1;
                              req.sig = 0;
                              req.cmd = 0;
                            else
    And I add a new condition for the write in SimpleCentral_processGATTMsg and SimpleCentral_processGATTDiscEvent. But not works
  • I suggest you to set breakpoint in your code and trace why it doesn't work.
  • If I put KEY_LEFT in the KEY_RIGHT cycle it doesn't work. I did a new cycle, but it doesn't work. Tips?
    if(state == BLE_STATE_CONNECTED){
    if (keys & KEY_LEFT)
    uint8_t status;
    if (doWrite)
    // Do a write
    attWriteReq_t req;
    req.len = 1;
    req.sig = 0;
    req.cmd = 0;
    else
  • In original simple_central example, "if(state == BLE_STATE_CONNECTED)..." would only be checked while KEY_RIGHT is triggered. I don't think your code will work since you shouldn't check "if (keys & KEY_LEFT)..." inside "if(state == BLE_STATE_CONNECTED)...".
  • How should i do? With the right button I have to send CHARACTERISTIC 1 and with the left button I have to send CHARACTERISTIC 3
  • yes, but how?
  • I suppose you can clone whole things inside "if (keys & KEY_RIGHT)..." to "if (keys & KEY_LEFT)..." and set req.handle to two different cases.
  • I try this but KEYS_LEFT not works. Why?
        if (state == BLE_STATE_IDLE)
          if (scanIdx == -1)
            if (!scanningStarted)
              scanningStarted = TRUE;
              scanRes = 0;
              Display_print0(dispHandle, 2, 0, "Discovering...");
              Display_print0(dispHandle, 3, 0, "");
              Display_print0(dispHandle, 4, 0, "");
              Display_print0(dispHandle, 5, 0, "");
              Display_print0(dispHandle, 6, 0, "");
              GAPCentralRole_StartDiscovery(DEFAULT_DISCOVERY_MODE,
                                            DEFAULT_DISCOVERY_ACTIVE_SCAN,
                                            DEFAULT_DISCOVERY_WHITE_LIST);
          // Connect if there is a scan result
          else
            // connect to current device in scan result
            uint8_t *peerAddr = devList[scanIdx].addr;
            uint8_t addrType = devList[scanIdx].addrType;
            state = BLE_STATE_CONNECTING;
            GAPCentralRole_EstablishLink(DEFAULT_LINK_HIGH_DUTY_CYCLE,
                                         DEFAULT_LINK_WHITE_LIST,
                                         addrType, peerAddr);
            Display_print0(dispHandle, 2, 0, "Connecting");
            Display_print0(dispHandle, 3, 0, Util_convertBdAddr2Str(peerAddr));
            Display_clearLine(dispHandle, 4);
            // Forget the scan results.
            scanRes = 0;
            scanIdx = -1;
              if (charHdl != 0 &&
                uint8_t status;
                if (doWrite)
                  // Do a write
                  attWriteReq_t req;
                    req.len = 1;
                    req.sig = 0;
                    req.cmd = 0;
                  else
        return;
      } else if(keys & KEY_LEFT){
                if (scanIdx == -1)
                    scanRes = 0;
                else
                  scanRes = 0;
                  scanIdx = -1;
                      uint8_t status;
                      if (doWrite)
                        // Do a write
                        attWriteReq_t req;
                          req.len = 1;
                          req.sig = 0;
                          req.cmd = 0;
                        else
              return;
  • Do you set breakpoint and debug what happens to your code?
  • Yes, in the second if Not enter. Here:
    uint8_t status;
    if (doWrite)
    // Do a write
    attWriteReq_t req;
    req.len = 1;
    req.sig = 0;
    req.cmd = 0;
    else
    return;
  • Since you can debug your code, I suppose you can check why it doesn’t enter if statement.
  • I ran the left button to send the character. But send the same value as the right button. These are my changes:
                PIN_setOutputValue(ledPinHandle, Board_RLED, 1);
                      uint8_t status;
                      if (doWrite)
                        // Do a write
                        attWriteReq_t req1;
                        req1.pValue = GATT_bm_alloc(connHandle, ATT_WRITE_REQ, 1, NULL);
                        if ( req1.pValue != NULL )
                          req1.handle = charHdl1;
                          req1.len = 1;
                          req1.pValue[0] = charVal1;
                          req1.sig = 0;
                          req1.cmd = 0;
                          status = GATT_WriteCharValue(connHandle, &req1, selfEntity);
                            GATT_bm_free((gattMsg_t *)&req1, ATT_WRITE_REQ);
                        else
    else if ((pMsg->method == ATT_WRITE_RSP)  ||
                    ((pMsg->method == ATT_ERROR_RSP) &&
                     (pMsg->msg.errorRsp.reqOpcode == ATT_WRITE_REQ)))
             if (pMsg->method == ATT_ERROR_RSP)
               Display_print1(dispHandle, 4, 0, "Write Error %d", pMsg->msg.errorRsp.errCode);
             else
               // After a successful write, display the value that was written and
               // increment value
                 if(charVal1==0){
                     charVal1=1;
               Display_print1(dispHandle, 4, 0, "LED2 OFF: %d", charVal1);
                 }else{
                     charVal1=0;
                     Display_print1(dispHandle, 4, 0, "LED2 ON: %d", charVal1);
             procedureInProgress = FALSE;
            req.startHandle = svcStartHdl;
            req.endHandle = svcEndHdl;
            req.type.len = ATT_BT_UUID_SIZE;
            req1.startHandle = svcStartHdl;
            req1.endHandle = svcEndHdl;
            req1.type.len = ATT_BT_UUID_SIZE;
            req.type.uuid[0] = LO_UINT16(SIMPLEPROFILE_CHAR1_UUID);
            req.type.uuid[1] = HI_UINT16(SIMPLEPROFILE_CHAR1_UUID);
            req1.type.uuid[0] = LO_UINT16(SIMPLEPROFILE_CHAR3_UUID);
            req1.type.uuid[1] = HI_UINT16(SIMPLEPROFILE_CHAR3_UUID);
  • You should make sure you use correct req1.handle and req1.pValue[0] when KEY_LEFT is triggered.
  • Yes? How do you confirm it?
  • I used req.handle and req.pValue[0] for BUTTON RIGHT
    I used req1.handle and re1.pValue[0] for BUTTON LEFT
  • The point is what are inside your req.handle/req.pValue[0] or req1.handle/re1.pValue[0] when BUTTON RIGHT or BUTTON LEFT is triggered.
  • This is my part of code:
              PIN_setOutputValue(ledPinHandle, Board_GLED, 1);
              if (charHdl != 0 &&
                uint8_t status;
                if (doWrite)
                  // Do a write
                  attWriteReq_t req;
                    req.len = 1;
                    req.sig = 0;
                    req.cmd = 0;
                  else
                      uint8_t status;
                      if (doWrite)
                        // Do a write
                        attWriteReq_t req1;
                          req1.len = 1;
                          req1.sig = 0;
                          req1.cmd = 0;
                        else
  • Again, I cannot debug your code for you. I suggest you to set a breakpoint to check what are in your req.handle/req.pValue[0] before you do write attribute.
