RTOS/CC2642R: CC2642 Custom Board File for simple_peripheral_oad_offchip
Part Number: CC2642R
Tool/software: TI-RTOS
I follow the "Creating a Custom Board File" in the BLE USER Guide, then I created the board files into /ti/simplelink_cc26x2_sdk_2_30_00_34/source/ti/boards/CC26X2R1_QRM.
Please see the attached board files in detail.
I also make the following modifications:
1. in ble5_simple_peripheral_oad_offchip_cc26x2r1lp_app_FlashROM_Release_unsecure.opt
-DBOARD_DISPLAY_USE_LCD=0
-DBOARD_DISPLAY_USE_UART=1
-DBOARD_DISPLAY_USE_UART_ANSI=1
-DCC26X2
-DCC26X2R1_QRM
-DCC26XX
-DDeviceFamily_CC26X2
-DxDisplay_DISABLE_ALL
-DICALL_EVENTS
-DICALL_JT
-DICALL_LITE
-DICALL_MAX_NUM_ENTITIES=6
-DICALL_MAX_NUM_TASKS=3
-DICALL_STACK0_ADDR
-DLED_DEBUG
-DMAX_NUM_BLE_CONNS=8
-DMAX_PDU_SIZE=251
-DPOWER_SAVING
-DSTACK_LIBRARY
-DTBM_ACTIVE_ITEMS_ONLY
-DUSE_ICALL
-DNVSSPI
2. in include Options:
${INHERITED_INCLUDE_PATH}
${COM_TI_SIMPLELINK_CC26X2_SDK_INCLUDE_PATH}
${PROJECT_ROOT}
${SRC_BLE_DIR}/controller/cc26xx/inc
${SRC_BLE_DIR}/inc
${SRC_BLE_DIR}/rom
${SRC_BLE_DIR}/common/cc26xx
${SRC_BLE_DIR}/icall/inc
${SRC_BLE_DIR}/target
${SRC_BLE_DIR}/../../../source/ti/
${SRC_BLE_COMMON_DIR}/common/cc26xx
${SRC_COMMON_DIR}/
${SRC_BLE_COMMON_DIR}/common/cc26xx/menu
${SRC_BLE_COMMON_DIR}/common/cc26xx/oad_efl_dbg
${SRC_BLE_COMMON_DIR}/boards/CC26X2R1_QRM
${SRC_BLE_COMMON_DIR}/profiles/dev_info
${SRC_BLE_COMMON_DIR}/profiles/oad/cc26xx
${SRC_BLE_COMMON_DIR}/profiles/simple_profile
${SRC_BLE_COMMON_DIR}/hal/src/target/_common
${SRC_BLE_COMMON_DIR}/hal/src/target/_common/cc26xx
${SRC_BLE_COMMON_DIR}/hal/src/inc
${SRC_BLE_COMMON_DIR}/heapmgr
${SRC_BLE_COMMON_DIR}/icall/src/inc
${SRC_BLE_COMMON_DIR}/osal/src/inc
${SRC_BLE_COMMON_DIR}/services/src/saddr
${SRC_BLE_COMMON_DIR}/services/src/sdata
${SRC_BLE_COMMON_DIR}/services/src/nv
${SRC_BLE_COMMON_DIR}/services/src/nv/cc26xx
${SRC_BLE_DIR}/../../../source/ti/devices/cc13x2_cc26x2_v1
${SRC_BLE_DIR}/../../../source/ti/drivers/nvs
${CG_TOOL_ROOT}/include
But I met the build errors:
>> Compilation failure
OAD/subdir_rules.mk:14: recipe for target 'OAD/flash_interface_ext_rtos_NVS.obj' failed
"/home/qic/ti/simplelink_cc26x2_sdk_2_30_00_34/source/ti/common/cc26xx/flash_interface/external/flash_interface_ext_rtos_NVS.c", line 52: fatal error #1965: cannot open source file "Board.h"
1 catastrophic error detected in the compilation of "/home/qic/ti/simplelink_cc26x2_sdk_2_30_00_34/source/ti/common/cc26xx/flash_interface/external/flash_interface_ext_rtos_NVS.c".
Compilation terminated.
gmake: *** [OAD/flash_interface_ext_rtos_NVS.obj] Error 1
Do you have any suggestions???
thanks.
BR
Trevor
7242.Board.h
 * Copyright (c) 2016-2018, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ====================== CC26X2R1_QRM.c ===================================
 *  This file is responsible for setting up the board specific items for the
 *  CC26X2R1_QRM board.
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
#include <ti/devices/cc13x2_cc26x2_v1/driverlib/ioc.h>
#include <ti/devices/cc13x2_cc26x2_v1/driverlib/udma.h>
#include <ti/devices/cc13x2_cc26x2_v1/inc/hw_ints.h>
#include <ti/devices/cc13x2_cc26x2_v1/inc/hw_memmap.h>
#include "CC26X2R1_QRM.h"
 *============================= I2S begin =====================================
/* Place into subsections to allow the TI linker to remove items properly */
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_SECTION(I2SCC26XX_config, ".const:I2SCC26XX_config")
#pragma DATA_SECTION(i2sCC26XXHWAttrs, ".const:i2sCC26XXHWAttrs")
#endif
#include <ti/drivers/i2s/I2SCC26XX.h>
I2SCC26XX_Object i2sCC26XXObject;
const I2SCC26XX_HWAttrs i2sCC26XXHWAttrs = {
    .baseAddr = I2S0_BASE,
    .intNum = INT_I2S_IRQ,
    .intPriority = ~0,
    .powerMngrId = PowerCC26XX_PERIPH_I2S,
    .mclkPin = CC26X2R1_LAUNCHXL_I2S_MCLK,
    .bclkPin = CC26X2R1_LAUNCHXL_I2S_BCLK,
    .wclkPin = CC26X2R1_LAUNCHXL_I2S_WCLK,
    .ad0Pin = CC26X2R1_LAUNCHXL_I2S_ADO,
    .ad1Pin = CC26X2R1_LAUNCHXL_I2S_ADI,
/* I2S configuration structure */
const I2SCC26XX_Config I2SCC26XX_config[] = {
        .object = &i2sCC26XXObject,
        .hwAttrs = &i2sCC26XXHWAttrs
    {NULL, NULL}
 *  =============================== ADCBuf ===============================
#include <ti/drivers/ADCBuf.h>
#include <ti/drivers/adcbuf/ADCBufCC26X2.h>
ADCBufCC26X2_Object adcBufCC26xxObjects[CC26X2R1_LAUNCHXL_ADCBUFCOUNT];
 *  This table converts a virtual adc channel into a dio and internal analogue
 *  input signal. This table is necessary for the functioning of the adcBuf
 *  driver. Comment out unused entries to save flash. Dio and internal signal
 *  pairs are hardwired. Do not remap them in the table. You may reorder entire
 *  entries. The mapping of dio and internal signals is package dependent.
const ADCBufCC26X2_AdcChannelLutEntry ADCBufCC26X2_adcChannelLut[CC26X2R1_LAUNCHXL_ADCBUF0CHANNELCOUNT] = {
    {CC26X2R1_LAUNCHXL_DIO23_ANALOG, ADC_COMPB_IN_AUXIO7},
    {CC26X2R1_LAUNCHXL_DIO24_ANALOG, ADC_COMPB_IN_AUXIO6},
    {CC26X2R1_LAUNCHXL_DIO25_ANALOG, ADC_COMPB_IN_AUXIO5},
    {CC26X2R1_LAUNCHXL_DIO26_ANALOG, ADC_COMPB_IN_AUXIO4},
    {CC26X2R1_LAUNCHXL_DIO27_ANALOG, ADC_COMPB_IN_AUXIO3},
    {CC26X2R1_LAUNCHXL_DIO28_ANALOG, ADC_COMPB_IN_AUXIO2},
    {PIN_UNASSIGNED, ADC_COMPB_IN_AUXIO1},
    {PIN_UNASSIGNED, ADC_COMPB_IN_AUXIO0},
    {PIN_UNASSIGNED, ADC_COMPB_IN_VDDS},
    {PIN_UNASSIGNED, ADC_COMPB_IN_DCOUPL},
    {PIN_UNASSIGNED, ADC_COMPB_IN_VSS},
const ADCBufCC26X2_HWAttrs adcBufCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADCBUFCOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
        .adcChannelLut     = ADCBufCC26X2_adcChannelLut,
        .gpTimerUnit       = CC26X2R1_LAUNCHXL_GPTIMER0A,
const ADCBuf_Config ADCBuf_config[CC26X2R1_LAUNCHXL_ADCBUFCOUNT] = {
        &ADCBufCC26X2_fxnTable,
        &adcBufCC26xxObjects[CC26X2R1_LAUNCHXL_ADCBUF0],
        &adcBufCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADCBUF0]
const uint_least8_t ADCBuf_count = CC26X2R1_LAUNCHXL_ADCBUFCOUNT;
 *  =============================== ADC ===============================
#include <ti/drivers/ADC.h>
#include <ti/drivers/adc/ADCCC26XX.h>
ADCCC26XX_Object adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADCCOUNT];
const ADCCC26XX_HWAttrs adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADCCOUNT] = {
        .adcDIO              = CC26X2R1_LAUNCHXL_DIO23_ANALOG,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO7,
        .refSource           = ADCCC26XX_FIXED_REFERENCE,
        .samplingDuration    = ADCCC26XX_SAMPLING_DURATION_2P7_US,
        .inputScalingEnabled = true,
        .triggerSource       = ADCCC26XX_TRIGGER_MANUAL,
        .returnAdjustedVal   = false
        .adcDIO              = CC26X2R1_LAUNCHXL_DIO24_ANALOG,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO6,
        .adcDIO              = CC26X2R1_LAUNCHXL_DIO25_ANALOG,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO5,
        .adcDIO              = CC26X2R1_LAUNCHXL_DIO26_ANALOG,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO4,
        .adcDIO              = CC26X2R1_LAUNCHXL_DIO27_ANALOG,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO3,
        .adcDIO              = CC26X2R1_LAUNCHXL_DIO28_ANALOG,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO2,
        .adcDIO              = PIN_UNASSIGNED,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO1,
        .adcCompBInput       = ADC_COMPB_IN_AUXIO0,
        .samplingDuration    = ADCCC26XX_SAMPLING_DURATION_10P9_MS,
        .adcCompBInput       = ADC_COMPB_IN_DCOUPL,
        .adcCompBInput       = ADC_COMPB_IN_VSS,
        .adcCompBInput       = ADC_COMPB_IN_VDDS,
const ADC_Config ADC_config[CC26X2R1_LAUNCHXL_ADCCOUNT] = {
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC0], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC0]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC1], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC1]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC2], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC2]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC3], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC3]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC4], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC4]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC5], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC5]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC6], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC6]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADC7], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADC7]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADCDCOUPL], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADCDCOUPL]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADCVSS], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADCVSS]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[CC26X2R1_LAUNCHXL_ADCVDDS], &adcCC26xxHWAttrs[CC26X2R1_LAUNCHXL_ADCVDDS]},
const uint_least8_t ADC_count = CC26X2R1_LAUNCHXL_ADCCOUNT;
 *  =============================== ECDH ===============================
#include <ti/drivers/ECDH.h>
#include <ti/drivers/ecdh/ECDHCC26X2.h>
ECDHCC26X2_Object ecdhCC26X2Objects[CC26X2R1_LAUNCHXL_ECDHCOUNT];
const ECDHCC26X2_HWAttrs ecdhCC26X2HWAttrs[CC26X2R1_LAUNCHXL_ECDHCOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const ECDH_Config ECDH_config[CC26X2R1_LAUNCHXL_ECDHCOUNT] = {
         .object  = &ecdhCC26X2Objects[CC26X2R1_LAUNCHXL_ECDH0],
         .hwAttrs = &ecdhCC26X2HWAttrs[CC26X2R1_LAUNCHXL_ECDH0]
const uint_least8_t ECDH_count = CC26X2R1_LAUNCHXL_ECDHCOUNT;
 *  =============================== ECDSA ===============================
#include <ti/drivers/ECDSA.h>
#include <ti/drivers/ecdsa/ECDSACC26X2.h>
ECDSACC26X2_Object ecdsaCC26X2Objects[CC26X2R1_LAUNCHXL_ECDSACOUNT];
const ECDSACC26X2_HWAttrs ecdsaCC26X2HWAttrs[CC26X2R1_LAUNCHXL_ECDSACOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const ECDSA_Config ECDSA_config[CC26X2R1_LAUNCHXL_ECDSACOUNT] = {
         .object  = &ecdsaCC26X2Objects[CC26X2R1_LAUNCHXL_ECDSA0],
         .hwAttrs = &ecdsaCC26X2HWAttrs[CC26X2R1_LAUNCHXL_ECDSA0]
const uint_least8_t ECDSA_count = CC26X2R1_LAUNCHXL_ECDSACOUNT;
 *  =============================== ECJPAKE ===============================
#include <ti/drivers/ECJPAKE.h>
#include <ti/drivers/ecjpake/ECJPAKECC26X2.h>
ECJPAKECC26X2_Object ecjpakeCC26X2Objects[CC26X2R1_LAUNCHXL_ECJPAKECOUNT];
const ECJPAKECC26X2_HWAttrs ecjpakeCC26X2HWAttrs[CC26X2R1_LAUNCHXL_ECJPAKECOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const ECJPAKE_Config ECJPAKE_config[CC26X2R1_LAUNCHXL_ECJPAKECOUNT] = {
         .object  = &ecjpakeCC26X2Objects[CC26X2R1_LAUNCHXL_ECJPAKE0],
         .hwAttrs = &ecjpakeCC26X2HWAttrs[CC26X2R1_LAUNCHXL_ECJPAKE0]
const uint_least8_t ECJPAKE_count = CC26X2R1_LAUNCHXL_ECJPAKECOUNT;
 *  =============================== SHA2 ===============================
#include <ti/drivers/SHA2.h>
#include <ti/drivers/sha2/SHA2CC26X2.h>
SHA2CC26X2_Object sha2CC26X2Objects[CC26X2R1_LAUNCHXL_SHA2COUNT];
const SHA2CC26X2_HWAttrs sha2CC26X2HWAttrs[CC26X2R1_LAUNCHXL_SHA2COUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const SHA2_Config SHA2_config[CC26X2R1_LAUNCHXL_SHA2COUNT] = {
         .object  = &sha2CC26X2Objects[CC26X2R1_LAUNCHXL_SHA20],
         .hwAttrs = &sha2CC26X2HWAttrs[CC26X2R1_LAUNCHXL_SHA20]
const uint_least8_t SHA2_count = CC26X2R1_LAUNCHXL_SHA2COUNT;
 *  =============================== AESCCM ===============================
#include <ti/drivers/AESCCM.h>
#include <ti/drivers/aesccm/AESCCMCC26XX.h>
AESCCMCC26XX_Object aesccmCC26XXObjects[CC26X2R1_LAUNCHXL_AESCCMCOUNT];
const AESCCMCC26XX_HWAttrs aesccmCC26XXHWAttrs[CC26X2R1_LAUNCHXL_AESCCMCOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const AESCCM_Config AESCCM_config[CC26X2R1_LAUNCHXL_AESCCMCOUNT] = {
         .object  = &aesccmCC26XXObjects[CC26X2R1_LAUNCHXL_AESCCM0],
         .hwAttrs = &aesccmCC26XXHWAttrs[CC26X2R1_LAUNCHXL_AESCCM0]
const uint_least8_t AESCCM_count = CC26X2R1_LAUNCHXL_AESCCMCOUNT;
 *  =============================== AESCBC ===============================
#include <ti/drivers/AESCBC.h>
#include <ti/drivers/aescbc/AESCBCCC26XX.h>
AESCBCCC26XX_Object aescbcCC26XXObjects[CC26X2R1_LAUNCHXL_AESCBCCOUNT];
const AESCBCCC26XX_HWAttrs aescbcCC26XXHWAttrs[CC26X2R1_LAUNCHXL_AESCBCCOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const AESCBC_Config AESCBC_config[CC26X2R1_LAUNCHXL_AESCBCCOUNT] = {
         .object  = &aescbcCC26XXObjects[CC26X2R1_LAUNCHXL_AESCBC0],
         .hwAttrs = &aescbcCC26XXHWAttrs[CC26X2R1_LAUNCHXL_AESCBC0]
const uint_least8_t AESCBC_count = CC26X2R1_LAUNCHXL_AESCBCCOUNT;
 *  =============================== AESECB ===============================
#include <ti/drivers/AESECB.h>
#include <ti/drivers/aesecb/AESECBCC26XX.h>
AESECBCC26XX_Object aesecbCC26XXObjects[CC26X2R1_LAUNCHXL_AESECBCOUNT];
const AESECBCC26XX_HWAttrs aesecbCC26XXHWAttrs[CC26X2R1_LAUNCHXL_AESECBCOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const AESECB_Config AESECB_config[CC26X2R1_LAUNCHXL_AESECBCOUNT] = {
         .object  = &aesecbCC26XXObjects[CC26X2R1_LAUNCHXL_AESECB0],
         .hwAttrs = &aesecbCC26XXHWAttrs[CC26X2R1_LAUNCHXL_AESECB0]
const uint_least8_t AESECB_count = CC26X2R1_LAUNCHXL_AESECBCOUNT;
 *  =============================== TRNG ===============================
#include <ti/drivers/TRNG.h>
#include <ti/drivers/trng/TRNGCC26X2.h>
TRNGCC26X2_Object trngCC26X2Objects[CC26X2R1_LAUNCHXL_TRNGCOUNT];
const TRNGCC26X2_HWAttrs trngCC26X2HWAttrs[CC26X2R1_LAUNCHXL_TRNGCOUNT] = {
        .intPriority       = ~0,
        .swiPriority       = 0,
const TRNG_Config TRNG_config[CC26X2R1_LAUNCHXL_TRNGCOUNT] = {
         .object  = &trngCC26X2Objects[CC26X2R1_LAUNCHXL_TRNG0],
         .hwAttrs = &trngCC26X2HWAttrs[CC26X2R1_LAUNCHXL_TRNG0]
const uint_least8_t TRNG_count = CC26X2R1_LAUNCHXL_TRNGCOUNT;
 *  =============================== Display ===============================
#include <ti/display/Display.h>
#include <ti/display/DisplayUart.h>
#include <ti/display/DisplaySharp.h>
#ifndef BOARD_DISPLAY_UART_STRBUF_SIZE
#define BOARD_DISPLAY_UART_STRBUF_SIZE    128
#endif
/* This value can be changed to 96 for use with the 430BOOST-SHARP96 BoosterPack. */
#define BOARD_DISPLAY_SHARP_SIZE    128
DisplayUart_Object     displayUartObject;
DisplaySharp_Object    displaySharpObject;
static char uartStringBuf[BOARD_DISPLAY_UART_STRBUF_SIZE];
static uint_least8_t sharpDisplayBuf[BOARD_DISPLAY_SHARP_SIZE * BOARD_DISPLAY_SHARP_SIZE / 8];
const DisplayUart_HWAttrs displayUartHWAttrs = {
    .uartIdx      = CC26X2R1_LAUNCHXL_UART0,
    .baudRate     = 115200,
    .mutexTimeout = (unsigned int)(-1),
    .strBuf       = uartStringBuf,
    .strBufLen    = BOARD_DISPLAY_UART_STRBUF_SIZE,
const DisplaySharp_HWAttrsV1 displaySharpHWattrs = {
    .spiIndex    = CC26X2R1_LAUNCHXL_SPI0,
    .csPin       = CC26X2R1_LAUNCHXL_GPIO_LCD_CS,
    .powerPin    = CC26X2R1_LAUNCHXL_GPIO_LCD_POWER,
    .enablePin   = CC26X2R1_LAUNCHXL_GPIO_LCD_ENABLE,
    .pixelWidth  = BOARD_DISPLAY_SHARP_SIZE,
    .pixelHeight = BOARD_DISPLAY_SHARP_SIZE,
    .displayBuf  = sharpDisplayBuf,
#ifndef BOARD_DISPLAY_USE_UART
#define BOARD_DISPLAY_USE_UART 1
#endif
#ifndef BOARD_DISPLAY_USE_UART_ANSI
#define BOARD_DISPLAY_USE_UART_ANSI 0
#endif
#ifndef BOARD_DISPLAY_USE_LCD
#define BOARD_DISPLAY_USE_LCD 0
#endif
 * This #if/#else is needed to workaround a problem with the
 * IAR compiler. The IAR compiler doesn't like the empty array
 * initialization. (IAR Error[Pe1345])
#if (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD)
const Display_Config Display_config[] = {
#if (BOARD_DISPLAY_USE_UART)
#  if (BOARD_DISPLAY_USE_UART_ANSI)
        .fxnTablePtr = &DisplayUartAnsi_fxnTable,
#  else /* Default to minimal UART with no cursor placement */
        .fxnTablePtr = &DisplayUartMin_fxnTable,
#  endif
        .object      = &displayUartObject,
        .hwAttrs     = &displayUartHWAttrs,
#endif
#if (BOARD_DISPLAY_USE_LCD)
        .fxnTablePtr = &DisplaySharp_fxnTable,
        .object      = &displaySharpObject,
        .hwAttrs     = &displaySharpHWattrs
#endif
const uint_least8_t Display_count = sizeof(Display_config) / sizeof(Display_Config);
#else
const Display_Config *Display_config = NULL;
const uint_least8_t Display_count = 0;
#endif /* (BOARD_DISPLAY_USE_UART || BOARD_DISPLAY_USE_LCD) */
 *  =============================== GPIO ===============================
#include <ti/drivers/GPIO.h>
#include <ti/drivers/gpio/GPIOCC26XX.h>
 * Array of Pin configurations
 * NOTE: The order of the pin configurations must coincide with what was
 *       defined in CC26X2R1_LAUNCHXL.h
 * NOTE: Pins not used for interrupts should be placed at the end of the
 *       array. Callback entries can be omitted from callbacks array to
 *       reduce memory usage.
GPIO_PinConfig gpioPinConfigs[] = {
    /* Input pins */
    GPIOCC26XX_DIO_13 | GPIO_DO_NOT_CONFIG,  /* Button 0 */
    GPIOCC26XX_DIO_14 | GPIO_DO_NOT_CONFIG,  /* Button 1 */
    GPIOCC26XX_DIO_15 | GPIO_DO_NOT_CONFIG,  /* CC26X2R1_LAUNCHXL_SPI_MASTER_READY */
    GPIOCC26XX_DIO_21 | GPIO_DO_NOT_CONFIG,  /* CC26X2R1_LAUNCHXL_SPI_SLAVE_READY */
    /* Output pins */
    GPIOCC26XX_DIO_07 | GPIO_DO_NOT_CONFIG,  /* Green LED */
    GPIOCC26XX_DIO_06 | GPIO_DO_NOT_CONFIG,  /* Red LED */
    /* SPI Flash CSN */
    GPIOCC26XX_DIO_20 | GPIO_DO_NOT_CONFIG,
    /* SD CS */
    /* Sharp Display - GPIO configurations will be done in the Display files */
    GPIOCC26XX_DIO_24 | GPIO_DO_NOT_CONFIG, /* SPI chip select */
    GPIOCC26XX_DIO_22 | GPIO_DO_NOT_CONFIG, /* LCD power control */
    GPIOCC26XX_DIO_23 | GPIO_DO_NOT_CONFIG, /*LCD enable */
 * Array of callback function pointers
 *       defined in CC26X2R1_LAUNCH.h
 * NOTE: Pins not used for interrupts can be omitted from callbacks array to
 *       reduce memory usage (if placed at end of gpioPinConfigs array).
GPIO_CallbackFxn gpioCallbackFunctions[] = {
    NULL,  /* Button 0 */
    NULL,  /* Button 1 */
    NULL,  /* CC26X2R1_LAUNCHXL_SPI_MASTER_READY */
    NULL,  /* CC26X2R1_LAUNCHXL_SPI_SLAVE_READY */
const GPIOCC26XX_Config GPIOCC26XX_config = {
    .pinConfigs         = (GPIO_PinConfig *)gpioPinConfigs,
    .callbacks          = (GPIO_CallbackFxn *)gpioCallbackFunctions,
    .numberOfPinConfigs = CC26X2R1_LAUNCHXL_GPIOCOUNT,
    .numberOfCallbacks  = sizeof(gpioCallbackFunctions)/sizeof(GPIO_CallbackFxn),
    .intPriority        = (~0)
 *  =============================== GPTimer ===============================
 *  Remove unused entries to reduce flash usage both in Board.c and Board.h
#include <ti/drivers/timer/GPTimerCC26XX.h>
GPTimerCC26XX_Object gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMERCOUNT];
const GPTimerCC26XX_HWAttrs gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMERPARTSCOUNT] = {
    { .baseAddr = GPT0_BASE, .intNum = INT_GPT0A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0A, },
    { .baseAddr = GPT0_BASE, .intNum = INT_GPT0B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT0, .pinMux = GPT_PIN_0B, },
    { .baseAddr = GPT1_BASE, .intNum = INT_GPT1A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1A, },
    { .baseAddr = GPT1_BASE, .intNum = INT_GPT1B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT1, .pinMux = GPT_PIN_1B, },
    { .baseAddr = GPT2_BASE, .intNum = INT_GPT2A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2A, },
    { .baseAddr = GPT2_BASE, .intNum = INT_GPT2B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT2, .pinMux = GPT_PIN_2B, },
    { .baseAddr = GPT3_BASE, .intNum = INT_GPT3A, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3A, },
    { .baseAddr = GPT3_BASE, .intNum = INT_GPT3B, .intPriority = (~0), .powerMngrId = PowerCC26XX_PERIPH_GPT3, .pinMux = GPT_PIN_3B, },
const GPTimerCC26XX_Config GPTimerCC26XX_config[CC26X2R1_LAUNCHXL_GPTIMERPARTSCOUNT] = {
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER0], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER0A], GPT_A },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER0], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER0B], GPT_B },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER1], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER1A], GPT_A },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER1], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER1B], GPT_B },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER2], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER2A], GPT_A },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER2], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER2B], GPT_B },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER3], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER3A], GPT_A },
    { &gptimerCC26XXObjects[CC26X2R1_LAUNCHXL_GPTIMER3], &gptimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_GPTIMER3B], GPT_B },
 *  =============================== I2C ===============================
#include <ti/drivers/I2C.h>
#include <ti/drivers/i2c/I2CCC26XX.h>
I2CCC26XX_Object i2cCC26xxObjects[CC26X2R1_LAUNCHXL_I2CCOUNT];
const I2CCC26XX_HWAttrsV1 i2cCC26xxHWAttrs[CC26X2R1_LAUNCHXL_I2CCOUNT] = {
        .baseAddr    = I2C0_BASE,
        .powerMngrId = PowerCC26XX_PERIPH_I2C0,
        .intNum      = INT_I2C_IRQ,
        .intPriority = ~0,
        .swiPriority = 0,
        .sdaPin      = CC26X2R1_LAUNCHXL_I2C0_SDA0,
        .sclPin      = CC26X2R1_LAUNCHXL_I2C0_SCL0,
const I2C_Config I2C_config[CC26X2R1_LAUNCHXL_I2CCOUNT] = {
        .fxnTablePtr = &I2CCC26XX_fxnTable,
        .object      = &i2cCC26xxObjects[CC26X2R1_LAUNCHXL_I2C0],
        .hwAttrs     = &i2cCC26xxHWAttrs[CC26X2R1_LAUNCHXL_I2C0]
const uint_least8_t I2C_count = CC26X2R1_LAUNCHXL_I2CCOUNT;
 *  =============================== NVS ===============================
#include <ti/drivers/NVS.h>
#include <ti/drivers/nvs/NVSSPI25X.h>
#include <ti/drivers/nvs/NVSCC26XX.h>
#define NVS_REGIONS_BASE 0x48000
#define SECTORSIZE       0x2000
#define REGIONSIZE       (SECTORSIZE * 4)
#ifndef Board_EXCLUDE_NVS_INTERNAL_FLASH
 * Reserve flash sectors for NVS driver use by placing an uninitialized byte
 * array at the desired flash address.
 * Place uninitialized array at NVS_REGIONS_BASE
#pragma LOCATION(flashBuf, NVS_REGIONS_BASE);
#pragma NOINIT(flashBuf);
static char flashBuf[REGIONSIZE];
#elif defined(__IAR_SYSTEMS_ICC__)
static __no_init char flashBuf[REGIONSIZE] @ NVS_REGIONS_BASE;
#elif defined(__GNUC__)
 * Place the flash buffers in the .nvs section created in the gcc linker file.
 * The .nvs section enforces alignment on a sector boundary but may
 * be placed anywhere in flash memory.  If desired the .nvs section can be set
 * to a fixed address by changing the following in the gcc linker file:
 * .nvs (FIXED_FLASH_ADDR) (NOLOAD) : AT (FIXED_FLASH_ADDR) {
 *      *(.nvs)
 * } > REGION_TEXT
__attribute__ ((section (".nvs")))
#endif
/* Allocate objects for NVS Internal Regions */
NVSCC26XX_Object nvsCC26xxObjects[1];
/* Hardware attributes for NVS Internal Regions */
const NVSCC26XX_HWAttrs nvsCC26xxHWAttrs[1] = {
        .regionBase = (void *)flashBuf,
        .regionSize = REGIONSIZE,
#endif /* Board_EXCLUDE_NVS_INTERNAL_FLASH */
#ifndef Board_EXCLUDE_NVS_EXTERNAL_FLASH
#define SPISECTORSIZE    0x1000
#define SPIREGIONSIZE    (SPISECTORSIZE * 32)
#define VERIFYBUFSIZE    64
static uint8_t verifyBuf[VERIFYBUFSIZE];
/* Allocate objects for NVS External Regions */
NVSSPI25X_Object nvsSPI25XObjects[1];
/* Hardware attributes for NVS External Regions */
const NVSSPI25X_HWAttrs nvsSPI25XHWAttrs[1] = {
        .regionBaseOffset = 0,
        .regionSize = SPIREGIONSIZE,
        .sectorSize = SPISECTORSIZE,
        .verifyBuf = verifyBuf,
        .verifyBufSize = VERIFYBUFSIZE,
        .spiHandle = NULL,
        .spiIndex = 0,
        .spiBitRate = 4000000,
        .spiCsnGpioIndex = CC26X2R1_LAUNCHXL_GPIO_SPI_FLASH_CS,
#endif /* Board_EXCLUDE_NVS_EXTERNAL_FLASH */
/* NVS Region index 0 and 1 refer to NVS and NVS SPI respectively */
const NVS_Config NVS_config[CC26X2R1_LAUNCHXL_NVSCOUNT] = {
        .fxnTablePtr = &NVSCC26XX_fxnTable,
        .object = &nvsCC26xxObjects[0],
        .hwAttrs = &nvsCC26xxHWAttrs[0],
#endif
        .fxnTablePtr = &NVSSPI25X_fxnTable,
        .object = &nvsSPI25XObjects[0],
        .hwAttrs = &nvsSPI25XHWAttrs[0],
#endif
const uint_least8_t NVS_count = CC26X2R1_LAUNCHXL_NVSCOUNT;
 *  =============================== PIN ===============================
#include <ti/drivers/PIN.h>
#include <ti/drivers/pin/PINCC26XX.h>
const PIN_Config BoardGpioInitTable[] = {
#if 0
    CC26X2R1_LAUNCHXL_PIN_RLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,       /* LED initially off */
    CC26X2R1_LAUNCHXL_PIN_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,       /* LED initially off */
    CC26X2R1_LAUNCHXL_PIN_BTN1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,          /* Button is active low */
    CC26X2R1_LAUNCHXL_PIN_BTN2 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,          /* Button is active low */
    CC26X2R1_LAUNCHXL_SPI_FLASH_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MIN,  /* External flash chip select */
    CC26X2R1_LAUNCHXL_UART0_RX | PIN_INPUT_EN | PIN_PULLDOWN,                                             /* UART RX via debugger back channel */
    CC26X2R1_LAUNCHXL_UART0_TX | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL,                       /* UART TX via debugger back channel */
    CC26X2R1_LAUNCHXL_SPI0_MOSI | PIN_INPUT_EN | PIN_PULLDOWN,                                            /* SPI master out - slave in */
    CC26X2R1_LAUNCHXL_SPI0_MISO | PIN_INPUT_EN | PIN_PULLDOWN,                                            /* SPI master in - slave out */
    CC26X2R1_LAUNCHXL_SPI0_CLK | PIN_INPUT_EN | PIN_PULLDOWN,                                             /* SPI clock */
#endif
    CC26X2R1_QRM_PIN_PWR_HOLD | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    CC26X2R1_QRM_PIN_BTN_PWR | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,
    CC26X2R1_QRM_PIN_SYS_ON_DET | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_BOTHEDGES | PIN_HYSTERESIS,
    PIN_TERMINATE
const PINCC26XX_HWAttrs PINCC26XX_hwAttrs = {
    .intPriority = ~0,
    .swiPriority = 0
 *  =============================== Power ===============================
#include <ti/drivers/Power.h>
#include <ti/drivers/power/PowerCC26X2.h>
const PowerCC26X2_Config PowerCC26X2_config = {
    .policyInitFxn      = NULL,
    .policyFxn          = &PowerCC26XX_standbyPolicy,
    .calibrateFxn       = &PowerCC26XX_calibrate,
    .enablePolicy       = true,
    .calibrateRCOSC_LF  = true,
    .calibrateRCOSC_HF  = true,
 *  =============================== PWM ===============================
#include <ti/drivers/PWM.h>
#include <ti/drivers/pwm/PWMTimerCC26XX.h>
PWMTimerCC26XX_Object pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWMCOUNT];
const PWMTimerCC26XX_HwAttrs pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWMCOUNT] = {
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN0, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER0A },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN1, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER0B },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN2, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER1A },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN3, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER1B },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN4, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER2A },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN5, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER2B },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN6, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER3A },
    { .pwmPin = CC26X2R1_LAUNCHXL_PWMPIN7, .gpTimerUnit = CC26X2R1_LAUNCHXL_GPTIMER3B },
const PWM_Config PWM_config[CC26X2R1_LAUNCHXL_PWMCOUNT] = {
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM0], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM0] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM1], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM1] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM2], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM2] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM3], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM3] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM4], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM4] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM5], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM5] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM6], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM6] },
    { &PWMTimerCC26XX_fxnTable, &pwmtimerCC26xxObjects[CC26X2R1_LAUNCHXL_PWM7], &pwmtimerCC26xxHWAttrs[CC26X2R1_LAUNCHXL_PWM7] },
const uint_least8_t PWM_count = CC26X2R1_LAUNCHXL_PWMCOUNT;
 *  =============================== RF Driver ===============================
#include <ti/drivers/rf/RF.h>
const RFCC26XX_HWAttrsV2 RFCC26XX_hwAttrs = {
    .hwiPriority        = ~0,       /* Lowest HWI priority */
    .swiPriority        = 0,        /* Lowest SWI priority */
    .xoscHfAlwaysNeeded = true,     /* Keep XOSC dependency while in stanby */
    .globalCallback     = NULL,     /* No board specific callback */
    .globalEventMask    = 0         /* No events subscribed to */
 *  =============================== SD ===============================
#include <ti/drivers/SD.h>
#include <ti/drivers/sd/SDSPI.h>
SDSPI_Object sdspiObjects[CC26X2R1_LAUNCHXL_SDCOUNT];
const SDSPI_HWAttrs sdspiHWAttrs[CC26X2R1_LAUNCHXL_SDCOUNT] = {
        .spiCsGpioIndex = CC26X2R1_LAUNCHXL_SDSPI_CS
const SD_Config SD_config[CC26X2R1_LAUNCHXL_SDCOUNT] = {
        .fxnTablePtr = &SDSPI_fxnTable,
        .object = &sdspiObjects[CC26X2R1_LAUNCHXL_SDSPI0],
        .hwAttrs = &sdspiHWAttrs[CC26X2R1_LAUNCHXL_SDSPI0]
const uint_least8_t SD_count = CC26X2R1_LAUNCHXL_SDCOUNT;
 *  =============================== SPI DMA ===============================
#include <ti/drivers/SPI.h>
#include <ti/drivers/spi/SPICC26X2DMA.h>
SPICC26X2DMA_Object spiCC26X2DMAObjects[CC26X2R1_LAUNCHXL_SPICOUNT];
 * NOTE: The SPI instances below can be used by the SD driver to communicate
 * with a SD card via SPI.  The 'defaultTxBufValue' fields below are set to 0xFF
 * to satisfy the SDSPI driver requirement.
const SPICC26X2DMA_HWAttrs spiCC26X2DMAHWAttrs[CC26X2R1_LAUNCHXL_SPICOUNT] = {
        .baseAddr           = SSI0_BASE,
        .intNum             = INT_SSI0_COMB,
        .intPriority        = ~0,
        .swiPriority        = 0,
        .powerMngrId        = PowerCC26XX_PERIPH_SSI0,
        .defaultTxBufValue  = 0xFF,
        .rxChannelBitMask   = 1<<UDMA_CHAN_SSI0_RX,
        .txChannelBitMask   = 1<<UDMA_CHAN_SSI0_TX,
        .mosiPin            = CC26X2R1_LAUNCHXL_SPI0_MOSI,
        .misoPin            = CC26X2R1_LAUNCHXL_SPI0_MISO,
        .clkPin             = CC26X2R1_LAUNCHXL_SPI0_CLK,
        .csnPin             = CC26X2R1_LAUNCHXL_SPI0_CSN,
        .minDmaTransferSize = 10
        .baseAddr           = SSI1_BASE,
        .intNum             = INT_SSI1_COMB,
        .intPriority        = ~0,
        .swiPriority        = 0,
        .powerMngrId        = PowerCC26XX_PERIPH_SSI1,
        .rxChannelBitMask   = 1<<UDMA_CHAN_SSI1_RX,
        .txChannelBitMask   = 1<<UDMA_CHAN_SSI1_TX,
        .mosiPin            = CC26X2R1_LAUNCHXL_SPI1_MOSI,
        .misoPin            = CC26X2R1_LAUNCHXL_SPI1_MISO,
        .clkPin             = CC26X2R1_LAUNCHXL_SPI1_CLK,
        .csnPin             = CC26X2R1_LAUNCHXL_SPI1_CSN,
const SPI_Config SPI_config[CC26X2R1_LAUNCHXL_SPICOUNT] = {
         .fxnTablePtr = &SPICC26X2DMA_fxnTable,
         .object      = &spiCC26X2DMAObjects[CC26X2R1_LAUNCHXL_SPI0],
         .hwAttrs     = &spiCC26X2DMAHWAttrs[CC26X2R1_LAUNCHXL_SPI0]
         .object      = &spiCC26X2DMAObjects[CC26X2R1_LAUNCHXL_SPI1],
         .hwAttrs     = &spiCC26X2DMAHWAttrs[CC26X2R1_LAUNCHXL_SPI1]
const uint_least8_t SPI_count = CC26X2R1_LAUNCHXL_SPICOUNT;
 *  =============================== UART ===============================
#include <ti/drivers/UART.h>
#include <ti/drivers/uart/UARTCC26XX.h>
UARTCC26XX_Object uartCC26XXObjects[CC26X2R1_LAUNCHXL_UARTCOUNT];
uint8_t uartCC26XXRingBuffer[CC26X2R1_LAUNCHXL_UARTCOUNT][32];
const UARTCC26XX_HWAttrsV2 uartCC26XXHWAttrs[CC26X2R1_LAUNCHXL_UARTCOUNT] = {
        .baseAddr       = UART0_BASE,
        .powerMngrId    = PowerCC26XX_PERIPH_UART0,
        .intNum         = INT_UART0_COMB,
        .intPriority    = ~0,
        .swiPriority    = 0,
        .txPin          = CC26X2R1_LAUNCHXL_UART0_TX,
        .rxPin          = CC26X2R1_LAUNCHXL_UART0_RX,
        .ctsPin         = PIN_UNASSIGNED,
        .rtsPin         = PIN_UNASSIGNED,
        .ringBufPtr     = uartCC26XXRingBuffer[CC26X2R1_LAUNCHXL_UART0],
        .ringBufSize    = sizeof(uartCC26XXRingBuffer[CC26X2R1_LAUNCHXL_UART0]),
        .txIntFifoThr   = UARTCC26XX_FIFO_THRESHOLD_1_8,
        .rxIntFifoThr   = UARTCC26XX_FIFO_THRESHOLD_4_8,
        .errorFxn       = NULL
        .baseAddr       = UART1_BASE,
        .powerMngrId    = PowerCC26X2_PERIPH_UART1,
        .intNum         = INT_UART1_COMB,
        .intPriority    = ~0,
        .swiPriority    = 0,
        .txPin          = CC26X2R1_LAUNCHXL_UART1_TX,
        .rxPin          = CC26X2R1_LAUNCHXL_UART1_RX,
        .ringBufPtr     = uartCC26XXRingBuffer[CC26X2R1_LAUNCHXL_UART1],
        .ringBufSize    = sizeof(uartCC26XXRingBuffer[CC26X2R1_LAUNCHXL_UART1]),
        .errorFxn       = NULL
const UART_Config UART_config[CC26X2R1_LAUNCHXL_UARTCOUNT] = {
        .fxnTablePtr = &UARTCC26XX_fxnTable,
        .object      = &uartCC26XXObjects[CC26X2R1_LAUNCHXL_UART0],
        .hwAttrs     = &uartCC26XXHWAttrs[CC26X2R1_LAUNCHXL_UART0]
        .object      = &uartCC26XXObjects[CC26X2R1_LAUNCHXL_UART1],
        .hwAttrs     = &uartCC26XXHWAttrs[CC26X2R1_LAUNCHXL_UART1]
const uint_least8_t UART_count = CC26X2R1_LAUNCHXL_UARTCOUNT;
 *  =============================== UDMA ===============================
#include <ti/drivers/dma/UDMACC26XX.h>
UDMACC26XX_Object udmaObjects[CC26X2R1_LAUNCHXL_UDMACOUNT];
const UDMACC26XX_HWAttrs udmaHWAttrs[CC26X2R1_LAUNCHXL_UDMACOUNT] = {
        .baseAddr    = UDMA0_BASE,
        .powerMngrId = PowerCC26XX_PERIPH_UDMA,
        .intNum      = INT_DMA_ERR,
        .intPriority = ~0
const UDMACC26XX_Config UDMACC26XX_config[CC26X2R1_LAUNCHXL_UDMACOUNT] = {
         .object  = &udmaObjects[CC26X2R1_LAUNCHXL_UDMA0],
         .hwAttrs = &udmaHWAttrs[CC26X2R1_LAUNCHXL_UDMA0]
 *  =============================== Watchdog ===============================
#include <ti/drivers/Watchdog.h>
#include <ti/drivers/watchdog/WatchdogCC26XX.h>
WatchdogCC26XX_Object watchdogCC26XXObjects[CC26X2R1_LAUNCHXL_WATCHDOGCOUNT];
const WatchdogCC26XX_HWAttrs watchdogCC26XXHWAttrs[CC26X2R1_LAUNCHXL_WATCHDOGCOUNT] = {
        .baseAddr    = WDT_BASE,
        .reloadValue = 1000 /* Reload value in milliseconds */
const Watchdog_Config Watchdog_config[CC26X2R1_LAUNCHXL_WATCHDOGCOUNT] = {
        .fxnTablePtr = &WatchdogCC26XX_fxnTable,
        .object      = &watchdogCC26XXObjects[CC26X2R1_LAUNCHXL_WATCHDOG0],
        .hwAttrs     = &watchdogCC26XXHWAttrs[CC26X2R1_LAUNCHXL_WATCHDOG0]
const uint_least8_t Watchdog_count = CC26X2R1_LAUNCHXL_WATCHDOGCOUNT;
 *  Board-specific initialization function to disable external flash.
 *  This function is defined in the file CC26X2R1_LAUNCHXL_fxns.c
extern void Board_initHook(void);
 *  ======== CC26X2R1_LAUNCHXL_initGeneral ========
void CC26X2R1_LAUNCHXL_initGeneral(void)
    Power_init();
    if (PIN_init(BoardGpioInitTable) != PIN_SUCCESS) {
        /* Error with PIN_init */
        while (1);
    /* Perform board-specific initialization */
    Board_initHook();
CC26X2R1_QRM.h
