Part Number: CC2640R2F
hello all,
i am working on CC2640R2F RSM package, Ihave designed and assembled all components on PCB but While uploading the program,
i am using CC2640R2F launchpad XDS110 jtag programmer, I have connected RESET, TMS, TCK, TDI, TDO directely TO my designed PCB board ic CC2640R2F RSM.
while flashing the code i have following errors
Cortex_M3_0: GEL Output: Memory Map Initialization Complete.
Cortex_M3_0: GEL Output: Board Reset Complete.
Cortex_M3_0: Error: (Error -1170 @ 0x0) Unable to access the DAP. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 8.0.903.4)
Cortex_M3_0: Trouble Halting Target CPU: (Error -2064 @ 0x0) Unable to read device status. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 8.0.903.4)
Cortex_M3_0: Unable to determine target status after 20 attempts
Cortex_M3_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
Cortex_M3_0: Failed to write data to temporary buffer in RAM before programming device FLASH memory. addr=0x20000C00, writeLength=4096(0x1000), bufIdx=0 Error: Could not write 0x20000C00: target is not connected
Cortex_M3_0: File Loader: Memory write failed: Failed to write data to temporary buffer in RAM before programming device FLASH memory.
Cortex_M3_0: GEL: File: C:\Users\vishal\workspace_v8\TI_ble_test\empty_CC2640R2_LAUNCHXL_tirtos_ccs\Debug\empty_CC2640R2_LAUNCHXL_tirtos_ccs.out: Load failed.
what is the reason for this error?
thank you.
