RTOS/CC2650EM-5XD-RD: CC2650 5XD ADC pin mapping
Part Number: CC2650EM-5XD-RD
Other Parts Discussed in Thread: CC2650
Tool/software: TI-RTOS
I have developed CC2650 5XD Custom board.I am trying to reading ADC value at IOID_9 pin.I am getting wrong value.ADC value at IOID_9 is 835 and voltage at that pin is 2V. For same hardware by using Sensor controller studio ADC Window Monitor example i am getting correct value.I am using Simple peripheral example and i have done mapping as-
//Board.h
#define     Board_ADC0              CC2650_LAUNCHXL_ADC2
//CC2650_LAUNCHXL.h
#define Board_DIO07_ANALOG          PIN_UNASSIGNED
#define Board_DIO08_ANALOG          PIN_UNASSIGNED
#define Board_DIO09_ANALOG          IOID_9
#define Board_DIO10_ANALOG          PIN_UNASSIGNED
#define Board_DIO11_ANALOG          PIN_UNASSIGNED
#define Board_DIO12_ANALOG          PIN_UNASSIGNED
#define Board_DIO13_ANALOG          PIN_UNASSIGNED
#define Board_DIO14_ANALOG          PIN_UNASSIGNED
 *  @def    CC2650_LAUNCHXL_ADCBufName
 *  @brief  Enum of ADCs
typedef enum CC2650_LAUNCHXL_ADCBufName {
    CC2650_LAUNCHXL_ADCBuf0 = 0,
    CC2650_LAUNCHXL_ADCBufCOUNT
} CC2650_LAUNCHXL_ADCBufName;
 *  @def    CC2650_LAUNCHXL_ADCName
typedef enum CC2650_LAUNCHXL_ADCName {
    CC2650_LAUNCHXL_ADC0 = 0,
    CC2650_LAUNCHXL_ADC1,
    CC2650_LAUNCHXL_ADC2,
    CC2650_LAUNCHXL_ADC3,
    CC2650_LAUNCHXL_ADC4,
    CC2650_LAUNCHXL_ADC5,
    CC2650_LAUNCHXL_ADC6,
    CC2650_LAUNCHXL_ADC7,
    CC2650_LAUNCHXL_ADCDCOUPL,
    CC2650_LAUNCHXL_ADCVSS,
    CC2650_LAUNCHXL_ADCVDDS,
    CC2650_LAUNCHXL_ADCCOUNT
} CC2650_LAUNCHXL_ADCName;
#ifdef __cplusplus
//CC2650_LAUNCHXL.c
 *  ========================== ADCBuf begin =========================================
/* Place into subsections to allow the TI linker to remove items properly */
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_SECTION(ADCBuf_config, ".const:ADCBuf_config")
#pragma DATA_SECTION(adcBufCC26xxHWAttrs, ".const:adcBufCC26xxHWAttrs")
#pragma DATA_SECTION(ADCBufCC26XX_adcChannelLut, ".const:ADCBufCC26XX_adcChannelLut")
#endif
/* Include drivers */
#include <ti/drivers/ADCBuf.h>
#include <ti/drivers/adcbuf/ADCBufCC26XX.h>
/* ADCBuf objects */
ADCBufCC26XX_Object adcBufCC26xxObjects[CC2650_LAUNCHXL_ADCBufCOUNT];
 *  This table converts a virtual adc channel into a dio and internal analogue input signal.
 *  This table is necessary for the functioning of the adcBuf driver.
 *  Comment out unused entries to save flash.
 *  Dio and internal signal pairs are hardwired. Do not remap them in the table. You may reorder entire entries though.
 *  The mapping of dio and internal signals is package dependent.
const ADCBufCC26XX_AdcChannelLutEntry ADCBufCC26XX_adcChannelLut[] = {
    //{PIN_UNASSIGNED, ADC_COMPB_IN_VDDS},
    //{PIN_UNASSIGNED, ADC_COMPB_IN_DCOUPL},
    //{PIN_UNASSIGNED, ADC_COMPB_IN_VSS},
    //{Board_DIO07_ANALOG, ADC_COMPB_IN_AUXIO7},
    //{Board_DIO08_ANALOG, ADC_COMPB_IN_AUXIO6},
    {Board_DIO09_ANALOG, ADC_COMPB_IN_AUXIO5},
    //{Board_DIO10_ANALOG, ADC_COMPB_IN_AUXIO4},
    //{Board_DIO11_ANALOG, ADC_COMPB_IN_AUXIO3},
    //{Board_DIO12_ANALOG, ADC_COMPB_IN_AUXIO2},
    //{Board_DIO13_ANALOG, ADC_COMPB_IN_AUXIO1},
    //{Board_DIO14_ANALOG, ADC_COMPB_IN_AUXIO0},
const ADCBufCC26XX_HWAttrs adcBufCC26xxHWAttrs[CC2650_LAUNCHXL_ADCBufCOUNT] = {
        .intPriority = ~0,
        .swiPriority = 0,
        .adcChannelLut = ADCBufCC26XX_adcChannelLut,
        .gpTimerUnit = Board_GPTIMER0A,
        .gptDMAChannelMask = 1 << UDMA_CHAN_TIMER0_A,
const ADCBuf_Config ADCBuf_config[] = {
    {&ADCBufCC26XX_fxnTable, &adcBufCC26xxObjects[0], &adcBufCC26xxHWAttrs[0]},
    {NULL, NULL, NULL},
 *  ========================== ADCBuf end =========================================
 *  ========================== ADC begin =========================================
#pragma DATA_SECTION(ADC_config, ".const:ADC_config")
#pragma DATA_SECTION(adcCC26xxHWAttrs, ".const:adcCC26xxHWAttrs")
#endif
#include <ti/drivers/ADC.h>
#include <ti/drivers/adc/ADCCC26XX.h>
/* ADC objects */
ADCCC26XX_Object adcCC26xxObjects[CC2650_LAUNCHXL_ADCCOUNT];
const ADCCC26XX_HWAttrs adcCC26xxHWAttrs[CC2650_LAUNCHXL_ADCCOUNT] = {
        .adcDIO = Board_DIO07_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO7,
        .refSource = ADCCC26XX_FIXED_REFERENCE,
        .samplingDuration = ADCCC26XX_SAMPLING_DURATION_2P7_US,
        .inputScalingEnabled = true,
        .triggerSource = ADCCC26XX_TRIGGER_MANUAL
        .adcDIO = Board_DIO08_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO6,
        .adcDIO = Board_DIO09_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO5,
        .adcDIO = Board_DIO10_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO4,
        .adcDIO = Board_DIO11_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO3,
        .adcDIO = Board_DIO12_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO2,
        .adcDIO = Board_DIO13_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO1,
        .adcDIO = Board_DIO14_ANALOG,
        .adcCompBInput = ADC_COMPB_IN_AUXIO0,
        .samplingDuration = ADCCC26XX_SAMPLING_DURATION_10P9_MS,
        .adcDIO = PIN_UNASSIGNED,
        .adcCompBInput = ADC_COMPB_IN_DCOUPL,
        .adcCompBInput = ADC_COMPB_IN_VSS,
        .adcCompBInput = ADC_COMPB_IN_VDDS,
const ADC_Config ADC_config[] = {
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[0], &adcCC26xxHWAttrs[0]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[1], &adcCC26xxHWAttrs[1]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[2], &adcCC26xxHWAttrs[2]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[3], &adcCC26xxHWAttrs[3]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[4], &adcCC26xxHWAttrs[4]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[5], &adcCC26xxHWAttrs[5]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[6], &adcCC26xxHWAttrs[6]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[7], &adcCC26xxHWAttrs[7]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[8], &adcCC26xxHWAttrs[8]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[9], &adcCC26xxHWAttrs[9]},
    {&ADCCC26XX_fxnTable, &adcCC26xxObjects[10], &adcCC26xxHWAttrs[10]},
    {NULL, NULL, NULL},
 *  ========================== ADC end =========================================
//Main file
int main()
  /* Register Application callback to trap asserts raised in the Stack */
  RegisterAssertCback(AssertHandler);
  //Board_initGeneral();
  PIN_init(BoardGpioInitTable);
  Board_initADC();
 // Power_enablePolicy()
  UART_init();
  UartLog_init(UART_open(Board_UART, NULL));
//  uint16_t     i;
  ADC_Handle   adc;
  ADC_Params   params;
  int_fast16_t res;
  ADC_Params_init(&params);
  adc = ADC_open(Board_ADC0, &params);
  if (adc == NULL) {
      Log_info0("Error initializing ADC channel 0\n");
  else {
      Log_info0("ADC channel 0 initialized\n");
  /* Blocking mode conversion */
  res = ADC_convert(adc, &adcValue0);
  if (res == ADC_STATUS_SUCCESS) {
      Log_info1("ADC channel 0 convert result: %d", adcValue0);
  else {
      Log_info0("ADC channel 0 convert failed\n");
  ADC_close(adc);
//  System_printf("||");
  Log_info0("UART Logger initialized");
  // Enable iCache prefetching
  VIMSConfigure(VIMS_BASE, TRUE, TRUE);
  // Enable cache
  VIMSModeSet(VIMS_BASE, VIMS_MODE_ENABLED);
#if !defined( POWER_SAVING ) || defined( USE_FPGA )
  /* Set constraints for Standby, powerdown and idle mode */
  // PowerCC26XX_SB_DISALLOW may be redundant
  Power_setConstraint(PowerCC26XX_SB_DISALLOW);
  Power_setConstraint(PowerCC26XX_IDLE_PD_DISALLOW);
#endif // POWER_SAVING | USE_FPGA
  /* Initialize ICall module */
  ICall_init();
  /* Start tasks of external images - Priority 5 */
  ICall_createRemoteTasks();
  /* Kick off profile - Priority 3 */
  GAPRole_createTask();
  SimpleBLEPeripheral_createTask();
  /* enable interrupts and start SYS/BIOS */
  BIOS_start();
  return 0;
