Part Number: CC2564
I can use HCI_VS_Write_BD_Addr to change the public BDADDR of a CC2564 slave device. But I found that when I bond the CC2564 to a master, CC2564 will report SMP fail with
Code: Pairing Failed
Reason: Confirm Value Failed
I figured out that it's because the stack use the default public BDADDR to validate the Mconfirm received from the master. I don't think it's a expected behavior. the master and slave(CC2564) use different BDADDR for Confirm value calculation.
I have try CC2564B and CC2564C, they act the same.
Could you help?
Kevin.
