We would like to send the data to our server not the Texas instrument terminal ,if you can help
thanks
What do you mean Texas instrument terminal? Do you use BLE example on your LAUNCHXL-CC2650?
yes, project zero in cc2650 launchpad , and i need to send the data to my putty
Do you mean to output data from the application UART simulated by LAUNCHXL-CC2650?
I would assume we are referring to the following Project 0 but this already describes a PuTTY interface...
Ryan
hi
i need to send the data ( to the tcp /ip ) and i am used the putty to see this data ( came from the project 0 ) , so can I using the sensor tag APP to send this data or i can not ?
hi
I am using cc2650 launchpad ( project 0) , with the APP in IOS ( sensor tag ) to send the data to tcp/ip ( if you can help me with that )
TI doens't provide sensor tag APP source code so you might need to implement your own APP for this purpose.
