Is there a host stack available for the LAUNCHXL-CC2640R2 to support BLE 5.0 with the BLE Device Monitor GUI? The cc2640r2lp_host_test.hex image supplied with BLE Device Monitor will not successfully find our 5.0 device on scan.
Hi Joakim,
Using BTool we are able to scan and connect to our device - thank you.
Ideally for development we need a host/client that can make the connection to our device then output the BT data on the serial port for analysis/logging using Hterm or similar. Is there an available option with any of the TI dev kits that would support this?
Steve
