Part Number: CC2650MODA
Other Parts Discussed in Thread: MSP432E401Y, UNIFLASH
Hello
I am using cc2650moda and msp432e401y launch pad and xds110 debug probe.
I am debugging simple peripheral sample code in cc2650moda
I got this error.
Pls solve
Cortex_M3_0: Trouble Halting Target CPU: (Error -2064 @ 0x0) Unable to read device status. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 8.2.0.00004)
Cortex_M3_0: Unable to determine target status after 20 attempts
Cortex_M3_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
