Hi Team,
We are facing the Run time issue with TI_RTOS, when we are running the code , it automatically going Hwi Hard Fault Exception. In call stack also not showing any detailed path.
Could any one help us on this issue. We need more debug techniques and analysis on this issue, means like due to which task it's happening and what is root cause for this, In IAR where we need to check this root cause file path.
Any standard procedure to debug this type of TI_RTOS Related issues by using IAR workbench.
Here with I have attached the screen for the same.
