LAUNCHXL-CC1352R1: XDS110 on Launchpad cannot firmware upgrade
Part Number: LAUNCHXL-CC1352R1
Using CCS 9.2, XDS fails to upgrade firmware.
Enumerated using xdsdfu and put into DFU mode. When downloading the firmware, it errors out with DFU_ERR_UNSUPPORTED. Attempt to upgrade bootloader fails with the same error.
Microsoft Windows [Version 10.0.18362.418]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\ti\ccs920\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -e
USB Device Firmware Upgrade Utility
Copyright (c) 2008-2019 Texas Instruments Incorporated.  All rights reserved.
Scanning USB buses for supported XDS110 devices...
<<<< Device 0 >>>>
VID: 0x0451    PID: 0xbef3
Device Name:   XDS110 Embed with CMSIS-DAP
Version:       2.3.0.18
Manufacturer:  Texas Instruments
Serial Num:    L41006RM
Mode:          Runtime
Configuration: Standard
Found 1 device.
C:\ti\ccs920\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -v -m
<<<< Device 0 >>>>
Version:       2.3.0.18
Mode:          Runtime
Switching device into DFU mode.
<<<< Device 0 >>>>
VID: 0x1cbe    PID: 0x00ff
Device Name:   <<Unknown>>
Manufacturer:  <<Unknown>>
Serial Num:    <<Unknown>>
Mode:          DFU
Found 1 device.
C:\ti\ccs920\ccs\ccs_base\common\uscif\xds110>xdsdfu.exe -f firmware.bin -r
Downloading firmware.bin to device...
Error DFU_ERR_UNSUPPORTED (-5) reported during file download
    This issue was reported before, but this was tied to the specific versions of the tools and OS used at the time.
    I tried to reproduce this here to no avail. The output is at the end of this post.
    Could you try replacing the USB cable of your kit? It is a long shot, but I am trying to cover all scenarios.
    Was your launchpad recently purchased and did it ever work before? What marking does the top device show? Is it TM4C1294NCPDTI3?
    Rafael
    The last two xdsdfu -e commands were done between disconnecting and re-connecting the board to my host.
    C:\CCSv9_2_0\ccs\ccs_base\common\uscif\xds110>ver
    Microsoft Windows [Version 10.0.17763.740]
    C:\CCSv9_2_0\ccs\ccs_base\common\uscif\xds110>xdsdfu -e
    <<<< Device 0 >>>>
    Version:       2.3.0.11
    Serial Num:    L410063F
    Mode:          Runtime
    Found 1 device.
    C:\CCSv9_2_0\ccs\ccs_base\common\uscif\xds110>xdsdfu -m
    <<<< Device 0 >>>>
    Version:       2.3.0.11
    Mode:          Runtime
    C:\CCSv9_2_0\ccs\ccs_base\common\uscif\xds110>xdsdfu -f firmware.bin -r
    Found 0 devices.
    <<<< Device 0 >>>>
    Version:       3.0.0.5
    Mode:          Runtime
    Found 1 device.
  • This turned out to be an issue running Windows in a VM.
    CCS had issues upgrading the XDS firmware on a Windows host, but succeeded from command line.
