Compiler/CC2650: I2C Pin Configuration
Part Number: CC2650
Hi all,
We are using Bluetooth stack version 2.2 development environment for CC2650.
We are currently using pins DIO_12 and DIO_13 as SDA and SCL.
We want to use DIO_5 and DIO_6 as SDA and SCL.
How to configure and use this pins for I2C?
Ankita Tayade
  • Hi Ankita,
    If you have a look at the files in <BLE-SDK>/src/boards/<BOARD>, this is where the pin definitions and driver HW attributes are defined.
    The SDA and SCL pins for I2C are configured in <BOARD>_LAUNCHXL.c, and you can find the pin definitions Board_I2C0_SDA0 and Board_I2C0_SCL0 in the corresponding header file <BOARD>_LAUNCHXL.h.
    Vetle
