Part Number: CC2642R
Our project is to collect sensor data from SPI and log it in the SD card.
And we were planning to do select/ deselect the i2c pins whenever required. But the problem we face is - if SPI_init and SD_init are called together in a single project then neither the data collection from the sensor works nor the SD card logging. How can we work around this problem?
In the SPI_config table we have left the chip select pin to be unassigned and we are selecting/deselecting pins whenever we need in the code manually.
