Part Number: CC2642R
Hi Team,
We are getting difference between .bin and .hex files when we compile between two systems, but the code base(SDK, XDC using same versions) and IAR Settings also same across the team, the only difference is IAR IDE Version i am using the 8.32.2 version, the other one is 8.32.3.
If Tool Chain(Compiler, assembler and linker) version is same and IAR settings also same including Optimization levels, why we are getting difference in out put files.
Could anyone help me out on this issue. what are the things we need to take care if we are using the different IAR versions to get the same output generation.
Srinivas.V
