Dear TI team,
I am starting design Bluetooth board and specify size of BT board around 35mm X 50 mm and considering 2.4GHz Inverted F antenna (size 26 x 8 as http://www.ti.com/lit/an/swru120d/swru120d.pdf) and small size PCB antenna (size 15 x 6 as http://www.ti.com/lit/an/swra117d/swra117d.pdf)
Reference, I am designing follow LAUNCHXL-CC2640R2 Design (see as below)
0871.LAUNCHXL-CC2640R2_1_0_0_Schematics.pdfLAUNCHXL-CC2640R2_1_0_Assy.pdf
Could you please advise about the component that can reduce to fit in my BT board (35mm X 50 mm) ?
Note: I just use only RF circuit with antenna, other parts not use
Thank you
