Hi.
Since I don't know the power supply timing of the oscillator circuit, is it impossible to measure them?
Hi.
Hi
Sorry for the delay here:
You can use this app note to calculate startup times:
http://www.ti.com/lit/an/swra495g/swra495g.pdf?&ts=1589235474817
Thank you for your information.
Is it possible to measure the startup time, not the calculation?
BR Hiroki
Could you share measurement result of startup time(32k, 48M crystal) of launch pad.
303usec for 48MHz seems right but 32kHz seems long. I will check 32kHz and get back.
Also, you can route the 32kHz clock on the GPIO and test it.
Is this how you are measuring the 32lHz startup time?
Thanks.
