CC2652R: Crystal selection
Part Number: CC2652R
Hello team,
Since I received inquiry about Crystal Selection from our customer, I introduced Crystal selection Guide(http://www.ti.com/lit/pdf/swra495). Customer does not decide 2.4GHz solution or Sub1GHz solution yet, but, first of all, customer is trying to estimate system cost.
Customer pick up some crystals(48MHz/32.768KHz) which customer is able to get easily, while referring above document. I attached this spreadsheet(Crystal_Candicate_for_TI_Devices.xlsx). To avoid miss, customer would like to know if it’s OK or not. Could you fill in the blank in this spreadsheet, please (Yes/No) ?
I will really appreciate if Expert will be able to check this.
Miyazaki
