Hi.
I will set unused pins to output low.
Is that correct?
Or Is there any recommended unused pin treatment?
BR
Hi.
Is that correct?
Hi
Thank you for your reply.
To my knowledge the ESD performance is independent of the DIO setting. The reason for this is that a high voltage pulse has to be diverted from the buffers in the pad by the structures in the ESD protection. If the pulse reach the transistors in the buffer, damage will occur independent of the state of the buffer.
