Part Number: CC2564C
Hi Team,
My customer is using CC2564C with Linux, they encounter some compiling issues while using Linux add-on from ti.com, version v4.2.1.1.1.0.
They are using BTS file cc256xc_bt_sp_v1.4, and also BLE add-on.
Need your help, thanks.
The error info shows below:
nshao@TMO_Env:/nshao_repo/tmo/AM335xBluetopiaLinuxProduction-4.2.1.1.1.0/build$ make all
CC_S BTPMSRVR.c -o BTPMSRVR_S.o
LN BTPMSRVR_S.o libBTPM_S.a libBTPM_HAL_S.a libSS1BTAUD.a libSS1BTGAV.a libSS1BTAVC.a libSS1BTAVR.a libSS1SBC.a libSS1BTFTP.a libSS1BTHDP.a libSS1BTHDS.a libSS1BTHIDH.a libSS1BTHID.a libSS1BTPAN.a libBTPS_VNET.a libSS1BTPBA.a libSS1BTHFR.a libSS1BTMAP.a libSS1BTOPP.a libSS1BTCTS.a libSS1BTNDCS.a libSS1BTRTUS.a libSS1BTDIS.a libSS1BTGAT.a libSS1BTGAPS.a libSS1BTCSCS.a libSS1BTHIDS.a libSS1BTNDC.a libSS1BTRTU.a libSS1BTIAS.a libSS1BTHRS.a libSS1BTSCP.a libSS1BTLLS.a libSS1BTBAS.a libSS1BTTPS.a libBTPS.a libBTPS_PLA.a libBTPS_OSA.a -o SS1BTPM
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: error: ../BluetopiaPM/lib/libBTPM_S.a(BTPMMAIN_S.o) uses VFP register arguments, ../BluetopiaPM/bin/SS1BTPM does not
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: failed to merge target specific data of file ../BluetopiaPM/lib/libBTPM_S.a(BTPMMAIN_S.o)
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: error: ../BluetopiaPM/lib/libBTPM_S.a(BTPMDEVM_S.o) uses VFP register arguments, ../BluetopiaPM/bin/SS1BTPM does not
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: failed to merge target specific data of file ../BluetopiaPM/lib/libBTPM_S.a(BTPMDEVM_S.o)
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: error: ../BluetopiaPM/lib/libBTPM_S.a(DEVMGR_S.o) uses VFP register arguments, ../BluetopiaPM/bin/SS1BTPM does not
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: failed to merge target specific data of file ../BluetopiaPM/lib/libBTPM_S.a(DEVMGR_S.o)
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: error: ../BluetopiaPM/lib/libBTPM_S.a(DEVMUTIL_S.o) uses VFP register arguments, ../BluetopiaPM/bin/SS1BTPM does not
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: failed to merge target specific data of file ../BluetopiaPM/lib/libBTPM_S.a(DEVMUTIL_S.o)
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: error: ../BluetopiaPM/lib/libBTPM_S.a(BTPMSCOM_S.o) uses VFP register arguments, ../BluetopiaPM/bin/SS1BTPM does not
/nshao_repo/tmo/HB_Tools/32/toolchain/bin/../lib/gcc/arm-openwrt-linux-muslgnueabi/5.2.0/../../../../arm-openwrt-linux-muslgnueabi/bin/ld: failed to merge target specific data of file ../BluetopiaPM/lib/libBTPM_S.a(BTPMSCOM_S.o)
