I am really new in using BLE protocols and probably you can help me.. I try to create a L2CAP connection between 2 devices using Btool application. The CC2640 is flashed with host_test.
Steps:
1. I connect the devices (connection succesul)
2. Try to execute L2CAP_RegisterPSM() with different PSM values. It always fails with Status 0x01 (Failure) which is not described in functions return values in API Documentation
I copy here the send message and the response.
[21] : <Tx> - 12:21:18.675
-Type : 0x01 (Command)
-OpCode : 0xFE62 (GapInit_connect)
-Data Length : 0x0A (10) byte(s)
PeerAddrType : 0x01 (1) (PEER_ADDRTYPE_RANDOM_OR_RANDOM_ID)
PeerAddr : C2:DE:2E:9B:28:27
InitiatingPhy : 0x01 (1) (
INIT_PHY_1M)
Timeout : 0x0000 (0)
Dump(Tx):
0000:01 62 FE 0A 01 27 28 9B 2E DE C2 01 00 00 .b...'(.......
[22] : <Rx> - 12:21:18.713
-Type : 0x04 (Event)
-EventCode : 0x00FF (HCI_LE_ExtEvent)
-Data Length : 0x06 (6) bytes(s)
Event : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus)
Status : 0x00 (0) (SUCCESS)
DataLength : 0x00 (0)
Dump(Rx):
0000:04 FF 06 7F 06 00 62 FE 00 ......b..
[23] : <Rx> - 12:21:18.768
-Data Length : 0x14 (20) bytes(s)
Event : 0x0605 (1541) (GAP_EstablishLink)
DevAddrType : 0x01 (1) (ADDRTYPE_RANDOM)
DevAddr : C2:DE:2E:9B:28:27
ConnHandle : 0x0000 (0)
ConnRole : 0x08 (8) (
Central)
ConnInterval : 0x0050 (80)
ConnLatency : 0x0000 (0)
ConnTimeout : 0x07D0 (2000)
ClockAccuracy : 0x00 (0)
Dump(Rx):
0000:04 FF 14 05 06 00 01 27 28 9B 2E DE C2 00 00 08 .......'(.......
0010:50 00 00 00 D0 07 00 P......
[24] : <Tx> - 12:21:18.769
-OpCode : 0x2022 (HCI_LE_SetDataLength)
-Data Length : 0x06 (6) byte(s)
Handle : 0x0000 (0)
TxOctets : 0x00FB (251)
TxTime : 0x0848 (2120)
Dump(Tx):
0000:01 22 20 06 00 00 FB 00 48 08 ." .....H.
[25] : <Info> - 12:21:18.851
Device Connected
Handle = 0x0000
Addr Type = 0x01 (ADDRTYPE_RANDOM)
BDAddr = C2:DE:2E:9B:28:27
[26] : <Rx> - 12:21:18.822
-EventCode : 0x000E (HCI_CommandCompleteEvent)
Packets : 0x01 (1)
Handle : 0x0000 (0)
Dump(Rx):
0000:04 0E 06 01 22 20 00 00 00 ...." ...
[27] : <Rx> - 12:21:19.053
-EventCode : 0x003E (HCI_LE_GenericReportEvent)
-Data Length : 0x0C (12) bytes(s)
LE Event Code : 0x04 (4) (HCI_LE_ReadRemoteUsedFeaturesCompleteEvent)
ConnectionId : 0x0000 (0)
Features : 0x00000000000041F5 (16885) (
Encryption
Reject_Extended_Indication
Ping
Data_Packet_Length_Extension
Privacy
Extended_Scanner_Filter_Policies
PHY_2M
Channel_Selection_Algorithm_2)
Dump(Rx):
0000:04 3E 0C 04 00 00 00 F5 41 00 00 00 00 00 00 .>......A......
[28] : <Tx> - 12:21:42.989
-OpCode : 0xFCF1 (L2CAP_RegisterPsm)
PSM : 0x1001 (4097)
MTU : 0x0017 (23)
InitialPeerCrs : 0x000A (10)
PeerCrThreshld : 0x0001 (1)
MaxNumChannels : 0x01 (1)
SecurityVrfctn : 0x00 (0) (No)
Dump(Tx):
0000:01 F1 FC 0A 01 10 17 00 0A 00 01 00 01 00 ..............
[29] : <Rx> - 12:21:43.038
Status : 0x01 (1) (FAILURE)
Dump(Rx):
0000:04 FF 06 7F 06 01 F1 FC 00 .........
