We are using TI2564C chip and use HCI command to read RSSI value every second to detect device distance.
We found sometimes the RSSI value is fixed and no updated even we moved BT devices from different distances.
By the way, it also happens that during RSSI detection, the scan BT devices function sometimes doesn't work, the inquiry command is sent out successfully, but no inquiry result reported.
Would you help to check what causes these problem and how to solve them?
The log for RSSI value not change is attached.
Thank you very much.
Gao Hong
