Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
CC2564C: Code porting from CC2560B (CC2560) to CC2564..
Part Number: CC2564C
Other Parts Discussed in Thread: CC2560B, CC2560, CC2564
Hi Team BT-Classic/BLE,
I have the following customer question..
"I can certainly imagine that the answer to the question about code compatibility across silicon generations is “it depends on the code.”  Still though, I’d appreciate your input on how much effort will need to go into revising code written for the CC2560B in order to update to the CC2564C."
Is it easy?  Do we have a "code porting guide"?
Thanks, Merril
  • This should be relatively straight forward, I'll ask one of our SW experts to chime in.
    Travis
  • Hi Merrill,
    There shouldn't be any porting efforts required going from CC2560 to CC2564. Both products use the same stack and work similarly under the hood. Keep in mind our SDKs are released to support all CC256x devices. There might be some subtle changes in later SDKs but I don't believe there's anything that should require significant efforts.
    Jesu
