Part Number: LAUNCHXL-CC26X2R1
Other Parts Discussed in Thread: CC2650
I am needed to sync multiple multi-role devices with a common RTC. I am planning on developing a singular device that will act as a time server, and implement a current time profile service on it and the surrounding devices.
I have done some research and found that there is a TimeApp example code that implements the previously mentioned service, however I cannot find the code. Does it still exists and work? If anyone could link the example code I would be much appreciative.
I ideally would like to be able to connect all the devices to sync the time with the server, and have them all operate on their own RTC clocks to keep time afterwards. I would then be able to perform sensor measurements with accurate timestamps to be communicated and compared later on.
Max
