Part Number: CC2640R2F
Other Parts Discussed in Thread: LAUNCHXL-CC2640R2, FLASH-PROGRAMMER,
>Initiate access to target: COM3 using 2-pin cJTAG.
>No response from device. Device may not be in bootloader mode. Reset device and try again.
If problem persists, check connection and baud rate.
>Connecting over serial bootloader failed: No response from device. Device may not be in bootloader mode. Reset device and try again.
>Failed to create device object.
