Part Number: CC1352R
Hi!
I am running mostly the CC1352 DMM example ( I implemented a Bluetooth ZigBee bridge) I have observed high latency between the time when Bluetooth profile is updated to the time ZigBee sends data (~300-450ms), moreover if writing to Bluetooth faster (ex 3-4 times per second) the Bluetooth looses packets and does not update accordingly (I suppose that the stack is busy processing the ZigBee commands).
Is this a normal behavior or I am doing something wrong? Also is there anything that can be done to mitigate this problem?
Thank you!
