CC2640: How can I fill the .snvsectors to 0x00 rather than 0xFF ?
Part Number: CC2640
Usually, we check that there is no difference between code data and flash data after programmed the cc2640 firmware to device.
We use gang s/w (Flash-Pro ARM) for programming firmware and checking.
When I compare code data and flash data, the snvsectors (0x1D000 ~ 0x1EFFF) is different like below.
I know there are no functional problems here but I don't want to see the differences.
Is there any solution for this? I tried to fill unused code memory to 0xFF in linker options of IAR like below but it didn't work.
I'm using sdk-2.2.5.
Calvin
  • Calvin,
    Thanks for your inquiry. I notified a team member and he will provide additional insights as soon as possible.
    Rafael
  • Calvin,
    This looks like a question for IAR. Have you tried contacting them?
    In any case, 0xFF is the default, erased value of flash memory. I don't recommend filling the .snvsectors in memory with zeroes, but instead filling the file with 0xFF.
    -Luis
