do you share the VDD vs. current consumption curve? thanks.
BR. Albin
Hi Albin,
Can you give an example of what you are looking for? I do not see a VDD vs. Current curve in our datasheet, so it's likely we don't have it.
BR,
Vince
Hi Vince,
customer is going to calculate the battery life of the A2DP sink device.
the power supply is 1.8V. But the current number in datasheet is 3.3V.
so need the avs current consumption number under 1.8V power supply in the A2DP sink mode.
BR. Albin
Hi Albin,
This is not specified in our datasheet so I can't give you exact values. I can tell you as voltage goes down, you will increase current consumption of the device.
My suggestion for the customer is setup a demo with one of our EVMs and running A2DP Demo and measure current with V1.8.
BR,
Vince
