Part Number: LAUNCHXL-CC26X2R1
Other Parts Discussed in Thread: SYSCONFIG, , SYSBIOS
Hi folks,
I am unable to generate execution or load analysis graphs. I followed the TI-RTOS Basics tutorial to familiarize myself with the debugging tools available through CCS, deviating only from the provided source to rely on SysConfig and the empty example project (.\simplelink_cc13x2_26x2_sdk_4_30_00_54\examples\rtos\CC26X2R1_LAUNCHXL\drivers\empty\tirtos\ccs). I strongly suspect this is a user error associated with my debug.cfg, DefaultSession.usmxml, RTOS_Training.uia.xml, or RTOS_Training.syscfg files. I have included these and online references I reviewed at the end of this post. The rest of this post documents the overall project setup.
Thank you in advance for your input!
Ken (Rye)
EDIT: Fixed broken file uploads and picture uploads.
Experimental Setup
I am running Code Compositor Studio 10.1.1 on Windows 10 with the LAUNCHXL-CC26X2R1 featuring the CC2652R1F Cortex M4.
Project Overview |
Board Config |
Configuration and Results
Following the tutorial, I commented out the code in the "ROM Configuration" and uncommented the code in "Logging Configuration." I have also added the line, "var UIAProfile = xdc.useModule('ti.uia.events.UIAProfile');"
/* == ROM configuration == */ var ROM = xdc.useModule('ti.sysbios.rom.ROM'); ROM.romName = ROM.CC13X2V2; |
/* == Logging configuration == */ //var Log = xdc.useModule('xdc.runtime.Log'); var LoggingSetup = xdc.useModule('ti.uia.sysbios.LoggingSetup'); LoggingSetup.loadLoggerSize = 256; LoggingSetup.mainLoggerSize = 512; LoggingSetup.sysbiosLoggerSize = 1024; |
I cleaned the project and ensured that the secondary project, “tirtos_builds_cc13x2_cc26x2_release_ccs” was set to “Debug” rather than “Release” before building the source. I disabled all breakpoints in the code before debugging the code and opening the Execution Analysis (Tools → RTOS Analyzer → Execution Analysis/Load Analysis). I created a new UIA config with the following settings and by renaming an empty text file to RTOS_Training.uia.xml to proceed.
The Live Session for both Execution and Load Analysis fail to populate. I have tried to run program before and after hitting Play/Stop in the live session window.
I have tried a number of different settings within my debug.cfg file based on other forum posts (linked in resources below), however I fail to see any kind of LoggerStopMode resource within Runtime Object View. While exploring SysConfig, I found the following set of configuration settings that APPEAR to be doing something (as indicated by the new modules populating in ROV, but the Live Session data is still unpopulated,
My Project Resources for Review
RTOS_Training.syscfg and DedfaultSession.usmxml extensions were changed for upload compatability
| debug.cfg | 3264.debug.cfg |
RTOS_Training.syscfg (Remove.xml Extension) |
* These arguments were used when this file was generated. They will be automatically applied on subsequent loads
* via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
* @cliArgs --board "/ti/boards/CC26X2R1_LAUNCHXL" --product "simplelink_cc13x2_26x2_sdk@4.30.00.54"
* @versions {"data":"2020090214","timestamp":"2020090214","tool":"1.6.0+1543","templates":"2020090214"}
* Import the modules used in this configuration.
const Display = scripting.addModule("/ti/display/Display", {}, false);
const Display1 = Display.addInstance();
const GPIO = scripting.addModule("/ti/drivers/GPIO");
const GPIO1 = GPIO.addInstance();
const GPIO2 = GPIO.addInstance();
const RTOS = scripting.addModule("/ti/drivers/RTOS");
const LoggerITM = scripting.addModule("/ti/loggers/drivers/LoggerITM", {}, false);
const LoggerITM1 = LoggerITM.addInstance();
const ExGr_LoggerBuf = scripting.addModule("/ti/loggers/utils/ExGr_LoggerBuf");
const Bench = scripting.addModule("/ti/utils/runtime/Bench", {}, false);
const Bench1 = Bench.addInstance();
const ExGr_SYSBIOS = scripting.addModule("/ti/utils/runtime/ExGr_SYSBIOS");
const ExGr_tiutils = scripting.addModule("/ti/utils/runtime/ExGr_tiutils");
const LogMain = scripting.addModule("/ti/utils/runtime/LogMain");
const LogSite = scripting.addModule("/ti/utils/runtime/LogSite", {}, false);
const LogSite1 = LogSite.addInstance();
const LoggerText = scripting.addModule("/ti/utils/runtime/LoggerText", {}, false);
const LoggerText1 = LoggerText.addInstance();
* Write custom configuration values to the imported modules.
Display1.$name = "CONFIG_Display_0";
Display1.$hardware = system.deviceData.board.components.XDS110UART;
Display1.uart.$name = "CONFIG_UART_1";
Display1.uart.txPinInstance.$name = "CONFIG_PIN_4";
Display1.uart.rxPinInstance.$name = "CONFIG_PIN_5";
GPIO1.$hardware = system.deviceData.board.components.LED_RED;
GPIO1.$name = "CONFIG_GPIO_LED_0";
GPIO1.pinInstance.$name = "CONFIG_PIN_0";
GPIO2.$hardware = system.deviceData.board.components.LED_GREEN;
GPIO2.$name = "CONFIG_GPIO_LED_1";
GPIO2.pinInstance.$name = "CONFIG_PIN_1";
const CCFG = scripting.addModule("/ti/devices/CCFG", {}, false);
CCFG.ccfgTemplate.$name = "ti_devices_CCFGTemplate0";
LoggerITM1.$name = "CONFIG_ti_loggers_drivers_LoggerITM_0";
const ITM = scripting.addModule("/ti/drivers/ITM", {}, false);
ITM.swoPinInstance.$name = "CONFIG_PIN_2";
ExGr_LoggerBuf.ExecGraphLogger.$name = "Config_ExecGraphLogger_0";
Bench1.$name = "CONFIG_Bench_0";
const ExGr_XDCtools = scripting.addModule("/ti/utils/runtime/ExGr_XDCtools", {}, false);
ExGr_XDCtools.ExecGraphLogger_xdctools.$name = "Config_ExecGraphLogger_1";
ExGr_tiutils.ExecGraphLogger_utils.$name = "Config_ExecGraphLogger_2";
ExGr_tiutils.ExecGraphLogger_drivers.$name = "Config_ExecGraphLogger_3";
LogSite1.$name = "ti_utils_runtime_LogSite_0";
const LoggerBuf = scripting.addModule("/ti/loggers/utils/LoggerBuf", {}, false);
const LoggerBuf1 = LoggerBuf.addInstance({}, false);
LoggerBuf1.$name = "CONFIG_ti_loggers_utils_LoggerBuf_0";
LogSite1.logger = LoggerBuf1;
LogMain.LogSite.logger = LoggerBuf1;
LoggerText1.$name = "CONFIG_ti_utils_runtime_LoggerText_0";
* Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
* version of the tool will not impact the pinmux you originally saw. These lines can be completely deleted in order to
* re-solve from scratch.
Display1.uart.uart.$suggestSolution = "UART1";
Display1.uart.uart.txPin.$suggestSolution = "boosterpack.4";
Display1.uart.uart.rxPin.$suggestSolution = "boosterpack.3";
GPIO1.gpioPin.$suggestSolution = "boosterpack.39";
GPIO2.gpioPin.$suggestSolution = "boosterpack.40";
ITM.swoPin.$suggestSolution = "boosterpack.29";
DefaultSession.usmxml (Remove.xml Extension) |
<?xml version="1.0" encoding="UTF-8"?>
<java version="1.8.0_144" class="java.beans.XMLDecoder">
<object class="com.ti.uia.host.core.Session$Config" id="Session$Config0">
<void property="endpoints">
<void method="add">
<object class="com.ti.uia.host.core.Session$Config$Endpoint">
<void property="clockFreq">
<long>48000000</long>
</void>
<void property="eventTransport">
<object class="com.ti.uia.host.core.Session$Config$Transport">
<void property="type">
<string>JTAG</string>
</void>
</object>
</void>
<void property="name">
<string>Cortex_M4_0</string>
</void>
<void property="outFile">
<string>C:\Users\rRye\Texas Instruments Projects\Tutorial_RTOS\RTOS_Training\Debug\RTOS_Training.out</string>
</void>
<void property="rtaFile">
<string>C:/Users/rRye/Texas Instruments Projects/Tutorial_RTOS/tirtos_builds_cc13x2_cc26x2_release_ccs/Debug/configPkg/package/cfg/release_pem4f.rta.xml</string>
</void>
<void property="uiaFile">
<string>C:\Users\rRye\Texas Instruments Projects\Tutorial_RTOS\RTOS_Training\analysis\RTOS_Training.uia.xml</string>
</void>
</object>
</void>
</void>
<object class="com.ti.uia.host.core.Session$Config$Transport" id="Session$Config$Transport0">
<string>None</string>
</void>
</object>
</void>
<void property="msgTransport">
</void>
</object>
</void>
</object>
<void class="com.ti.uia.host.core.Session$Config$Transport" id="Field0" method="getField">
<string>customProperties</string>
<void id="Properties0" method="get">
<object idref="Session$Config$Transport0"/>
<void method="put">
<string>Address</string>
<string>localhost</string>
</void>
<void method="put">
<string>Port</string>
<int>8080</int>
</void>
</void>
</void>
<void idref="Properties0"/>
</java>
| RTOS_Training.uia.xml | Empty FIle |
Online Resources:
- TI-RTOS Basics
- Kernel Configuration
- System Analyzer User Guide (See Section 3.x)
- System Analyzer Tutorials (See Important Notes, See Tutorial 1: How to Run the System Analyzer Tutorial 1 Project)
- module ti.uia.events.UIAProfile
- module ti.uia.sysbios.LoggingSetup
- CCS/TMS320F28377S: ROV Execution Analysis Configuration
- UIA Product Installation and Inclusion
- CCS/CC2640R2F: How to use Execution Analysis with simple_peripheral project?
- Example CFG File and Configuration tutorial, tried a remix of these settings.
- Execution Graph Gaps due to Data Loss and Log Start Control
- Another example CFG File, tried a remix of these settings.
- Inspecting the ROV for Live Session Logging Data
