Here is a step by step guide to use the GPTimer with NORTOS.
- Open CCS
- Import the example C:\ti\simplelink_cc2640r2_sdk_4_30_00_08\examples\nortos\CC2640R2_LAUNCHXL\drivers\gpiointerrupt\ccs
- Open the file gpiointerrupt.c
Replace the code in gpiointerrupt.c with:
/* * Copyright (c) 2015-2019, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ #include <stdint.h> #include <stddef.h> #include <unistd.h> /* Driver Header files */ #include <ti/drivers/GPIO.h> #include <ti/drivers/timer/GPTimerCC26XX.h> /* Example/Board Header files */ #include "Board.h" GPTimerCC26XX_Handle hTimer; /* * ======== timerCallback ======== * Callback function for the timer interrupt */ void timerCallback(GPTimerCC26XX_Handle handle, GPTimerCC26XX_IntMask interruptMask) { // interrupt callback code goes here. Minimize processing in interrupt. GPIO_toggle(Board_GPIO_LED0); } /* * ======== mainThread ======== */ void *mainThread(void *arg0) { GPTimerCC26XX_Params params; GPTimerCC26XX_Params_init(¶ms); params.width = GPT_CONFIG_16BIT; params.mode = GPT_MODE_PERIODIC; params.direction = GPTimerCC26XX_DIRECTION_UP; params.debugStallMode = GPTimerCC26XX_DEBUG_STALL_OFF; hTimer = GPTimerCC26XX_open(CC2640R2_LAUNCHXL_GPTIMER0, ¶ms); if(hTimer == NULL) { while(1); } GPTimerCC26XX_Value loadVal = 48000000 / 1000 - 1; //48000000 (48MHz) is the frequency of the CPU GPTimerCC26XX_setLoadValue(hTimer, loadVal); GPTimerCC26XX_registerInterrupt(hTimer, timerCallback, GPT_INT_TIMEOUT); GPTimerCC26XX_start(hTimer); while(1) { usleep(50000); } return (NULL); }
4. Build and run the code on a CC2640R2F launchpad with a logic analyzer attached to DIO6 (Red Led)
This is the c file (the only one that need to be modified):
I hope this will help,
