Part Number: CC2642R
I try some examples that are scanning and advertising, I have taken this error. I changed the setting of syscfg. How can I solve this problem?
Hey Rabia,
You should use our simple_peripheral to practice scanning and advertising. This way, the include paths in the projects will already link to the appropriate files in the SDK.
I suggest going through our Simplelink Academy labs here: dev.ti.com/.../node
Hi Ammar,
Thank you so much for your answer. But I want to create a new project. And I have estimated problem that undefined path. But I don't know the solution to this problem. I tried to add a new path. For example, I have added new path on window->prefences-> general->workspace->linked resources. But it didn't work this solution.
You'll have to go into the Project>Properties>ARM Compiler>Include Options. Here you add compiler paths. You may have to do something similar with linker paths if you get any linker errors when building. This can be found in Project>Properties>ARM Linker>File Search Path.
I highly encourage you to import an example BLE project and look at the project settings there.
