CC2564C: HCI inquiry doesn't show all active BT devices
Part Number: CC2564C
Other Parts Discussed in Thread: CC256XSTBTBLESW
developing and debugging our own CC2564C based hw. Device shows only some active devices, not all of them even if half meter next to each other. To exclude sw related issue we have reworked our hw and use HCI tester tool for verification. Getting exactly same results using TIInit_6.12.26.xml library, attached configuration script and HCI_inquiry command. Only two/three devices listed, with the android phone I can see another 15 devices. RF front end and BT antenna doesn't seem to be a problem, once paired and connected in BT sink mode, operating range is about 10meters.
7485.HCITester Trace Log.htm
# Description : Orca C ROM Initialization Script
# Compatibility: Orca, 12.0.26 ROM
# Last Updated: 24-Mar-2020   8:03:16.31
# Version     : 12_26.23
# Notes       : Use this script on Orca C, 12.0.26 ROM device only (FW v12.0.26)
## START of CC256x Add-On
## Change UART baudrate
Send_HCI_VS_Update_Uart_HCI_Baudrate 0xFF36, 0x0001c200
Wait_HCI_Command_Complete_VS_Update_Uart_HCI_Baudrate_Event 5000, 0x01, 0xff36, 0x00
Com_SetParams 115200, 1
## END of CC256x Add-On
Send_HCI_VS_Start_VS_Lock 0xFE37, 0x0c, 0x1a
Wait_HCI_Command_Complete_VS_Start_VS_Lock_Event 5000, any, 0xfe37, 0x00
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000865d0, 0xfa, "0C:1A:09:17:01:6A:C8:7B:00:02:89:7B:01:43:09:48:51:30:02:88:06:48:91:42:03:D1:04:49:09:78:01:29:01:D0:5D:30:F7:46:FF:30:D8:30:F7:46:76:24:08:00:BD:28:02:00:69:53:08:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:B5:00:69:FF:21:02:31:09:5C:09:29:05:D1:01:21:00:22:8E:46:6D:4B:FE:44:18:47:00:BD:6C:4A:11:88:01:20:40:03:08:43:10:80:F7:46:30:B5:00:69:F4:21:08:5C:01:28:16:D1:EA:48:00:78:03:28:12:D0:00:25:28:1C:E8:49:01:24:A6:46:E7:4A:FE:44:10:47:00:28:08:D0"
Wait_HCI_Command_Complete_VS_Write_Memory_Block_Event 5000, any, 0xff05, 0x00
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000866ca, 0xfa, "E6:49:E6:4A:BB:32:20:20:2B:1C:A6:46:E5:4C:FE:44:20:47:30:BD:70:B5:85:69:00:7D:80:1F:11:D0:47:38:2E:D1:A9:79:28:20:48:43:DF:4A:10:18:23:22:12:5C:01:2A:25:D1:80:7B:00:28:22:D0:DB:4A:00:20:50:54:70:BD:01:24:A6:46:D9:48:FE:44:00:47:01:28:05:D0:A6:46:D6:48:FE:44:00:47:04:28:11:D1:E8:78:00:28:0E:D1:0E:26:31:1C:D3:4D:28:1C:14:38:A6:46:D0:4A:FE:44:10:47:28:1C:31:1C:A6:46:CD:4A:FE:44:10:47:70:BD:70:B5:01:1C:88:69:89:8A:CB:4A:89:1A:1C:D0:1C:39:20:D1:C5:7A:01:21:0C:1C:8E:46:C8:4A:FE:44:10:47:06:1C:10:20:A6:46:C6:49:FE:44:08:47:00:2D:11:D0:02:2E:0F:D0:C3:49:C4:4A:D9:32:20:20:00:23:A6:46:B7:4C:FE:44:20:47:70:BD:C0:7A:00:28:02:D1:00:20:BE:49:08:70:70:BD:00:B5:00:69:FF:21:04:31:09:5C:06:29:06:D1:FF:21:05:31:0A:5C:2C:2A:01:D1:2D:22:0A:54:FF:21:05:31:09:5C"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000867c4, 0xfa, "34:29:11:D1:FF:21:0B:31:09:5C:91:29:0C:D1:F1:21:09:5C:60:22:4A:43:EB:4B:00:21:99:54:06:21:01:22:96:46:E9:4A:FE:44:10:47:00:BD:F0:B5:06:1C:F7:69:08:20:C0:19:01:24:A6:46:E4:49:FE:44:08:47:C1:7B:09:02:80:7B:08:43:05:04:2D:0C:02:2D:12:D0:EF:48:00:88:A8:42:0E:D1:EE:48:00:78:01:28:0A:D1:ED:48:82:8F:81:6B:08:1C:10:43:04:D0:38:1C:A6:46:EA:4B:FE:44:18:47:35:60:E9:48:24:30:30:62:F0:BD:C0:46:DD:9D:00:00:3E:A6:1B:00:F0:B5:86:B0:04:90:81:69:05:91:81:8A:E2:48:09:1A:DC:4D:00:D1:BA:E0:E1:4A:89:1A:00:D1:AF:E0:07:38:09:1A:35:D0:DE:48:09:1A:28:D0:05:39:26:D0:13:39:33:D1:DC:48:05:1C:84:3D:00:78:02:28:2D:D1:01:24:A6:46:D9:48:FE:44:00:47:00:28:26:D1:A6:46:D7:48:FE:44:00:47:00:28:20:D1:A6:46:D5:48:FE:44:00:47:00:28:1A:D1:28:78:00:28:17:D1:A8:78:00:28:14:D1:A6:20"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000868be, 0xfa, "A6:46:CF:49:FE:44:08:47:C4:E0:05:98:81:88:41:18:08:7C:02:28:00:DA:BD:E0:80:1E:08:74:BA:E0:51:3D:28:78:2A:28:02:D0:33:28:00:D0:B3:E0:0E:21:05:98:0F:18:44:20:0C:21:1A:22:01:24:A6:46:C2:4B:FE:44:18:47:C1:4E:B1:78:F2:78:C1:48:A6:46:C1:4B:FE:44:18:47:06:21:05:98:81:80:28:78:BF:4D:2A:28:26:D0:0A:26:3E:70:01:37:38:1C:00:21:A6:46:BA:4A:FE:44:10:47:07:1C:3E:70:01:37:38:1C:0D:21:A6:46:B5:4A:FE:44:10:47:07:1C:A6:46:B5:48:FE:44:00:47:81:02:AE:48:C0:78:40:06:40:0E:08:43:05:43:29:04:09:0C:38:1C:A6:46:AC:4A:FE:44:10:47:08:26:24:E0:08:26:3E:70:01:37:38:1C:00:21:A6:46:A6:4A:FE:44:10:47:07:1C:3E:70:01:37:38:1C:0D:21:A6:46:A2:4A:FE:44:10:47:07:1C:A6:46:A1:48:FE:44:00:47:81:02:9A:48:C0:78:40:06:40:0E:08:43:05:43:29:04:09:0C:38:1C:A6:46:98:4A:FE:44:10:47:05:98"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x000869b8, 0xfa, "46:80:FF:21:02:31:00:22:A6:46:ED:4B:FE:44:18:47:3F:E0:EC:49:00:20:08:70:08:74:EB:49:08:70:3C:E0:05:98:00:21:6A:46:01:24:A6:46:E8:4B:FE:44:18:47:02:A8:00:21:06:22:A6:46:E5:4B:FE:44:18:47:00:26:02:E0:70:1C:06:04:36:0C:28:1C:4F:38:00:78:86:42:23:DA:11:20:40:01:70:43:EA:49:0F:18:10:20:C0:19:69:46:A6:46:E8:4A:FE:44:10:47:00:28:E9:D1:68:46:02:A9:A6:46:E4:4A:FE:44:10:47:00:28:E1:D0:B8:78:01:28:DE:D0:05:98:69:49:3A:22:A6:46:DF:4B:FE:44:18:47:EC:49:E2:31:04:98:01:62:06:B0:F0:BD:C0:46:18:32:08:00:CE:04:00:00:23:B9:02:00:65:71:08:00:FD:79:00:00:A9:70:08:00:D4:1D:08:00:94:54:08:00:8F:8D:01:00:FD:06:05:00:14:05:1A:00:A2:FD:00:00:65:2D:00:00:7D:CA:03:00:A5:71:08:00:79:47:00:00:78:24:08:00:F0:B5:07:1C:BA:69:50:78:FE:69:25:21:43:1A:E4:49:32:D0:01:3B:68:D1"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086ab2, 0xfa, "04:23:B3:80:0C:23:9D:19:40:00:12:78:02:43:2A:70:01:35:08:78:2A:28:05:D0:33:28:01:D1:0A:20:02:E0:07:20:00:E0:08:20:28:70:01:35:28:1C:0D:21:01:24:A6:46:4B:4A:FE:44:10:47:05:1C:A6:46:4B:48:FE:44:00:47:82:02:D2:48:00:78:40:06:41:0E:11:43:45:48:08:43:01:04:09:0C:28:1C:A6:46:41:4A:FE:44:10:47:2F:E0:04:23:B3:80:0C:23:9D:19:40:00:12:78:02:43:2A:70:01:35:08:78:2A:28:05:D0:33:28:01:D1:0A:20:02:E0:07:20:00:E0:08:20:28:70:01:35:28:1C:0D:21:01:24:A6:46:33:4A:FE:44:10:47:05:1C:A6:46:32:48:FE:44:00:47:82:02:B9:48:00:78:40:06:41:0E:11:43:2D:48:08:43:01:04:09:0C:28:1C:A6:46:29:4A:FE:44:10:47:06:20:70:80:03:20:30:80:E3:48:E2:49:08:18:38:62:F0:BD:C0:46:76:A0:1B:00:C5:8E:00:00:5B:19:04:00:10:B5:DE:48:00:21:01:24:A6:46:DD:4A:FE:44:10:47:DC:49:01:28:01:D0:00:20"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086bac, 0xfa, "01:E0:08:68:01:30:08:60:A6:46:D9:48:FE:44:00:47:00:28:06:D0:0B:48:00:78:02:28:02:D1:02:20:D5:49:08:80:10:BD:BA:53:08:00:90:A1:1B:00:A8:59:08:00:25:6F:04:00:79:6C:04:00:05:04:00:00:FE:07:00:00:05:10:00:00:45:10:08:00:C1:72:03:00:1B:5F:03:00:53:38:02:00:21:F0:04:00:DB:8E:04:00:FC:53:08:00:C6:02:00:00:8D:8F:04:00:F9:2D:00:00:00:82:FF:FF:A9:57:05:00:F8:B5:80:8A:FF:21:0B:31:88:42:5C:D0:FF:21:45:31:88:42:16:D1:C1:48:00:78:02:28:12:D1:B9:49:FF:20:41:30:40:18:00:90:B8:48:40:5C:00:26:86:42:10:D3:51:25:AD:00:28:1C:01:24:A6:46:B4:49:FE:44:08:47:00:28:6D:D1:28:1C:B2:49:A6:46:B2:4A:FE:44:10:47:F8:BD:B1:00:00:98:45:58:00:2D:30:D0:FE:20:40:5D:00:28:2C:D0:F2:20:41:5D:00:29:28:D1:FF:20:02:30:40:5D:01:28:23:D0:24:20:01:24:A6:46:A6:4A:FE:44:10:47:00:06:00:0E"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086ca6, 0xfa, "F3:22:51:5D:81:42:17:D0:50:55:00:28:14:D1:2F:8D:39:1C:E1:48:A6:46:E1:4A:FE:44:10:47:29:8E:79:18:08:1A:40:1E:39:1C:A6:46:DD:4A:FE:44:10:47:40:00:28:86:28:8E:40:08:28:86:01:36:D9:48:00:78:B2:E7:00:20:01:24:A6:46:D7:49:FE:44:08:47:01:1C:00:90:D6:4D:28:68:01:30:28:60:0B:27:7F:01:D4:4E:D4:48:00:8D:32:68:10:18:80:01:80:09:A6:46:D2:4A:FE:44:10:47:00:28:11:DD:00:98:30:60:28:68:03:28:0A:D9:00:20:A6:46:CD:49:FE:44:08:47:C9:48:38:5C:A6:46:CA:49:FE:44:08:47:00:20:28:60:F8:BD:30:B5:05:69:24:20:00:21:01:24:A6:46:7A:4A:FE:44:10:47:F3:21:48:55:51:25:AD:00:28:1C:A6:46:72:49:FE:44:08:47:00:28:05:D1:28:1C:70:49:A6:46:70:4A:FE:44:10:47:30:BD:ED:49:02:00:AB:11:08:00:63:66:08:00:99:2D:00:00:E9:63:05:00:41:69:00:7E:00:28:11:D1:FF:22:04:32:50:5C:01:28:0C:D1:FF:20"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086da0, 0xfa, "05:30:43:5C:1B:2B:07:D1:FF:23:0A:33:5B:5C:01:2B:02:D1:00:23:53:54:43:54:F7:46:C0:46:00:00:08:00:49:8F:03:00:85:48:02:00:10:B5:80:69:00:88:02:28:13:D1:54:48:9C:30:01:79:FF:29:0E:D0:00:78:03:28:03:D0:01:28:01:D0:02:28:07:D1:01:20:04:1C:86:46:9C:49:FE:44:08:47:9C:48:04:70:10:BD:25:00:00:00:10:B5:C0:69:80:78:80:38:00:06:00:0E:02:28:13:D1:44:48:9C:30:01:79:FF:29:0E:D0:00:78:03:28:03:D0:01:28:01:D0:02:28:07:D1:01:20:04:1C:86:46:8D:49:FE:44:08:47:8C:48:04:70:10:BD:C0:46:69:53:08:00:FF:53:08:00:10:B5:00:69:FE:21:09:5C:02:29:06:D0:D0:21:09:58:82:8D:D2:00:54:23:1B:18:05:E0:54:21:0B:18:02:8D:06:20:42:43:D9:6F:50:18:80:01:81:09:D8:6D:01:24:A6:46:79:4A:FE:44:10:47:00:28:12:DC:28:48:9C:30:01:79:FF:29:0D:D0:00:78:03:28:03:D0:01:28:01:D0:02:28:06:D1:20:1C"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086e9a, 0xfa, "A6:46:71:49:FE:44:08:47:71:48:04:70:10:BD:10:B5:1B:48:00:68:50:28:06:D9:17:48:00:21:01:22:96:46:72:4A:FE:44:10:47:6B:48:00:78:FF:21:21:31:41:43:68:48:41:18:69:4C:20:78:14:28:0D:DA:00:28:14:D0:67:49:09:78:C9:08:05:D3:01:20:86:46:65:49:FE:44:08:47:20:78:40:1C:07:E0:FF:20:08:70:01:20:86:46:61:48:FE:44:00:47:00:20:20:70:10:BD:C0:46:4E:05:00:00:B5:CC:00:00:F8:21:19:00:B3:08:05:00:5C:66:08:00:71:CD:01:00:4A:24:19:00:54:24:08:00:07:0E:00:00:21:CB:03:00:00:66:E3:01:0B:C9:03:00:2B:F0:04:00:45:10:08:00:F0:B5:06:1C:74:69:30:69:55:4D:2B:78:31:7E:0A:22:89:1A:62:D0:06:39:48:D0:31:39:2E:D0:3B:39:03:29:6D:D8:FF:21:7D:31:09:5D:02:29:68:D1:FF:22:81:32:01:78:11:55:FF:21:82:31:09:19:42:78:01:30:0A:70:FF:22:83:32:12:19:43:78:13:70:40:78:FF:23:25:33:18:55:08:78"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00086f94, 0xfa, "19:28:52:D1:10:78:37:28:4F:D1:20:1C:05:21:00:22:01:25:AE:46:37:4B:FE:44:18:47:20:1C:AE:46:36:49:FE:44:08:47:3D:E0:00:2B:3F:D0:FF:20:5D:30:01:5D:05:20:03:1C:20:1C:41:22:01:27:BE:46:31:4F:FE:44:38:47:20:1C:05:21:01:22:96:46:2A:4B:FE:44:18:47:00:20:28:70:25:E0:FF:21:7D:31:00:78:08:55:2A:4A:20:1C:09:5C:53:78:99:42:02:DB:12:78:91:42:1C:DD:FF:21:79:31:09:5C:10:22:20:23:01:24:A6:46:21:4C:FE:44:20:47:0D:E0:22:48:00:78:33:28:0D:DB:FF:20:79:30:01:5D:20:1C:29:23:01:24:A6:46:19:4C:FE:44:20:47:17:48:15:49:08:18:30:62:F0:BD:FF:FF:FF:01:95:49:05:00:5B:32:08:00:D1:A1:04:00:50:66:08:00:54:66:08:00:48:10:08:00:3F:A2:04:00:AB:EA:01:00:3D:1D:03:00:58:66:08:00:B9:26:08:00:61:66:08:00:60:66:08:00:35:57:08:00:5D:9A:03:00:43:1C:03:00:FD:06:05:00:7F:A6:01:00:B3:53"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008708e, 0xfa, "04:00:A4:0F:00:00:F9:D2:00:00:ED:E7:00:00:B2:11:08:00:63:66:08:00:69:53:08:00:40:1E:80:00:8C:4B:19:50:8A:49:0A:50:F7:46:F0:B5:01:1C:88:69:82:88:53:04:5B:0C:88:4E:88:4F:89:4D:03:D0:60:2B:01:DC:B2:42:14:D0:82:88:01:23:1B:03:54:04:64:0F:24:03:9C:42:08:DB:3B:1C:01:33:54:04:24:0D:E4:00:9C:42:01:DA:BA:42:03:D0:FF:20:88:60:E8:1D:F0:BD:01:24:A6:46:7B:49:FE:44:08:47:38:1C:A6:46:7A:49:FE:44:08:47:30:1C:A6:46:77:49:FE:44:08:47:A6:46:76:48:FE:44:00:47:38:1C:A6:46:73:49:FE:44:08:47:E8:48:01:68:30:1C:A6:46:71:4A:FE:44:10:47:71:48:40:19:F0:BD:01:1C:0A:7D:6F:48:00:2A:02:D0:C9:68:01:29:01:D0:4F:30:F7:46:31:30:F7:46:41:68:02:39:41:60:E9:48:3F:30:F7:46:1C:B5:41:68:E8:4C:00:29:17:D0:41:69:B0:20:40:18:B8:31:6A:46:01:23:9E:46:E2:4B:FE:44:18:47:00:99:E2:48:E4:38"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087188, 0xfa, "41:43:68:46:80:88:41:18:FF:20:AE:30:81:42:02:D9:20:1C:BF:30:1C:BD:20:1C:DF:30:1C:BD:10:B5:04:1C:C8:68:0A:21:01:22:96:46:E0:4A:FE:44:10:47:00:28:00:D1:8C:20:A0:60:DE:48:DB:30:10:BD:DE:49:04:39:09:78:00:29:01:D1:00:21:41:60:41:68:42:69:51:1A:41:60:D8:48:55:30:F7:46:D8:49:09:78:00:29:04:D1:01:7D:D5:48:02:30:FF:22:42:54:D5:48:4F:30:F7:46:01:1C:8A:69:4B:68:D3:48:9A:42:01:D9:3B:30:F7:46:CA:60:79:30:F7:46:D1:48:CF:49:08:80:D0:48:FF:30:DE:30:F7:46:C2:69:FF:21:11:31:8B:5C:CD:49:5B:08:08:D3:FF:23:02:33:9A:5C:02:2A:03:D0:01:2A:01:D0:03:2A:02:D1:08:1C:5B:30:F7:46:FF:22:42:60:08:1C:39:30:F7:46:00:B5:40:68:01:21:8E:46:C2:49:FE:44:08:47:C2:48:57:30:00:BD:02:8A:01:79:0A:29:00:DB:0A:21:E8:48:8A:42:01:DD:5F:30:F7:46:5B:30:F7:46:F0:B5:01:24:A6:46:E4:48:FE:44"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087282, 0xfa, "00:47:01:28:05:D0:A6:46:E1:48:FE:44:00:47:04:28:19:D1:02:26:DF:4D:28:79:00:28:11:D0:E8:7A:06:28:0E:D1:0E:20:01:1C:EA:4F:38:1C:14:38:A6:46:E7:4A:FE:44:10:47:38:1C:0E:21:A6:46:E4:4A:FE:44:10:47:70:35:01:3E:E7:D1:A6:46:E3:48:FE:44:00:47:E2:49:0B:48:54:30:40:18:F0:BD:C0:46:04:F3:1A:00:80:7B:08:00:03:80:00:00:17:10:00:00:C9:FB:04:00:BB:15:04:00:7D:CA:03:00:05:43:02:00:0B:C9:03:00:AB:02:00:00:B1:33:02:00:F0:B5:8D:B0:01:90:81:69:02:91:01:7D:03:91:42:68:00:92:80:8B:40:00:04:90:6B:48:83:30:00:78:40:00:05:90:00:29:01:D1:00:20:E1:E0:04:98:02:04:12:0C:06:92:02:98:03:99:6B:46:01:24:A6:46:C6:4D:FE:44:28:47:07:90:00:9E:00:20:08:90:80:48:09:90:0A:90:7F:E0:09:98:00:28:2B:D0:0B:98:09:90:28:E0:05:98:87:42:25:DB:90:79:03:28:01:D0:01:28:20:D1:79:19:05:98:08:1A"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008737c, 0xfa, "07:99:A6:46:B8:4A:FE:44:10:47:07:1C:28:1C:07:99:A6:46:B5:4A:FE:44:10:47:01:04:09:0C:3A:04:12:0C:00:20:A6:46:B1:4B:FE:44:18:47:00:28:04:D1:0A:98:00:28:03:D0:0A:97:01:E0:00:20:0A:90:B6:68:00:2E:03:D0:30:88:07:99:88:42:49:DB:08:98:00:28:46:D1:61:49:09:98:88:42:42:D1:0A:98:88:42:3F:D1:03:98:00:28:2C:D0:02:9D:03:98:0C:90:00:27:28:88:0B:90:04:99:A6:46:9C:4A:FE:44:10:47:00:28:07:D0:0B:99:04:98:A6:46:98:4A:FE:44:10:47:00:28:11:D1:08:98:B8:42:09:D0:08:98:C1:00:02:98:40:18:29:1C:08:22:A6:46:EF:4B:FE:44:18:47:08:98:40:1C:00:06:00:0E:08:90:08:35:01:37:0C:98:01:38:0C:90:D6:D1:08:98:00:28:0C:D0:02:98:08:99:06:9A:6B:46:A6:46:85:4D:FE:44:28:47:07:90:00:9E:3F:48:09:90:0A:90:00:2E:3A:D0:35:88:07:98:85:42:36:DA:B0:68:00:28:05:D0:00:88:07:99:88:42:01:DC:47:1B"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087476, 0xfa, "04:E0:07:98:40:1B:00:99:09:88:0F:18:72:68:91:88:05:98:40:18:87:42:00:DA:6A:E7:48:19:07:99:A6:46:73:4A:FE:44:10:47:0B:90:79:19:05:98:08:1A:07:99:A6:46:6E:4A:FE:44:10:47:02:04:12:0C:0B:98:01:04:09:0C:00:20:A6:46:6A:4B:FE:44:18:47:00:28:00:D1:48:E7:00:20:09:90:06:E0:C0:46:E0:31:08:00:1F:48:09:99:81:42:02:D0:09:98:0A:90:02:E0:0A:99:81:42:01:D0:0A:98:04:E0:06:98:A6:46:E8:49:FE:44:08:47:01:99:48:60:E5:48:FF:30:10:30:0D:B0:F0:BD:B7:4B:04:00:4F:81:03:00:FD:79:00:00:C6:05:00:00:E0:49:09:78:2A:29:05:D0:33:29:01:D1:0A:21:02:E0:06:21:00:E0:08:21:41:60:F1:48:43:30:F7:46:C0:46:65:2D:00:00:79:47:00:00:0D:13:02:00:76:24:08:00:E0:A0:1B:00:89:28:05:00:3D:39:02:00:60:5B:08:00:FF:FF:00:00:D9:AA:00:00:D5:75:00:00:23:01:05:00:B3:09:02:00:FC:B5:00:90:E4:48:00:78"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087570, 0xfa, "02:28:43:D1:E3:49:FF:20:41:30:40:18:01:90:E2:48:40:5C:00:26:38:E0:B1:00:01:98:45:58:00:2D:30:D0:FE:20:40:5D:00:28:2C:D0:F2:20:41:5D:00:29:28:D1:FF:20:02:30:40:5D:01:28:23:D0:24:20:01:24:A6:46:D6:4A:FE:44:10:47:00:06:00:0E:F3:22:51:5D:81:42:17:D0:50:55:00:28:14:D1:2F:8D:39:1C:D0:48:A6:46:24:4A:FE:44:10:47:29:8E:79:18:08:1A:40:1E:39:1C:A6:46:20:4A:FE:44:10:47:40:00:28:86:28:8E:40:08:28:86:01:36:C7:48:00:78:86:42:C4:D3:FF:21:41:31:00:98:41:60:C5:48:C4:49:08:18:FC:BD:F9:97:00:00:8F:8D:01:00:A4:13:08:00:10:B5:00:79:01:28:06:D1:88:8B:09:7D:01:22:96:46:BD:4A:FE:44:10:47:BD:4C:20:78:01:28:04:D1:01:20:86:46:BB:48:FE:44:00:47:00:20:20:70:B9:49:B4:48:88:38:40:18:10:BD:C0:46:E5:06:05:00:14:05:1A:00:77:C5:01:00:B9:C5:01:00:A1:95:01:00:95:49:05:00:21:96"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008766a, 0xfa, "01:00:F0:B5:86:B0:01:92:02:91:06:1C:88:68:00:6A:03:90:80:00:01:99:44:18:04:94:04:19:05:94:04:19:01:98:03:99:01:25:AE:46:A7:4A:FE:44:10:47:04:98:03:99:AE:46:A4:4A:FE:44:10:47:05:98:03:99:AE:46:A1:4A:FE:44:10:47:02:98:80:68:C7:69:70:68:03:99:AE:46:9D:4A:FE:44:10:47:00:28:50:D1:30:68:39:1C:03:9A:AE:46:9A:4B:FE:44:18:47:00:28:47:D5:70:68:39:1C:03:9A:AE:46:95:4B:FE:44:18:47:00:28:3E:D5:30:68:01:99:02:9A:23:1C:AE:46:91:4F:FE:44:38:47:00:94:30:68:01:99:04:9A:02:9B:AE:46:8E:4F:FE:44:38:47:00:94:30:68:02:99:89:68:C9:6A:01:9A:02:9B:AE:46:88:4F:FE:44:38:47:01:98:04:99:05:9A:02:9B:AE:46:85:4F:FE:44:38:47:02:98:80:68:01:6B:05:98:01:9A:02:9B:AE:46:80:4F:FE:44:38:47:70:68:04:99:02:9A:23:1C:AE:46:7A:4C:FE:44:20:47:01:98:04:99:03:9A:AE:46:76:4B:FE:44:18:47"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087764, 0xfa, "00:28:02:D0:00:20:C0:43:00:E0:00:20:06:B0:F0:BD:F0:B5:85:B0:45:69:86:69:C0:69:02:90:0F:6A:48:6A:03:90:88:6B:04:90:28:1C:00:95:31:6A:89:00:4D:19:01:95:4D:19:31:68:01:29:0D:D1:72:69:39:1C:01:24:A6:46:0D:4B:FE:44:18:47:72:69:01:98:B9:18:A6:46:09:4B:FE:44:18:47:68:46:02:99:2A:1C:01:24:A6:46:60:4B:FE:44:18:47:62:49:5F:4D:00:28:06:D0:0C:70:28:1C:21:30:0D:E0:C0:46:5D:5F:05:00:00:20:08:70:B2:69:03:98:04:99:A6:46:58:4B:FE:44:18:47:28:1C:A9:30:05:B0:F0:BD:58:48:00:78:00:07:40:0E:89:6B:49:06:89:0C:08:18:53:49:08:80:54:48:C5:30:F7:46:01:1C:0A:79:52:48:06:2A:03:DB:92:1F:4A:60:2F:30:F7:46:79:30:F7:46:01:1C:88:69:43:78:3E:22:1A:40:4C:48:06:2A:05:DB:9A:06:92:0E:06:3A:4A:60:23:30:F7:46:49:30:F7:46:30:B5:45:68:FF:20:11:30:40:5D:80:09:0C:D3:11:21:09:01:4A:5D"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x0008785e, 0xfa, "DF:20:10:40:48:55:28:1C:00:21:01:22:96:46:3F:4A:FE:44:10:47:01:20:04:1C:86:46:3D:49:FE:44:08:47:A9:8B:28:1C:A6:46:3B:4A:FE:44:10:47:3B:48:9B:30:30:BD:6D:95:00:00:4D:96:01:00:69:53:08:00:10:B5:02:1C:4C:20:43:5A:35:48:06:2B:0D:DB:19:24:E4:01:A3:42:09:DC:54:23:59:5A:0A:29:05:DB:A1:42:03:DC:00:21:51:60:99:30:10:BD:2E:4A:00:21:FF:23:21:33:4B:43:D3:5C:FF:2B:04:D0:49:1C:09:06:09:0E:0A:29:F4:DB:49:1E:28:4A:11:70:01:21:27:4A:11:70:FF:30:26:30:10:BD:C0:46:7B:5E:02:00:24:48:A5:30:F7:46:C0:46:45:10:08:00:54:24:08:00:07:0E:00:00:2B:F0:04:00:FF:FF:FF:01:5B:32:08:00:8F:02:00:00:CD:92:01:00:6F:4B:02:00:58:66:08:00:43:1C:03:00:F5:70:00:00:21:37:05:00:E9:36:05:00:A9:36:05:00:C3:6C:05:00:A5:6C:05:00:D1:1C:05:00:6D:76:08:00:91:48:05:00:47:37:05:00:63:66:08:00"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087958, 0xec, "1C:30:19:00:96:A5:1B:00:61:61:03:00:E1:72:03:00:5F:73:03:00:F5:56:02:00:BB:88:03:00:3B:3B:02:00:9D:CF:02:00:6D:23:03:00:B9:26:08:00:61:66:08:00:60:66:08:00:BD:65:01:00:FF:B5:68:46:FF:F7:FA:F9:FF:BD:FF:B5:68:46:FF:F7:13:FA:FF:BD:FF:B5:68:46:FF:F7:3A:F9:FF:BD:FF:B5:68:46:FF:F7:EF:F8:FF:BD:FF:B5:68:46:FF:F7:74:FA:FF:BD:FF:B5:68:46:FF:F7:BB:FA:FF:BD:FF:B5:68:46:FF:F7:16:FA:FF:BD:FF:B5:68:46:FF:F7:33:FA:FF:BD:FF:B5:68:46:FE:F7:7B:FE:FF:BD:FF:B5:68:46:FE:F7:AD:FE:FF:BD:FF:B5:68:46:FE:F7:53:FE:FF:BD:FF:B5:68:46:FE:F7:39:FE:FF:BD:FF:B5:68:46:FE:F7:42:FE:FF:BD:FF:B5:68:46:FF:F7:41:F8:FF:BD:FF:B5:68:46:FF:F7:8F:F9:FF:BD:FF:B5:68:46:FE:F7:0F:FF:FF:BD:FF:B5:68:46:FE:F7:B5:FE:FF:BD:FF:B5:68:46:FE:F7:D6:FE:FF:BD"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00087b78, 0x88, "00:B5:F8:F0:E3:FA:00:BD:B7:70:08:00:59:71:08:00:1D:72:08:00:4D:72:08:00:61:72:08:00:79:72:08:00:15:75:08:00:69:75:08:00:75:77:08:00:41:71:08:00:D5:65:08:00:C5:71:08:00:E1:71:08:00:F9:71:08:00:0F:72:08:00:09:73:08:00:19:76:08:00:FB:77:08:00:15:78:08:00:2B:78:08:00:4B:78:08:00:A5:71:08:00:9D:78:08:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:F9:78:08:00"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001af304, 0x80, "CE:FB:04:00:F4:4B:04:00:0C:76:00:00:06:0A:02:00:50:98:00:00:B4:C6:01:00:B8:5E:02:00:58:95:01:00:2E:49:05:00:DE:33:02:00:14:29:02:00:60:13:02:00:D6:28:05:00:74:39:02:00:88:AC:00:00:7A:95:00:00:E8:72:00:00:1C:62:03:00:0E:73:03:00:7E:73:03:00:34:D0:02:00:52:48:00:00:04:24:03:00:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:5A:66:01:00"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x00180000, 0xfa, "70:B5:3A:4D:AE:7F:01:24:A6:46:36:48:FE:44:00:47:B0:42:F8:D1:03:20:17:21:89:01:A6:46:32:4A:FE:44:10:47:AD:7F:A6:46:2F:48:FE:44:00:47:A8:42:F9:D1:FE:E7:30:B5:2E:49:08:1F:2E:4A:10:60:31:48:02:1C:71:3A:93:24:01:23:A3:54:2B:4B:0B:60:02:23:13:71:2A:4B:4B:60:03:23:53:71:29:4B:8B:60:04:23:03:70:29:4B:CB:60:05:23:83:73:28:4B:0B:61:06:23:03:73:27:4B:4B:61:07:23:43:71:26:4B:8B:61:08:24:03:1C:33:3B:1C:70:24:4B:CB:61:09:23:D3:74:23:4B:0B:62:0A:23:D3:71:D3:1D:22:4C:4C:62:0B:24:44:77:21:4C:8C:62:0C:25:04:1C:3D:3C:25:70:1F:4C:CC:62:0F:38:0D:24:04:70:1D:4C:0C:63:0E:24:04:73:1C:4C:4C:63:0F:24:44:73:1B:4C:8C:63:10:24:04:77:1A:48:C8:63:11:20:10:70:19:48:08:64:12:20:98:76:18:48:48:64:30:BD:C0:46:25:86:04:00:1B:90:04:00:6C:52:08:00:08:66:08:00:20:55:08:00:FF:79"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001800fa, 0xfa, "08:00:EB:79:08:00:E1:79:08:00:95:55:08:00:31:7A:08:00:09:7A:08:00:F5:79:08:00:3B:7A:08:00:27:7A:08:00:13:7A:08:00:A5:79:08:00:1D:7A:08:00:AF:79:08:00:91:79:08:00:9B:79:08:00:CD:79:08:00:D7:79:08:00:B9:79:08:00:C3:79:08:00:F0:B5:31:4E:0C:22:32:70:1A:23:73:70:09:20:B0:70:17:20:F0:70:03:20:2E:4D:29:1C:01:39:01:24:A6:46:2A:4F:FE:44:38:47:B2:78:F3:78:03:20:29:1C:A6:46:26:4E:FE:44:30:47:03:20:29:1C:01:31:A6:46:25:4A:FE:44:10:47:A6:46:24:48:FE:44:00:47:23:4B:00:21:08:1C:1A:68:00:2A:04:D0:02:07:15:0F:22:1C:AA:40:11:43:02:07:12:0F:0F:2A:05:D1:C5:08:06:22:2A:40:1B:4D:A9:52:00:21:04:33:01:30:20:28:E9:D3:1A:48:01:1C:50:31:0C:70:0A:21:16:4A:11:70:33:21:01:70:00:25:16:48:05:60:28:1C:A6:46:16:49:FE:44:08:47:13:49:08:60:14:48:05:60:07:20:14:49:08:70:14:4A"
Send_HCI_VS_Write_Memory_Block 0xFF05, 0x001801f4, 0x60, "91:78:02:20:08:43:90:70:12:48:05:70:12:48:05:70:12:48:05:70:F0:BD:C0:46:FC:53:08:00:31:90:04:00:C6:05:00:00:1B:90:04:00:33:00:18:00:80:7B:08:00:84:F3:1A:00:6D:22:08:00:69:53:08:00:50:66:08:00:54:66:08:00:D1:A1:04:00:5C:66:08:00:B3:11:08:00:E4:15:08:00:63:66:08:00:60:66:08:00:61:66:08:00"
Send_HCI_VS_Goto_Address 0xFF83, 0x00087b79, 0x00000000, 0x00000000, 0x00000000, 0x00000000
Wait_HCI_Command_Complete_VS_Goto_Address_Event 5000, any, 0xff83, 0x00
### Set the BT Core spec to 4.2 for Bluetopia stack compatibility
### Remove below VS command for default BT core spec 5.1
Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x00085368, 0x2a00, 0xff00
Wait_HCI_Command_Complete_VS_Read_Modify_Write_Hardware_Register_Event 5000, any, 0xfd09, 0x00
Send_HCI_VS_Sleep_Mode_Configurations 0xFD0C, 0x01, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0x0064
Wait_HCI_Command_Complete_VS_Sleep_Mode_Configurations_Event 5000, any, 0xfd0c, 0x00
Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x001a6058, 0x1000, 0x1000
Send_HCI_VS_Read_Modify_Write_Hardware_Register 0xFD09, 0x001a6010, 0x0010, 0x0010
Send_HCI_VS_Fast_Clock_Configuration_btip 0xFD1C, 0xff, 0x00001388, 0x000000ff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, 0xfa, 0x00, 0xff, 0x00ff
Wait_HCI_Command_Complete_VS_Fast_Clock_Configuration_btip_Event 5000, any, 0xfd1c, 0x00
## Description:   ORCA_C Commercial PHY FW Initialization Script
Send_HCI_VS_DRPb_Set_RF_Calibration_Info 0xFD76, 0x01, 0x00005421, 0x00005761, 0x14, 0x05, 0x0a, 0x05, 0x00, 0x07, 0x06, 0x0a, 0x04, 0x05, 0x08, 0x09, 0x0b, 0x0c, 0x0d, 0x0e, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x00000000
Wait_HCI_Command_Complete_VS_DRPb_Set_RF_Calibration_Info_Event 5000, any, 0xfd76, 0x00
Send_HCI_VS_DRPb_Enable_RF_Calibration 0xFD80, 0x00, 0x00000001, 0x01
Wait_HCI_Command_Complete_VS_DRPb_Enable_RF_Calibration_Event 5000, any, 0xfd80, 0x00
Send_HCI_VS_DRPb_Enable_RF_Calibration 0xFD80, 0x3c, 0x00005ff0, 0x00
Send_HCI_VS_Stop_VS_Lock 0xFE38
Wait_HCI_Command_Complete_VS_Stop_VS_Lock_Event 5000, any, 0xfe38, 0x00
## START of CC2564 Adds-On
## Enable fast clock XTAL support
Send_HCI_VS_Fast_Clock_Configuration_btip 0xFD1C, 0x01, 0x00001388, 0x000007d0, 0xff, 0xff, 0x04, 0xff, 0xff, 0xff, 0xfa, 0x00, 0x00, 0x0000
## Enable eHCILL
Send_HCI_VS_hcill_parameters 0xFD2B, 0x0010, 0x0050, 0x96
Wait_HCI_Command_Complete_VS_hcill_parameters_Event 5000, any, 0xfd2b, 0x00
#Send_HCI_VS_Sleep_Mode_Configurations 0xFD0C, 0x01, 0x01, 0x00, 0xff, 0xff, 0xff, 0xff, 0x0064
#Wait_HCI_Command_Complete_VS_Sleep_Mode_Configurations_Event 5000, any, 0xfd0c, 0x00
## END of CC2564 Adds-On
  • Did, you try with CC2564CQFNEVM board? Can, you take FW logs? You may also try changing the Inquiry transmit power level with:
    HCI_Read_Inquiry_Response_Transmit_Power_Level and HCI_Write_Inquiry_Transmit_Power_Level
    Hari
    Inquiry TX power is set to 12 and cannot be changed. Whatever value enter, always read back 12 using HCI_Read_Inquiry_Response_Transmit_Power_Level command.
    Comparison with TI-eval board doesn't show any difference in terms of device discovery. But I realized that most of surrounding active BT devices are BLE thus not discovered with HCI_inquiry command.
    Only BDR and EDR devices are listed what is to be expected. Use of Periodic Inquiry mode makes a real improvement.  It's more efficient then standard HCI_inquiry which doesn't show all available devices anytime and discovers between 3-5 out of 5 available devices.
    We have a clear evidence (TI-eval board log file) that 50:1E:2D:3D:26:B0 (StreamKit1832) was discovered after 22 seconds of the periodic inquiry. That's the case, device wouldn't be discovered with HCI_inquiry at that moment.
    <HTML>
    <HEAD>
    <TITLE>HCITester Log</TITLE>
    </HEAD>
    <BODY>
    <FONT face="Courier New">
    <TABLE ALIGN=LEFT CELLSPACING=0 width=3500 CELLPADDING=0>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 --</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 Packet "HCI_Periodic_Inquiry_Mode", Opcode 0x0403</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 Parameters:</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 | Max Period Length   : 0x0008</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 | Min Period Length   : 0x0007</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 | LAP                 : "9E8B33"</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 | Inquiry Length      : 0x04</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:15.935 | Number of Responses : 0x00</font></td></tr>
    <tr bgcolor="60c0c0"><td><font color="ffffff">12:58:15.935 Outgoing Dump:</font></td></tr>
    <tr bgcolor="60c0c0"><td><font color="ffffff">12:58:15.935     0000: 01 03 04 09 08 00 07 00 33 8b 9e 04 00          ........3....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:15.935 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:15.935     0000: 04 0e 04 01 03 04 00                            .......</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:15.935 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:15.935 Packet "HCI_Command_Complete_Periodic_Inquiry_Mode_Event", Opcode 0x0403</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:15.935 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:15.935 | Number HCI commands : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:15.935 | Command Opcode      : 0x0403</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:15.935 | Status              : 0x00 (Success)</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:17.106 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:17.106     0000: 04 02 0f                                        ...</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:17.106     0000: 01 45 e8 b3 41 16 00 01 02 00 04 01 02 a9 5b    .E..A.........[</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | BD_ADDR responded         : "00:16:41:B3:E8:45"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | Class of Device           : 0x020104</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:17.106 | Clock Offset              : 0x5ba9</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.447 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.447     0000: 04 02 0f 01                                     ....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.447     0000: d0 56 91 c0 d3 c0 01 02 00 0c 02 5a 44 2e       .V.........ZD.</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | BD_ADDR responded         : "C0:D3:C0:91:56:D0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | Class of Device           : 0x5a020c</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.447 | Clock Offset              : 0x2e44</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.917 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.917     0000: 04 02 0f 01                                     ....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.917     0000: 05 53 74 ab 03 7c 01 02 00 0c 02 5a e5 26       .St..|.....Z.&amp;</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | BD_ADDR responded         : "7C:03:AB:74:53:05"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | Class of Device           : 0x5a020c</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.917 | Clock Offset              : 0x26e5</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.937 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.937     0000: 04 02 0f 01                                     ....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:20.937     0000: 10 37 3d 2d 1e 50 01 02 00 14 04 24 6a 3b       .7=-.P.....$j;</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | BD_ADDR responded         : "50:1E:2D:3D:37:10"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | Class of Device           : 0x240414</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:20.937 | Clock Offset              : 0x3b6a</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:21.057 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:21.057     0000: 04 01 01 00                                     ....</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:21.057 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:21.057 Packet "HCI_Inquiry_Complete_Event", Opcode 0x0001</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:21.057 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:21.057 | Status : 0x00 (Success)</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:26.428 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:26.428     0000: 04 02 0f 01 45 e8 b3 41                         ....E..A</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:26.428     0000: 16 00 01 02 00 04 01 02 a8 5b                   .........[</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | BD_ADDR responded         : "00:16:41:B3:E8:45"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | Class of Device           : 0x020104</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:26.428 | Clock Offset              : 0x5ba8</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:28.458 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:28.458     0000: 04 02 0f 01 10 37 3d 2d                         .....7=-</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:28.458     0000: 1e 50 01 02 00 14 04 24 6a 3b                   .P.....$j;</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | BD_ADDR responded         : "50:1E:2D:3D:37:10"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | Class of Device           : 0x240414</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:28.458 | Clock Offset              : 0x3b6a</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:29.328 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:29.328     0000: 04 02 0f 01 d0 56 91 c0                         .....V..</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:29.328     0000: d3 c0 01 02 00 0c 02 5a 45 2e                   .......ZE.</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | BD_ADDR responded         : "C0:D3:C0:91:56:D0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | Class of Device           : 0x5a020c</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:29.328 | Clock Offset              : 0x2e45</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:30.318 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:30.318     0000: 04 01 01 00                                     ....</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:30.318 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:30.318 Packet "HCI_Inquiry_Complete_Event", Opcode 0x0001</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:30.318 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:30.318 | Status : 0x00 (Success)</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:35.709 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:35.709     0000: 04 02 0f 01                                     ....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:35.709     0000: 45 e8 b3 41 16 00 01 02 00 04 01 02 a9 5b       E..A.........[</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | BD_ADDR responded         : "00:16:41:B3:E8:45"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | Class of Device           : 0x020104</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:35.709 | Clock Offset              : 0x5ba9</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:37.420 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:37.420     0000: 04 02 0f 01 10 37 3d 2d 1e 50                   .....7=-.P</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:37.420     0000: 01 02 00 14 04 24 6a 3b                         .....$j;</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | BD_ADDR responded         : "50:1E:2D:3D:37:10"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | Class of Device           : 0x240414</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:37.420 | Clock Offset              : 0x3b6a</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.149 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.149     0000: 04                                              .</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.149     0000: 02 0f 01 d0 56 91 c0 d3 c0 01 02 00 0c 02 5a 45 ....V.........ZE</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.149     0010: 2e                                              .</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | BD_ADDR responded         : "C0:D3:C0:91:56:D0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | Class of Device           : 0x5a020c</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.149 | Clock Offset              : 0x2e45</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.640 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.640     0000: 04 02 0f 01 b0 26 3d                            .....&amp;=</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:38.640     0000: 2d 1e 50 01 02 00 14 04 24 98 3f                -.P.....$.?</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | BD_ADDR responded         : "50:1E:2D:3D:26:B0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | Class of Device           : 0x240414</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:38.640 | Clock Offset              : 0x3f98</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:39.969 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:39.969     0000: 04 01 01 00                                     ....</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:39.969 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:39.969 Packet "HCI_Inquiry_Complete_Event", Opcode 0x0001</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:39.969 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:39.969 | Status : 0x00 (Success)</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:46.902 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:46.902     0000: 04 02 0f 01 45 e8 b3 41 16                      ....E..A.</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:46.902     0000: 00 01 02 00 04 01 02 a9 5b                      ........[</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | BD_ADDR responded         : "00:16:41:B3:E8:45"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | Class of Device           : 0x020104</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:46.902 | Clock Offset              : 0x5ba9</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:48.343 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:48.343     0000: 04 02 0f 01 b0 26                               .....&amp;</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:48.343     0000: 3d 2d 1e 50 01 02 00 14 04 24 98 3f             =-.P.....$.?</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | BD_ADDR responded         : "50:1E:2D:3D:26:B0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | Class of Device           : 0x240414</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:48.343 | Clock Offset              : 0x3f98</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:49.163 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:49.163     0000: 04 01 01 00                                     ....</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:49.163 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:49.163 Packet "HCI_Inquiry_Complete_Event", Opcode 0x0001</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:49.163 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:49.163 | Status : 0x00 (Success)</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:53.783 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:53.783     0000: 04 02 0f 01                                     ....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:53.783     0000: 45 e8 b3 41 16 00 01 02 00 04 01 02 a8 5b       E..A.........[</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | BD_ADDR responded         : "00:16:41:B3:E8:45"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | Class of Device           : 0x020104</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:53.783 | Clock Offset              : 0x5ba8</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:55.814 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:55.814     0000: 04 02 0f 01 d0 56 91                            .....V.</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:55.814     0000: c0 d3 c0 01 02 00 0c 02 5a 45 2e                ........ZE.</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | BD_ADDR responded         : "C0:D3:C0:91:56:D0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | Class of Device           : 0x5a020c</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:55.814 | Clock Offset              : 0x2e45</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:57.074 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:57.074     0000: 04                                              .</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:57.074     0000: 02 0f 01 b0 26 3d 2d 1e 50 01 02 00 14 04 24 97 ....&amp;=-.P.....$.</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:57.074     0010: 3f                                              ?</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | Number of Responses       : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | BD_ADDR responded         : "50:1E:2D:3D:26:B0"</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | Page Scan Repetition Mode : 0x01 (R1)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | Page Scan Period Mode     : 0x02 (P2)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | Page Scan Mode            : 0x00 (Mandatory)</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | Class of Device           : 0x240414</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.074 | Clock Offset              : 0x3f97</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:57.824 --</font></td></tr>
    <tr bgcolor="ffffe6"><td><font color="0000c0">12:58:57.824 Packet "HCI_Exit_Periodic_Inquiry_Mode", Opcode 0x0404</font></td></tr>
    <tr bgcolor="60c0c0"><td><font color="ffffff">12:58:57.824 Outgoing Dump:</font></td></tr>
    <tr bgcolor="60c0c0"><td><font color="ffffff">12:58:57.824     0000: 01 04 04 00                                     ....</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:57.824 Incoming Dump:</font></td></tr>
    <tr bgcolor="408080"><td><font color="ffffff">12:58:57.824     0000: 04 0e 04 01 04 04 00                            .......</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.824 --</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.824 Packet "HCI_Command_Complete_Exit_Periodic_Inquiry_Mode_Event", Opcode 0x0404</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.824 Parameters:</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.824 | Number HCI commands : 0x01</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.824 | Command Opcode      : 0x0404</font></td></tr>
    <tr bgcolor="fff7fa"><td><font color="006400">12:58:57.824 | Status              : 0x00 (Success)</font></td></tr>
    </TABLE>
    </FONT>
    </BODY>
    </HTML>
  • Ok.. What is the Inquiry length being used in 'HCI_Inquiry'? With periodic inquiry, obviously the chances are better as it tries periodically. Do, you have any other BT connections or BT/BLE activities at the same time?
  • Hi Hari,
    there were no other connections or activities active, Ladislav was just using the HCITester and only tested inquiry. He will resume testing on Monday. What Inquiry length do you suggest to use (I don´t know what he used unfortunately and he left the office already)
    thanks, Christoph
  • Please try with 'Inquiry length' around  8 to 10 sec, and the max number of responses to 20 or so..
  • Changing these parameters didn't yield any improvement. I'm wondering, could the Inquiry Mode influence the result? We're using Extended mode at the moment.
  • Changing the inquiry mode to standard didn't change the result either, so we're still looking for a solution here.
  • we have moved bit further and found different CC2564C behaviour when used with HCITool or with own hw and application software.
    1st case: CC2564C is connected via UART to a PC running HCITool
    - HCI tool captured data from CC2564C on HCI_Inquiry command are in standard format containing BD address, decvice class, clock offset ...
    - All active BT devices including (headset class Panasonic SC-MC07) are discovered and listed.
    2nd case: CC2564C loaded with TI CC256XSTBTBLESW 4.2.1.0 firmware, connected to the MCU running app sw
    - data captured with UART/USB converter attached in parallel to HCI_UART confirmed that CC2564C responds in extended inquiry format, means BT firmware must be configured for that since we can see additional info e.g. device friendly name and so. The problem is that one active BT device (headset class BT speaker Panasonic SC-MC07) isn't listed at all, neither BD address nor friendly name. For some reason filtered out by BT firmware.
  • Hi Hari, what rules are applied in  CC2564C firmware to prevent list following device in extended inquiry format?
     Panasonic SC-MC07
    09:37:44.407 Packet "HCI_Inquiry_Result_Event", Opcode 0x0002
    09:37:44.407 Parameters:
    09:37:44.407 | Number of Responses : 0x01
    09:37:44.407 | BD_ADDR responded : "00:1D:DF:5C:71:9D"
    09:37:44.407 | Page Scan Repetition Mode : 0x01 (R1)
    09:37:44.407 | Page Scan Period Mode : 0x02 (P2)
    09:37:44.407 | Page Scan Mode : 0x00 (Mandatory)
    09:37:44.407 | Class of Device : 0x240404
    09:37:44.407 | Clock Offset : 0x72a6
  • Your device is acting like master, issuing the 'Inquiry' right? As such, extended Inquiry response is from the slave.. Did, you capture the HCI messages between the MCU and CC2564C to compare with the HCI tool script, that is detecting the Panasonic device.
  • right, MCU is acting as master, bellow log is extended inquiry response from the CC2564C. As you can see even lower in HEX to ASCII converted log, Panasonic device isn't listed there.
    04 0E 05 01 19 0C 00 03 04 0E 04 01 3A 0C 00 04 0E 04 01 1A 0C 00 04 0E
    07 01 23 0C 00 28 00 00 04 0E 04 01 24 0C 00 04 0F 04 00 01 01 04 04 2F
    FF 01 D0 56 91 C0 D3 C0 01 02 0C 02 5A F8 17 A5 14 09 47 61 6C 61 78 79
    20 54 61 62 20 41 20 28 32 30 31 36 29 11 03 05 11 0A 11 0C 11 0E 11 12
    11 15 11 1F 11 00 12 01 05 01 07 28 FF 00 75 02 09 01 00 00 00 02 01 00
    00 00 00 00 01 C2 D3 C0 91 56 D1 00 00 00 00 00 00 00 00 5B 54 61 62 6C
    65 74 5D 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2F FF 01 B0 26 3D 2D
    1E 50 01 02 14 04 24 22 4A A9 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 04 2F FF 01 B0 26 3D 2D 1E 50 01 02 14 04
    24 22 4A B6 20 09 53 74 72 65 61 6D 38 30 30 20 45 76 61 6C 75 61 74 69
    6F 6E 20 4B 69 74 2D 33 64 32 36 62 30 02 0A 04 09 10 02 00 6B 1D 46 02
    2B 05 0D 03 00 18 01 18 0E 11 0C 11 1E 11 0B 11 00 00 00 00 00 00 00 00
    00 00 00 00 04 01 01 00
    :#($/ÿÐV‘ÀÓÀZø¥ Galaxy Tab A (2016)
    (ÿu ÂÓÀ‘VÑ[Tablet] /ÿ°&=-P$"J©/ÿ°&=-P$"J¶ Stream800 Evaluation Kit-3d26b0
    kF+
  • So, basically with HCI tester, the panasonic device is discovered. Where as with your MCU host stack, you do not see the device getting discovered. Is this understanding correct?
    If so, check the HCI commands sent from HCI tester vs MCU stack. I wonder, if the MCU stack is sending, 'HCI_Inquiry_Mode' with a value 2 or so.. i.e inquiry results with RSSI or EIR format..
  • Hi, your understanding is correct. Device is discovered only with HCI tool. Basically HCITool and MCU stack uses identical Inquiry command 01 01 04. The only difference are additional commands sent by MCU stack in advance.
    HCI command sent by HCITool
    Send_HCI_Inquiry "9E8B33", 0x08, 0x14
    01 01 04 05 33 8B 9E 08 14
    HCI commands sent by MCU stack:
    HCI_OP_WRITE_SSP_MODE (Secure Simple Pairing)
    01 56 0C 01 01
    HCI_Read_Scan_Enable command
    01 19 0C 00
    HCI_Write_Current_IAC_LAP command
    01 3A 0C 04 01 33 8B 9E
    HCI_Write_Scan_Enable command
    01 1A 0C 01 03
    Read_Class_of_Device
    01 23 0C 00
    Write_Class_of_Device
    01 24 0C 03 28 00 00
  • I suggest to take BT FW logs to compare the HCI commands between HCI tester and the MCU to review the differences.
  • Hi Hari,
    I provided decoded logs for comparison already. Those are captured using extra UART interface listening to HCI_UART communication.
    As you can see above HCI Inquiry command is identical in both cases but response is different.
    We are few weeks before start of production and device isn't capable discover all BT speakers, could you please prioritize this topic within your team.
    regards
    Laco
  • It would be easy to compare the FW logs, as they are the ones seen and acted by the controller.
    Anyways, From your above HCI command list, it seems the MCU is also sending page and Inquiry scan. Did, you try disabling it?
    01 1A 0C 01 03
  • Whatever we do in order to change parameter or disable Write_Scan_Enable command at all, BT stack always executes Write_Scan_Enable with parameter 03.
    Any other ideas?
  • Which host BT stack are you using?
  • You can try with the API 'HCI_Write_Scan_Enable()'. Please check the 'BluetopiaCoreAPI.pdf' in the 'API Documentation' folder. You can also use the GAP API, 'GAP_Set_Discoverability_Mode(); and 'GAP_Set_Connectability_Mode()', in the same document.
  • Our current implementation sets GAP_Set_Connectability_Mode() to true whenever there's no active A2DP connection, otherwise to false. GAP_Set_Pairability_Mode() is set to pmPairableMode_EnableSecureSimplePairing and GAP_Set_Discoverability_Mode() is set to dmGeneralDiscoverableMode when we're trying to pair to other devices (also during inquiry), and get set to pmNonPairableMode and dmNonDiscoverableMode respectively, when an A2DP connection is established.
    Is this the recommended operation of the stack?
    What's the relationship between these APIs and HCI_Write_Scan_Enable()?
    I've now tried the inquiry also with all these calls disabled, and it still didn't make the affected BT device visible on the inquiry list. Any other suggestions?
  • Humm.. I am not sure, what else is the difference. Is it possible to take FW logs (not UART logs) with HCI/LMP viewer enabled?
  • Hi, please find requested log. That includes BT initialization and BT discover sequence.
    2806.bt_log.zip
  • Nothing seems out of order. Did, you try increasing inquiry scan window? I will look a little deeper tomorrow.,
  • Can, you try with periodic inquiry mode, i.e 'HCI_Periodic_Inquiry_Mode()'. Unfortunately, we do not have a sample demo. But, the API usage is described in the document: BluetopiaCoreApi.pdf
  • the new image with recommended BT service pack 1.4 fails to initialize as you can see in the captured logs. Can you please have look what's going wrong here.
    ThanksBT log.zip
    Thanks3286.BT log.zip
    Can, you please try with the attached service pack.
    cc256xc_bt_sp_v1.4.1.zip
    service pack v1.4.1 initialized properly but specific Panasonic BT speaker isn't still discovered. Please check attached log that includes BT initialization and device discovery.
    logfile_1_4_1.zip
  • We, will review the logs and get back later today.. But, did you try the 'HCI_Periodic_Inquiry_Mode()'?
    we have tested HCI_Periodic_Inquiry_mode which increases a chance the device to be discovered but it didn't fix our issue. Any suspicious messages in the log which I provided you?
    Since it's becoming serious problem please let us know, we'll send you Panasonic SC-MC07 device for further debugging.
  • In the provided logs, i do not see 'Periodic Inquiry scan' issued to the controller. From the logs, i see that you have enabled 'Inquiry and Page' scans as well before 'Inquiry'. Did, you try disabling 'Page and Inquiry scan' (HCI_Write_Scan_Enable(xx,HCI_SCAN_ENABLE_NO_SCANS_ENABLED,xx)), before issuing 'Inquiry'? Also, did you try increasing Inquiry length from 8 to 12 or 15.
    We, will run the tests on our setup with Panasonic SC-MC07, once we get it..
  • Hi Hari, in the meantime we fixed the issue of Panasonic SC-MC07 device discovery by applying service pack v1.4.1. Now other BT connection failure issue popped up. CC2564C is acting as BT sink and attempting to pair and connect with JBL FLIP4 BT speaker. Connection fail is reported by BT stack. Could you please check the attached log what is causing the connection to fail?0728.btlog.zip
  • Can, you send me the FW logger's .lgr file? If it is failing at the profile level, we would need HCI logs.
    https://www.ti.com/lit/pdf/swau058
  • .lgr file is included, I just used txt extension instead of lgr in the previous post8054.btlog.zip
  • The logs show connection getting established. But, later it was getting disconnected either from local or remote with 'Disconnect' reason "Remote User Terminated Connection". It appears, this is likely coming from higher Host stack profile level negotiation or user termination. Which Host device are you using? Is it possible to take HCI logs?
  • would you like to analyze HCI communication between MCU and CC2564C? I can capture log in hexadecimal format or do you suggest a specific HCI encoding tool?
  • sorry, I meant HCI decoding tool..
  • Well, there are tools like Frontline HCI sniffer etc.. When you say, you can capture in HEX format, does it mean you capture at the UART serial port with a UART sniffer?
    If, you can take air sniffer logs with either Ellysis or Frontline sniffers, that would be fine too.
  • I captured UART HCI communication in hexadecimal format listening to HCI interface between MCU and CC2564C, hoping that can be decoded by tools used by TI for BT development and debugging.
    3365.HCI_log.zip
  • unless the HCI tracing is in BT snoop format, it is difficult to decode.. Anyways, let me check and get back to you..
  • Hi Hari,
    In the meantime, we've changed BT connection mode to auto-accept but It didn't help, JBL FLIP4 BT speaker pairing fails.
    By the way, have you succeeded to decode raw data? Is there anything that we can help with?
  • I think, it is best if you can send one of these failing JBL FLIP4 BT speakers to us. We can try with our EVMs and take air sniffer logs to analyze the issues.. I could n't find a tool to parse the HEX dump you provided.
  • Dear Hari,
    we reproduced the problem with the STM32 evaluation board and connected CC2564C adapter. You should receive the commercial product soon to debug this issue on your side.
