Part Number: BOOSTXL-AOA
My customer did AoA tests with LAUNCHXL-CC26X2R1 and BOOSTXL-AOA.
The software is SDK rtls_master/slave and they followed below RTLS Toolbox.
https://dev.ti.com/tirex/explore/node?node=AHYhhuDNTaRXzkOlahOlvA__pTTHBmu__LATEST
Customer used “AOA_MODE_RAW” and AOA was calculated on PC.
(customer confirmed these PC calculation results were aligned with results obtained with “AOA_MODE_ANGLE”)
These results were not accurate as described in below Getting Started Guide.
https://dev.ti.com/tirex/explore/node?node=AANEtvJ3vSoqWPiI3wiqEA__FUz-xrs__LATEST
I will send you customer’s results by separate message.
Customer wants to know the reason of imprecision results and any ideas for improvement.
Thanks and regards,
Koichiro Tashiro
