I already try ADCBUFCONTINUOUS and Project Zero example code.
I would combine these two coding in order for me to display the analog value on Android phone.
Any suggestion or tutorial can be share to me?
Roland
Roland
Hi Roland,
I recommend looking at simple_peripheral which may be easier to work with. You should be able to take the general logic of the ADC project and transfer it to the simple_peripheral project. Can you try creating a new thread in the simple_peripheral (or project zero) project which implements the ADC logic and prints it through UART. Once that is done, I recommend looking at the SimpleLink Academy tutorials which should help you get started with the BLE portion of your use case. I recommend the following SLA labs:
Bluetooth Low Energy Fundamentals - Helps get started with Bluetooth and our SimpleLink products
Custom Profile - Shows how to create your own custom profile which may be very useful for display custom analog data and covers how to do a periodic update to this data
TI-RTOS Basics - Covers generally how the TI-RTOS works and discusses tasks and threads
Jan
