Part Number: CC2652R
Customer wants to know, from CCS, can you use the GUI to build my project and add the files etc. , then can I export a make file for building via continuous integration server.
Thank you for your question.
There are ways to use CCS in command lines (see here). This will require to produce a .projectspec.
I have notified an expert of the topic. He will help if needed.
Lawrence,
Eclipse (the underlying tool of CCS) builds the code using a makefile automatically created in the output directory of your project. It has a few other auxiliary .mk files and may be what your customer wants to know.
To validate this, simply open a command prompt in the output of the directory and issue make all or gmake all (the make tool must be on the path of your system).
Hope this helps,
Rafael
Thanks then as far as hooks to various version control/continuous integration server besides Export, there is GIT and CVS. Is there any other plugins/options that Eclipse support that I can point my customers to?
Lawrence,
There are other options available for Eclipse/CCS shown at:
http://software-dl.ti.com/ccs/esd/documents/sdto_ccs_source-control.html
Cheers,
Rafael
