Part Number: LAUNCHXL-CC26X2R1
I wonder Purpose of Stack Wrapper Project
and where is Docoument of Stack Wrapper Project??
thank you.
thank you.
The stack wrapper is a middle layer between the Bluetooth stack and the application. This project should not be modified. Behind the scene, the tool chain will use the stack wrapper to build the image.
I hope this answer your interrogations,
I do not have any use case example where modify the Stack Wrapper Project is required.
You should focus on the application project (e.g. simple_peripheral, simple_central, rlts_master, etc.).
