OAD hex file
Part Number: CC2640R2
Other Parts Discussed in Thread: CC2642R
Hi Sir
I am Using
Code Composer Studio 9.0.1
simplelink_cc2640r2_sdk_3_10_00_15
Device = CC2642R
Code Composer Studio 9.3.0
simplelink_cc2640r2_sdk_4_20_00_04
Device = CC2642R
I am using both above combinations, it generate an oad.bin file with metadata but I want oad.hex file with metadata. (both generate app.hex without metadata)  how to Generate?
Regard's
Toravi
  • Hi Toravi,
    It look like we have discussed this before. I am afraid I cannot help more than last time.
    Could you please explain me the business case behind this demand?
    Thanks and regards,
    How to calculate CRC field in metadata in oad.bin file?
    I check ti document,
    Table 24. Description of the
    Field Size (in bytes) Description
    OAD Image Identification Value 8 Unique number to identify the start of an OAD image
    CRC 4 Cyclic Redundancy Check
    BIM Version 1 Version required to support image format
    Image Header Version 1 Version of image header contained in image
    Wireless Technology 2 Type of connectivity used in image
    Image Information 4 Image information bytes
    Image Validation 4 Check if image is valid to run
    Image Length 4 The total length of the image including header
    Program Entry Address 4 Application startup entry address
    Image Software Version 4 Software version of the image
    Image End Address 4 End address of the image
    Header Length 2 Total length of the image header
    But not clear about CRC, how to calculate?
    I am Using
    Device = CC2642R
    Device = CC2642R
    Regard's
    Toravi
  • Hi Toravi,
    Could you please open a new thread with this question? To keep the forum easy to read, it is best to keep as much as possible one topic by thread.
    Thanks and regards!
