Other Parts Discussed in Thread: TMS3705
hai josh,
i connected tms3705 in the same manner that was given in the application circuitry
SCBA020 i dont know how to check whether ic is working or not can u suggest me any solution.
regards bharath
hai josh,
regards bharath
Bharath -
Please see attached training documents/notes on the TMS3705. Basically, to start out with, if you drop TXCT line, then the TX will come on, which you could see with o'scope or spectrum analyzer. Then you can move on to putting tag in field, dropping TXCT line for 50mSec for general read and look for response from standard RO/RW TI tag (see ppt)
1016.LF TMS3705A ASIC.pdf4011.Notes on TMS3705A1DRG4 & Read.ppt
hai josh,
thanx for the in formation and one more thing i should a get a carrier signal of 134khz across the antenna pins right?. when i first connect the circuitry i changed the capacitor 22uf polarity due to that it burnt out this wont damage the tms3705 ic right?
regards
bharath
Bharath -
as i am not sure of your ckt. can't guarantee that you have not damaged the TMS3705, but, yes if you follow the procedure for turning on the carrier, you will then be able to observe it.
hai josh,
i would like to know the cost of the entire module that is available in the LF TMS3705A ASIC.PDF .
regards
bharath
Bharath -
the one shown there is part of kit called RI-ACC-ADR1 ==> http://components.arrow.com/part/detail/46804795S8229655N7713?region=na&whereFrom=PublicSearchCommand, fairly expensive as compared to the -ADR2
