Where can I download the SmartRF05EB schematic partlist (Bom) ?
I'd also like to know where's the SmartRF05EB's BOM! Specially the P5 and P6 connectors.
Hi Daniel,
I'm not sure you'll find a reference design for smartRF05EB, but I can suggest
you an alternative way to find this connector (if connectors is the only part you are
looking for).
Hope this helps.
Br,
Igor
I did exactly this... but I wasn't completely sure about all specifications!
Thank you again! ;D
^are you thinking made your own board ? How are you will to make if the the layout is about multi layers?
I would like too make my own pcb, but don't know make this in reason the question like strip width, impedance...
Or make the pcb is more simple than i imagine?
Hi David,
There are several reference designs for different devices, for example:
As a start point, pick one that suits the most your future design.
There are several Application notes you should be referencing to while designing your own PCB:
Hope this helps.
Br,
Igor
Igor,
one more time thanks, i will study these files and try to producing some pcb and i will say to you the result.
The problem is wich may take time a lot. :-)
Thanks Igor
