CC2530 programming
Other Parts Discussed in Thread: CC2530
i am developing a borad based on CC2530. I am developing firmware on CC2530 development kit
i would like to know whats best option for programming CC2530 i.e. CCdebugger or development kit.
what should be necessary connection and procedure.
if someone knows about some related documentation?
egard
waqar
    You can use the SmartRF05EB, which is included n the CC2530DK, as a programmer/debugger. It works almost exactly in the same way as the CC Debugger if you connect your target to the "ExtSoc Debug" connector on 05EB. The difference is that the  "ExtSoc Debug" connector only exposes the debug interface and by default, pin 9 does not supply 3.3V.
    For the debug connector on your device, I recommend that you take a look at chapter 6.2.1 in the CC Debugger User's Guide (www.ti.com/lit/swru197).
