About AGC_CS_THR register.
Dear Sir,
We developed two RF module.
[product 1]
it had RSSI value: -70
We tested the communication between transmitter and receiver. Test was ok.
[Product 2]
it had RSSI value: -100
We downloaded the same firmware but test failed.
But, test was ok by changing the AGC_CS_THR register value(0XEF) to 0X16.
i don't know exactly the mean of AGC_CS_THR value....
  • Do you use carrier sense in your application? (MDMCFG1.CARRIER_SENSE=1) What do you change the AGC_CS_THR from? Your result should make sense if carrier sense is used and you have increased the threshold.
  • Dear Sir,
    Thank you for your response.
    We use the AGC_CS and set GPIO3 to CCA.
    two of product 1 has RSSI value -50 and two of product2 has RSSI value -100.
    We did testing the following:
    [Test 1]
    Step1. we downloaded the firmware with [7:0] agc_cs_th = 0xEF on the "product 1" and " product2"
    Step2. we did the RF communication between transmitter and receiver.
                Result --> product 1 has passed but product2 has failed.
    [Test 2]
    Step1. we downloaded the firmware with [7:0] agc_cs_th = 0x16 on the "product 1" and " product2"
                Result --> product 1 has passed but product2 has passed.
    We only change  agc_cs_th register value from agc_cs_th = 0xEF to agc_cs_th = 0x16.
    Please let me know the mean(large or small value) of agc_cs_th value
    or guide what affection is occurred to test result?
    best and regard,
