TRF7970A: FIFO Status behavior under no-continuous mode
Guru 10235 points
Other Parts Discussed in Thread: TRF7970A
Sirs,
    We observed FIFO Status unchanged under no-continuous mode.
    We captured SPI log on TRF7907AEVM terminals as follows;
        MOSI:5C 00  5F 00  5C 00  5F 00  5C 00 ...
        MISO:00 0C  00 50  50 0C  0C BE  BE 0C …
      <Explanation>
           MOSI:5Ch (read FIFO Status)
           MISO:0Ch (unread bytes=12)
           MOSI:5Fh (read FIFO)
           MISO:50h (data=50h)
           MISO:0Ch (unread bytes=12) -> Problem! (We expected 0Bh)
           MISO:BEh (data=BEh)
Question:
Is "FIFO Status unchanged under no-continuous mode" in specification?
We observed FIFO Status = 00h after continuous FIFO read as below.
(We observed "FIFO Status decrement by reading each byte ".)
        MOSI:5C 00 (read FIFO Status)
        MISO:00 0C (unread bytes=12)
        MOSI:7F 00 00 00 00 00 00 00 00 00 00 00 (read FIFO continuously)
        MISO:00 50 1B 1D 0E 00 00 00 00 01 46 06 (TRF7970A send 12bytes data via SPI)
        MISO:00 00 (FIFO Status = 00h)
Our understanding of Specification of FIFO Status as below.
(rerated thread:
http://e2e.ti.com/support/wireless_connectivity/f/667/p/340702/1191228.aspx#1191228 )
FIFO status register always shows "The number of unread bytes"
 •MCU Reads data from FIFO:The value of FIFO Status decrements.
 •TRF7970A receives data from transceiver/tag : The value of FIFO Status increments.
FIFO status register always shows "how many bytes rest to transmit"
 •Write to FIFO from MCU:The value of FIFO Status register increments.
 •TRF7970A transmits data :The value of FIFO Status register decrements.
I'd appreciate if you would send us "Precise specification/behavior of FIFO Status".
(Is there any difference on FIFO Status behabior under non-continuous or continuous mode?)
Best regards
  • Please revert to: http://e2e.ti.com/support/wireless_connectivity/f/667/p/340702/1191228.aspx#1191228
    it makes no sense to troubleshoot this before you have determined if your code or the HW is the issue.
    Please load the code from the web to verify the HW, confirm you are using SPI w/SS or parallel mode and that the EVM is OK or not, if it is OK, then your code needs to be looked at and i asked some other questions back to you in the other thread - thanks!
