Our customer will be using RI-STU-MRD2 in their next application
and we need some details or clarifications about the PWM and PPM timing parameters.
The Reference Guide(SCBU049) mentions about PWM and PPM timing command(below)
and we would like to know if these "Timing Command Format" parameters are similar to the
older module RI-STU-MRD1? Can we assume it is same for both MRD1 and MRD2?
Table 95. Setup Set PWM Timing Command Format
Table 96. Setup Get PWM Timing Command Format
Table 97. Setup Set PWM Timing Command Format
Table 98. Get PPM Timing Command Format
Table 99. Set PPM Timing Command Format
Please let us know if there is any difference betweeen the MRD1 and MRD2 regarding the
above parameters.
Note; the customer has used MRD1 before, but unfortunately don't have the details.
Best Regards
Prad
