CC1125 PER test
Other Parts Discussed in Thread: CC1125
hi sir ,
i'am using cc1125 as transceiver to test the PER ,
i have transmitting ABCD,,,,,,,Z 26 characters from one module and other as receiver , after the GPio =06 interrupt readed the packet in receiver,
i can able to to get 26 character's fully ,
but i'am checking append status byte for crc error for bad packet but igives only 6 packets good and 14 packets bad.
i'am using FIFO queue at uart baud rate 1200 at 1200 RF baudrate,with manchester enabled.
thanks and regards
Rajesh
  • Your post doesn't contain enough information to give a good answer.
    Are you using SmartRF Studio for your testing?
    Which RSSI are you measuring?
    Have you checked if the RX BW is large enough given your signal bandwidth and frequency offset?
  • Hi sir ,
    I ‘am trying to implement transceiver cc1125 module in half duplex communication.
    I can able to communicate in simplex mode in both sides, (PKT_CFG2.CCA_MODE= 010. Unless a packet has received).
    When I start transmission it shows MARC_STATUS0 .TXONCCA_FAILED in one of the module, After MARC_STATUS0 .TXONCCA_FAILED has occurred,
    How can I restart the transmission on TXONCCA_FAILED either by giving STX strobe or writing bytes to fifo and STx strobe.
    My system description
    Uart => Uc-FIFO => if(FIFO != Empty ) => get all uart bytes move to local array => if CCA free => write into CC1125FIFO=> STX strobe.
    What are the steps I need to follow if configured as PKT_CFG2. CCA_MODE = 100 b = LBT, with bidirectional (Half duplex) communication.
    here  i had attached the configuration file details.
    <?xml version="1.0" encoding="ISO-8859-1"?>
    <!DOCTYPE configuration SYSTEM "E:/Program Files/Texas Instruments/SmartRF Tools/SmartRF Studio 7/config/xml/configdata.dtd"[]>
    <dcpanelconfiguration>
        <Devicename>CC1125</Devicename>
        <Description>Saved configuration data</Description>
        <registersettings>
            <Register>
                <Name>AGC_CFG0</Name>
                <Value>0xcf</Value>
            </Register>
            <Register>
                <Name>AGC_CFG1</Name>
                <Value>0xa9</Value>
            </Register>
            <Register>
                <Name>AGC_CS_THR</Name>
                <Value>0x19</Value>
            </Register>
            <Register>
                <Name>AGC_REF</Name>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Name>CHAN_BW</Name>
                <Value>0x10</Value>
            </Register>
            <Register>
                <Name>DCFILT_CFG</Name>
                <Value>0x1c</Value>
            </Register>
            <Register>
                <Name>DEVIATION_M</Name>
                <Value>0xa3</Value>
            </Register>
            <Register>
                <Name>FIFO_CFG</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FREQ0</Name>
                <Value>0x28</Value>
            </Register>
            <Register>
                <Name>FREQ1</Name>
                <Value>0xec</Value>
            </Register>
            <Register>
                <Name>FREQ2</Name>
                <Value>0x56</Value>
            </Register>
            <Register>
                <Name>FREQOFF_CFG</Name>
                <Value>0x22</Value>
            </Register>
            <Register>
                <Name>FREQ_IF_CFG</Name>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Name>FS_CAL0</Name>
                <Value>0x0e</Value>
            </Register>
            <Register>
                <Name>FS_CFG</Name>
                <Value>0x12</Value>
            </Register>
            <Register>
                <Name>FS_DIG0</Name>
                <Value>0x5f</Value>
            </Register>
            <Register>
                <Name>FS_DIG1</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>FS_DIVTWO</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>FS_DSM0</Name>
                <Value>0x33</Value>
            </Register>
            <Register>
                <Name>FS_DVC0</Name>
                <Value>0x17</Value>
            </Register>
            <Register>
                <Name>FS_PFD</Name>
                <Value>0x50</Value>
            </Register>
            <Register>
                <Name>FS_PRE</Name>
                <Value>0x6e</Value>
            </Register>
            <Register>
                <Name>FS_REG_DIV_CML</Name>
                <Value>0x14</Value>
            </Register>
            <Register>
                <Name>FS_SPARE</Name>
                <Value>0xac</Value>
            </Register>
            <Register>
                <Name>IF_ADC0</Name>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Name>IF_MIX_CFG</Name>
                <Value>0x00</Value>
            </Register>
            <Register>
                <Name>IOCFG0</Name>
                <Value>0x40</Value>
            </Register>
            <Register>
                <Name>IOCFG1</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IOCFG2</Name>
                <Value>0x06</Value>
            </Register>
            <Register>
                <Name>IOCFG3</Name>
                <Value>0xb0</Value>
            </Register>
            <Register>
                <Name>IQIC</Name>
                <Value>0xc6</Value>
            </Register>
            <Register>
                <Name>MDMCFG0</Name>
                <Value>0x05</Value>
            </Register>
            <Register>
                <Name>MDMCFG1</Name>
                <Value>0x66</Value>
            </Register>
            <Register>
                <Name>MODCFG_DEV_E</Name>
                <Value>0x0a</Value>
            </Register>
            <Register>
                <Name>PKT_CFG0</Name>
                <Value>0x20</Value>
            </Register>
            <Register>
                <Name>PKT_LEN</Name>
                <Value>0xff</Value>
            </Register>
            <Register>
                <Name>SETTLING_CFG</Name>
                <Value>0x03</Value>
            </Register>
            <Register>
                <Name>SYMBOL_RATE0</Name>
                <Value>0x10</Value>
            </Register>
            <Register>
                <Name>SYMBOL_RATE1</Name>
                <Value>0x75</Value>
            </Register>
            <Register>
                <Name>SYMBOL_RATE2</Name>
                <Value>0x3f</Value>
            </Register>
            <Register>
                <Name>SYNC_CFG1</Name>
                <Value>0x08</Value>
            </Register>
            <Register>
                <Name>XOSC1</Name>
                <Value>0x07</Value>
            </Register>
            <Register>
                <Name>XOSC3</Name>
                <Value>0xc7</Value>
            </Register>
            <Register>
                <Name>XOSC5</Name>
                <Value>0x0e</Value>
            </Register>
        </registersettings>
        <dcpanel>
            <Property name="m_chkRegView" role="44">2</Property>
            <Property name="m_chkRfParameters" role="44">2</Property>
            <Property name="m_tabUserMode" role="37">1</Property>
            <Property name="m_easyModeSettings" role="33">-1</Property>
            <Property name="m_typicalSettings" role="33">-1</Property>
            <Property name="m_testFuncPanel" role="37">2</Property>
        </dcpanel>
        <rfparameters>
            <Property name="Xtal frequency" role="46">40.000000</Property>
        </rfparameters>
        <conttx>
            <Property name="m_rbtModulated" role="45">1</Property>
            <Property name="m_rbtUnmodulated" role="45">0</Property>
            <Property name="m_cmbDataFormat" role="46">-1</Property>
            <Property name="m_chkFreqSweep" role="44">0</Property>
            <Property name="m_chkChanSweep" role="44">0</Property>
        </conttx>
        <contrx>
            <Property name="m_chkAutoScroll" role="44">2</Property>
        </contrx>
        <packettx>
            <Property name="m_edtPayloadSize" role="42">30</Property>
            <Property name="m_edtPacketCount" role="42">100</Property>
            <Property name="m_edtPacketCountEsy" role="42">100</Property>
            <Property name="m_edtRandomPacketData" role="42">13 0d 89 0a 1c db ae 32 20 9a 50 ee 40 78 36 fd 12 49 32 f6 9e 7d 49 dc ad 4f 14 f2 </Property>
            <Property name="m_edtPacketData" role="42"></Property>
            <Property name="m_edtAccessAddress" role="42"></Property>
            <Property name="m_edtDeviceAddress" role="42"></Property>
            <Property name="m_chkAddSeqNbr" role="44">2</Property>
            <Property name="m_chkInfinite" role="44">0</Property>
            <Property name="m_chkInfiniteEsy" role="44">0</Property>
            <Property name="m_rbtRandom" role="45">1</Property>
            <Property name="m_rbtText" role="45">0</Property>
            <Property name="m_rbtHex" role="45">0</Property>
            <Property name="m_chkAdvanced" role="44">2</Property>
            <Property name="m_cmbSyncWord" role="46">-1</Property>
            <Property name="m_cmbPreambleCount" role="46">-1</Property>
            <Property name="m_chkAddress" role="44">0</Property>
            <Property name="m_edtAddress" role="42"></Property>
            <Property name="m_cmbLengthConfig" role="46">1</Property>
            <Property name="m_edtLengthConfig" role="42">255</Property>
            <Property name="m_spnPktInterval" role="52">300</Property>
            <Property name="m_chkDefPktInterval" role="44">2</Property>
        </packettx>
        <packetrx>
            <Property name="m_cmbViewFormat" role="46">0</Property>
            <Property name="m_chkSeqNbrIncluded" role="44">2</Property>
            <Property name="m_edtDumpFile" role="42"></Property>
            <Property name="m_chkAdvanced" role="44">0</Property>
            <Property name="m_chk802154gMode" role="44">0</Property>
        </packetrx>
        <commandpanel>
            <Property name="m_chkInsertLength" role="44">0</Property>
            <Property name="m_edtTxFifo" role="42"></Property>
            <Property name="m_edtRxFifo" role="42"></Property>
            <Property name="m_cmbInstrInput" role="46">-1</Property>
        </commandpanel>
        <packetRxSniffMode>
            <Property name="m_edtPreambleLength" role="42">4</Property>
            <Property name="m_edtCarrierSenseThreshold" role="42">-90</Property>
            <Property name="m_rbtRssi" role="45">1</Property>
            <Property name="m_rbtPreamble" role="45">0</Property>
        </packetRxSniffMode>
    </dcpanelconfiguration>
    Smart_RfConfig.h
    Thanks and regards
    Rajesh
