Please recommend replacement part due to EOL
Other Parts Discussed in Thread: TRPGR30ATGA, TRPGP40ATGC, TMS37145
Hi TI Folks,
  Good day to you.
  There is EOL in three TI parts, Please advise what's the replacement MPN for them.
1)RI-TRP-RRHP-06
2)RI-TRP-R9WK
3)RI-TRP-AGWK-01
best regards
Jiang WeiJi
  • Jiang -
    RI-TRP-RRHP is R/O 23mm glass, replacement is TRPGR30ATGA, disty has stock
    RI-TRP-R9WK is 12mm R/O wedge (LTB was 02/28/2014), there is no direct replacement, except the 12mm glass, which is part #: TRPGP40ATGC, disty has stock
    the RI-TRP-A9WK (you have typo there) is 12mm wedge DST transponder. The replacement is TMS37145TEAIE.
  • Hi Josh,
    Good day to you.
    Thanks for your reply. Please teach me more:
    1) Please advise more how to use TRPGP40ATGC to replace RI-TRP-R9WK? what's the difference between RI-TRP-R9WK and TRPGP40ATGC?
    2) Do you mean there is typo error in the MPN RI-TRP-AGWK-01 ? The correct MPN should be RI-TRP-A9WK ?
    Best regards.
    Jiang WeiJi
  • the 12mm glass tag is same length and will be used in same orientation as the 12mm wedge you were using. all you need to do is work out mechanicals for handling the form factor change in your application.
    we never made a AGWK device to my knowledge. we did make A9WK, which i commented on that the replacement is TMS37145
