NFC/RFID
Other Parts Discussed in Thread: TRF7970A
Thank you very much for your answer .
Now I can read a Tag.
I want to write a Tag the example contents below.
Please teach me directly the text to write in the Text window of  TAG WRITE(NFC TOOL Ver1.7).
Situation is below.
1.Hard: MPS430F5529&TRF7970ATB (MSP-FETFlash EmulationTool)
Soft: Project F5529EXP_TRF7970A_ALL_NFC_MODE
2.Tag: Tag-it tmHF-1
3.NFC TOOL Ver1.7
Connected FW Version1.03.00 (correctly displayed)nt
  NFC 7970 RW Configuration tab select
   TRF7970 RW Configuration : ISO15693 26.48
     Reader/Writer tab select
          I put a Tag near the TRF7970ATB.
    I can read a Tag.
BEST REGARD,
Morimoto.
    Thank you very much for your answer.
    I want to write a Tag the example contents (Figure 22. Text RTD Example for Type 5 Tags) in Application Report NFC/HF RFID Reader/Writer Using the TRF7970A.
    Please teach me directly the text to write in the Text window of TAG WRITE.
    Situation is below.
    3.NFC TOOL Ver1.7
         I can read a Tag.
  • Hello Morimoto-san,
    Please see this User's Guide: www.ti.com/.../slou452 and focus on content from Section 3.3.2 Reader/Writer Mode.
  • Hello Ralph Jacobi,
    I downloaded www.ti.com/.../slou452 and focus on content from Section 3.3.2 Reader/Writer Mode.
    I found there is no FORMAT button to format T5T tags for NDEF messages in Reader/Writer Mode Tab.
    My NFC TOOL is Ver1.7.
    In slou452 manual NFC TOOL is Ver1.8.
    Again I will try to download the NFCLink Standalone GUI and example code from http://w ww.ti.com/lit/zip/sloa227.
    Am I right?
    If it is not, please give me advice.
    Best Regard,
    Morimoto.
    You need to use NFC Tool Ver 1.8 which comes with the latest SLOA227 download. This is compatible with the FW Version 1.03.00 (The V1.7 GUI is compatible with 1.02.05).
