CC2510: warning: IDATA stack overflow detected.
Part Number: CC2510
I have designed customized boards for CC2510 and they are working fine except few. I am using PER_test example for simple TX_RX. whenever I transmit data with power set to 0dBM I get warning: Possible IDATA stack overflow detected.
To solve this issue I tried:
1. Increased stack size(IDATA,XDATA) as suggested in many posts on forum.
2. Ensured proper soldering connections (specially with 26MHZ crystal as I am dealing with RF).
3. Ensured impedance matching is correct.
4. Checked weather debugger is loosing sync or actual overflow, It is showing overflow(All 144 byte used out of 144,stack window showing all FF).
5. Ensured constant supply voltage 3.3v,ground, RESET,DC, DD well connected.
6. Tried to debug program step by step, got warning at packet transmit polling flag (while(!pktSentFlag);).
7. Also tried by changing data type of Packet sent flag as volatile bool instead of static bool.
The warning still persist. Am I missing something? What will be the issue?
Please help. Thanks.
