Hi TI!!
I need to use Modbus RS485 with a simplelink microcontroller. There are a library for serial modbus protocol available for simplelink microcontrollers?
Please, anything suggestion about the solution?
Thank you very mucch. Best Reagards.
Hi TI!!
Hi A,
There is no such library that I'm aware of in the SimpleLink MCU family, the available drivers can be found in the SDK documentation:
https://dev.ti.com/tirex/explore/node?node=AOSQDVXMohlV5LElLx5wxA__pTTHBmu__LATEST
The MSP430 and MSP432 have the USCI peripheral that could be used to realize the RS485 part of it (and you could likely find a way to solve that on the RF parts of SimpleLink MCUs as well):
The Modbus part you would likely need to implement the protocol side yourself, there is a few other threads on this in the forum that might help you create a clearer picture:
https://e2e.ti.com/support/interface/f/138/t/730490?Modbus-tcp-ip-protocol
There is also this open-source projects but they are not meant for commercial use:
