Hi team,
Can you please have a look at the following customer question?
Is it possible to create applications for these components without an RTOS?
If I understand the data sheets correctly, this is possible with the noRTOS.
Is the use of the drivers unrestricted possible when using without RTOS?
What are the advantages or disadvantages of using the TI-RTOS? The low-power mode and the use of the different cores are particularly decisive.
Thank you,
Franz
