Other Parts Discussed in Thread: CC110L,
I have a configuration for the CC110L chip which will act as a transmitter of some data in a sensor application.
I have tried to use the same values as register setting for my receiver CC1101, but the receiver does not receive any messages.
I have traced the SPI communication between CC110L and the sensor and can see that the CC110L is transmitting.
Is there som register differences I should now about between the CC110L and CC1101?
The register settings is as follows:
<html><head>
<style>
body {background-color:#dde;}
caption {font-weight:bold; font-size:16px;margin-left:30px}
th { text-align:left; background-color:#f00; color:#fff}
table { background-color: #eec; font-size:9px;margin:10px}
</style>
</head>
<body><table border=1 cellpadding=5 cellspacing=0>
<caption>CC110L registers</caption>
<tr><th>Name</th><th>Address</th><th>Value</th>
<th>Description</th></tr><tr><td>IOCFG2<td>0x0000</td><td>0x07</td><td>GDO2 Output Pin Configuration</td></tr>
<tr><td>IOCFG1<td>0x0001</td><td>0x2E</td><td>GDO1 Output Pin Configuration</td></tr>
<tr><td>IOCFG0<td>0x0002</td><td>0x06</td><td>GDO0 Output Pin Configuration</td></tr>
<tr><td>FIFOTHR<td>0x0003</td><td>0x4F</td><td>RX FIFO and TX FIFO Thresholds</td></tr>
<tr><td>SYNC1<td>0x0004</td><td>0xD3</td><td>Sync Word, High Byte</td></tr>
<tr><td>SYNC0<td>0x0005</td><td>0x91</td><td>Sync Word, Low Byte</td></tr>
<tr><td>PKTLEN<td>0x0006</td><td>0xFF</td><td>Packet Length</td></tr>
<tr><td>PKTCTRL1<td>0x0007</td><td>0x08</td><td>Packet Automation Control</td></tr>
<tr><td>PKTCTRL0<td>0x0008</td><td>0x05</td><td>Packet Automation Control</td></tr>
<tr><td>ADDR<td>0x0009</td><td>0x00</td><td>Device Address</td></tr>
<tr><td>CHANNR<td>0x000A</td><td>0x00</td><td>Channel number</td></tr>
<tr><td>FSCTRL1<td>0x000B</td><td>0x0F</td><td>Frequency Synthesizer Control</td></tr>
<tr><td>FSCTRL0<td>0x000C</td><td>0x00</td><td>Frequency Synthesizer Control</td></tr>
<tr><td>FREQ2<td>0x000D</td><td>0x21</td><td>Frequency Control Word, High Byte</td></tr>
<tr><td>FREQ1<td>0x000E</td><td>0x65</td><td>Frequency Control Word, Middle Byte</td></tr>
<tr><td>FREQ0<td>0x000F</td><td>0xE5</td><td>Frequency Control Word, Low Byte</td></tr>
<tr><td>MDMCFG4<td>0x0010</td><td>0xCA</td><td>Modem Configuration</td></tr>
<tr><td>MDMCFG3<td>0x0011</td><td>0x83</td><td>Modem Configuration</td></tr>
<tr><td>MDMCFG2<td>0x0012</td><td>0x13</td><td>Modem Configuration</td></tr>
<tr><td>MDMCFG1<td>0x0013</td><td>0x22</td><td>Modem Configuration</td></tr>
<tr><td>MDMCFG0<td>0x0014</td><td>0xF8</td><td>Modem Configuration</td></tr>
<tr><td>DEVIATN<td>0x0015</td><td>0x34</td><td>Modem Deviation Setting</td></tr>
<tr><td>MCSM2<td>0x0016</td><td>0x07</td><td>Main Radio Control State Machine Configuration</td></tr>
<tr><td>MCSM1<td>0x0017</td><td>0x03</td><td>Main Radio Control State Machine Configuration</td></tr>
<tr><td>MCSM0<td>0x0018</td><td>0x18</td><td>Main Radio Control State Machine Configuration</td></tr>
<tr><td>FOCCFG<td>0x0019</td><td>0x16</td><td>Frequency Offset Compensation Configuration</td></tr>
<tr><td>BSCFG<td>0x001A</td><td>0x6C</td><td>Bit Synchronization Configuration</td></tr>
<tr><td>AGCCTRL2<td>0x001B</td><td>0x43</td><td>AGC Control</td></tr>
<tr><td>AGCCTRL1<td>0x001C</td><td>0x40</td><td>AGC Control</td></tr>
<tr><td>AGCCTRL0<td>0x001D</td><td>0x91</td><td>AGC Control</td></tr>
<tr><td>RESERVED_0X20<td>0x0020</td><td>0xF8</td><td>Use setting from SmartRF Studio</td></tr>
<tr><td>FREND1<td>0x0021</td><td>0x56</td><td>Front End RX Configuration</td></tr>
<tr><td>FREND0<td>0x0022</td><td>0x10</td><td>Front End TX Configuration</td></tr>
<tr><td>FSCAL3<td>0x0023</td><td>0xE9</td><td>Frequency Synthesizer Calibration</td></tr>
<tr><td>FSCAL2<td>0x0024</td><td>0x2A</td><td>Frequency Synthesizer Calibration</td></tr>
<tr><td>FSCAL1<td>0x0025</td><td>0x00</td><td>Frequency Synthesizer Calibration</td></tr>
<tr><td>FSCAL0<td>0x0026</td><td>0x1F</td><td>Frequency Synthesizer Calibration</td></tr>
<tr><td>RESERVED_0X29<td>0x0029</td><td>0x59</td><td>Use setting from SmartRF Studio</td></tr>
<tr><td>RESERVED_0X2A<td>0x002A</td><td>0x7F</td><td>Use setting from SmartRF Studio</td></tr>
<tr><td>RESERVED_0X2B<td>0x002B</td><td>0x3F</td><td>Use setting from SmartRF Studio</td></tr>
<tr><td>TEST2<td>0x002C</td><td>0x81</td><td>Various Test Settings</td></tr>
<tr><td>TEST1<td>0x002D</td><td>0x35</td><td>Various Test Settings</td></tr>
<tr><td>TEST0<td>0x002E</td><td>0x09</td><td>Various Test Settings</td></tr>
<tr><td>PARTNUM<td>0x0030</td><td>0x00</td><td>Chip ID</td></tr>
<tr><td>VERSION<td>0x0031</td><td>0x07</td><td>Chip ID</td></tr>
<tr><td>FREQEST<td>0x0032</td><td>0x00</td><td>Frequency Offset Estimate from Demodulator</td></tr>
<tr><td>CRC_REG<td>0x0033</td><td>0x00</td><td></td></tr>
<tr><td>RSSI<td>0x0034</td><td>0x00</td><td>Received Signal Strength Indication</td></tr>
<tr><td>MARCSTATE<td>0x0035</td><td>0x00</td><td>Main Radio Control State Machine State</td></tr>
<tr><td>PKTSTATUS<td>0x0038</td><td>0x00</td><td>Current GDOx Status and Packet Status</td></tr>
<tr><td>TXBYTES<td>0x003A</td><td>0x00</td><td>Underflow and Number of Bytes</td></tr>
<tr><td>RXBYTES<td>0x003B</td><td>0x00</td><td>Overflow and Number of Bytes</td></tr>
</table>
</body><html>
